vehicle weights, what is the heaviest Torana?
_robslxhatch_
Posted 16 July 2010 - 08:52 PM
eg -vehicle mass 1250kg x 0.294 =367.5 eng capacity maximum
_niterida_
Posted 16 July 2010 - 09:59 PM
_robslxhatch_
Posted 16 July 2010 - 10:28 PM
Posted 17 July 2010 - 08:26 AM
Mark
_robslxhatch_
Posted 17 July 2010 - 08:36 AM
Posted 17 July 2010 - 11:19 AM
Maximum engine capacity is based on the original tare of the model vehicle fitted the the largest engine available without optional accessories.
The actual tare of the car is not relevant. Each licencing authority appears to have their own figure. You may be able to argue that there figure is wrong and use a figure published by GMH, however I expect you would drown in red tape.
The heaviest figure I have seen in print is for a 6 cyl LX hatch which is 1213 kg. However the Perth Technical section use 1204 kg for both the hatch and sedan.
It is my understanding NSW have similar wording and rules.
This is a sample of weights posted by GMH355. For memory this is an extract from a NSW document. It appears that NSW use 1205 kg.
Edited by ls2lxhatch, 17 July 2010 - 11:22 AM.
_torbirdie_
Posted 17 July 2010 - 02:41 PM
i am just wondering what is the weight of heaviest torana from the factory is?? . I ask this because my engineer has told me that you times the vehicle weight by 0.294 and it will give you the maximum engine size allowable .
Id assume the heaviest torana that came out of the factory would have fitted a 5L v8, auto, ac and towbar...and whatever other weighty options were available.
Its not clear how you engineers formula works? does the mass include the mass of the motor you are going to put into it?, or is it the mass of the vehicle without a motor in it.
I would have thought from an engineering point of view the actual weight of the motor would be more important, but I suppose the capacity sort of looks after that anyway.
Edited by torbirdie, 17 July 2010 - 02:43 PM.
_torbirdie_
Posted 17 July 2010 - 02:51 PM
you would think they should go off the weight the vehicle is at time of inspection . i'll bet most ppls Torys are heavier than standard with 9" diffs and alike!!
Perhaps some authorities work with that rule, but isnt it about whether the car/chassis is designed for the weight?
Im sure there would be lots of ways(legitimate or not) of getting the car's overall mass up by a couple of hundred kilos for the inspection just so one could put in a higher capacity motor.
Edited by torbirdie, 17 July 2010 - 02:53 PM.
_SS Hatchback_
Posted 18 July 2010 - 09:19 AM
Posted 18 July 2010 - 08:57 PM
_moot_
Posted 19 July 2010 - 09:03 AM
Posted 19 July 2010 - 09:42 PM
_V6 UC_
Posted 19 July 2010 - 10:39 PM
_smoken2_
Posted 11 August 2010 - 11:40 PM
can you post or email me a copy? engineer says i'm limited to the 1204kg that the rta says unless i can prove otherwise (from the factory)
I put an LX 4 door A9X over the pits in WA (a few years ago) and the WA inspector showed me an old Torana list of weights and the 4 door A9X was quoted as 1315 KG.
Well that's what his documentation had on it, I guess it's only a piece of paper that somebody typed up in the late 70's.
Catch U all Later.
Posted 17 August 2010 - 08:01 PM
Thought it would of been a fair whack lighterI had my LX weighed for engineering and the fat pig came in at 1360kg with a LS1 and T-56. This is the mass weight they used.
Mark
_V6 UC_
Posted 18 August 2010 - 11:14 AM
_sstorana_
Posted 19 August 2010 - 03:54 PM
From the information that I have here...
Heaviest Kerb weight for the different model Torana's are;
HB SL 4 Door 829kg
LC GTR XU-1 1102kg
LJ GTR XU-1 1096kg
TA Sedan 918kg
LH L34 Sedan 1306kg
LX A9X Hatch 1242kg
LX A9X Sedan 1306kg
UC SL Hatch 1166kg
UC SL Sedan 1181kg
Mick
Posted 19 August 2010 - 04:05 PM
If you have access to some sort of official documentation then there is a chance of getting the rego departments to accept the figures.
Edited by ls2lxhatch, 19 August 2010 - 04:05 PM.
_UCV80_
Posted 19 August 2010 - 07:27 PM
_sstorana_
Posted 19 August 2010 - 09:18 PM
Do you have any paperwork to backup the figures?
Andy
weights are in the Appendix at the back of Dr Terry's book, 60 years of Holden.
Mick
#21
Posted 19 August 2010 - 09:37 PM
I doubt the book would be sufficient however it is a start. Dr Terry may have access to an official document or it may be possible to get the specifications from Holden.
In WA 1306 kg will give.
Naturally aspirated
1306 * 5 = 6530 cc (398 ci)
Turbo/Supercharged
1306 * 3 = 3918 cc (239 ci)
#22
Posted 19 August 2010 - 10:27 PM
Naturally aspirated
Thats big block territory WooT.
#23
_moot_
Posted 20 August 2010 - 07:48 AM
if you can do that,i'll promise to buy a bigblock
#24
_sstorana_
Posted 20 August 2010 - 12:37 PM
i would love something offical that says the weight.
I would think that Dr Terry might have this info as his book details pretty much every model, and variant Holden ever made..
Dt T.. over to you.
Mick
#25
Posted 20 August 2010 - 12:51 PM
