LX Steering Column Firewall mount
9 replies to this topic
#1 kingsly
kingsly
  • 235 posts
Posted 30 August 2010 - 01:03 PM
Just a quick question some one might be able to help me with is the steering column's plate that mounts on the firewall..
My lx came in pieces and it came with a steering column (with column shift) .. but when I went to bolt it in. .the plate wasnt lining up with the threaded holes on the firewall. It actually looks like someone has put it on backwards.
Now my 74 LH is stil complete and after looking at the mounts on that it still looks like the plate is reversed on my lx's one.
Now a few questions - are those plates the same through both lx and lh's.
Have i been given a LH one with my LX.. can that plate be removed.
I tryed but the column shifter coupling was preventing the plate from sliding off the end..
I shall get a few pics tonight for closer inspection.
But i've added this pic i grabbed from ayios project thread
cheers for any help
Edited by kingsly, 30 August 2010 - 01:04 PM.
#2 Statler
  • 6,309 posts
Posted 30 August 2010 - 01:05 PM
AFAIK there is no difference between the LH & LX plates.
The auto/manual ones are different.... in that the manual one has the hole for the clutch rod.
I don't know about the column shifts though.
#3 kingsly
kingsly
  • 235 posts
Posted 30 August 2010 - 01:13 PM
hmm ok cheers for that statler, both my lh and the lx are auto's (and the lh has a column auto in it). i'll post some pics up 2nite and see if it make sense to some1 else.. i may just be a dumbass.
#4 Heath
  • 18,378 posts
Posted 30 August 2010 - 04:32 PM
From memory, my panel doesn't have a hole in it because it has a factory fitted full cable clutch, but yes for rat traps they do have holes and they should all be the same apart from that.
#5 Torryhead
Torryhead
  • 90 posts
  • Name:Dan
  • Car:74 LH
Posted 01 September 2010 - 02:02 AM
Posted ImagePosted ImagePosted Image
hey mate, hope this helps. pics my wife took while doing up the LH. ignore that the steering shaft is shorter and a bit cleaner looking, i did the bearing conversion (something that i highly reccomend though)
Torryhead
Also, this was a factory floor shift Auto if i'm not mistaken
#6 kingsly
kingsly
  • 235 posts
Posted 01 September 2010 - 09:53 AM
awesome thanks torryhead. I'll jump out to mine this evening and do a bit of a comparison.,.
cheers again
#7 kingsly
kingsly
  • 235 posts
Posted 07 September 2010 - 10:44 AM
ive just added some pics for you guys to have a quick look .
see if im missing anything here.
in the last pic the top locator in in place where i think it should be and you can see the rest of the plate is way out... it is even a torrie column ? ahahha
#8 _The Baron_
_The Baron_
Posted 07 September 2010 - 11:39 AM
That appears to simply be the wrong plate, it may even be the wrong steering column all together.
I would suggest you take a minute and go to a pick your part sort of place and have a look, you may even pickup the whole assembly whilst there if it turns out yours is from a completely different model.
Please be aware that whilst the plate in question is the same for LH/LX/UC (except for manual 6cyl which will have the hole for the clutch rod.) The Columns are a little different through the models because:-
LH has the head light switch on the dash with the light dimmer switch location on the floor.
LX has the head light switch on the dash with the light dimmer switch location on the Column.
UC has the head light switch on the Column with the light dimmer switch location on the Column.
This all means you need the right column to make the wiring compatible for your model.
Mind you, just to throw a curve ball, some early LX, in particular the �S� with bench seat I believe has the LH floor dimmer arrangement.
Do you live in the north or south of Adelaide as someone may be able to come and have a look for you?
#9 Statler
  • 6,309 posts
Posted 07 September 2010 - 12:19 PM
I'm with Baron, that's the wrong plate.
#10 kingsly
kingsly
  • 235 posts
Posted 07 September 2010 - 12:41 PM
yeh thanks for clearing that up baron. when i was comparing to my lh plate the dome shaped concave section along side the cutout for the actual column -on the lh and in torryhead pics above that concave is very pronoun.. and in the plate i have in the pics is only just protuding.
i'm north of adelaide , Paralowie area.
So now im no the hunt, so if anyone has a column for sale,, please let me know..
cheers for the help.
