Transmission tunnels
_TUFF75LH355_
Posted 27 September 2010 - 06:16 PM
Posted 27 September 2010 - 06:29 PM
Posted 27 September 2010 - 06:41 PM
And whether they have done one before
_TUFF75LH355_
Posted 27 September 2010 - 06:50 PM
Edited by TUFF75LH355, 27 September 2010 - 06:51 PM.
Posted 03 October 2010 - 03:15 PM
I would make a cardboard template and bring that to a metal fabricator.im only going a th350 but my one has been massaged to fit the linkages on my top loader that is currently in the car and its not the greatest job was thinking of replacing with a fabricated one
Make up your template and fit the box in position and see how it looks then make adjustments by trimming etc until youre happy with it.
I made mine with a home made sheet metal bender, i used 2mm sheet, cold rolled steel.
Nissan RB25t gearbox which is pretty fat
Basic template shape, (Template not in pic)
In position, i pressed the tunnel edges with a piece of angled wood to nicely butt up the tunnel edge to the floor edge and tacked it on with a mig, had about 30 odd tacks before a full weld.
Rounded off and tappered the back to meat the flood and the original part of the tunnel.
Posted 03 October 2010 - 07:39 PM
_LEE_
Posted 03 October 2010 - 07:54 PM
Posted 03 October 2010 - 09:17 PM
Rod Andrews is a great fabricator/welder, helped me out heaps, he is normally too flat out but give him a go.Try Rod Andrews in Seven Hills.....
http://www.andrewsracecars.com.au/index.html
P.S. Nice work Bart !
Thanks Struggler
Edited by Bart, 03 October 2010 - 09:27 PM.
Posted 04 October 2010 - 02:39 PM
I forgot to mention, after I welded it all in I had allot of excess steel sticking out under the tunnel, I trimmed this off after welding. I left the excess intentionally as you never know it may end up too short even if the template seems accurate at the start. So leave excess, weld then trim. Use zinc primer, then sound deadening.Rod Andrews is a great fabricator/welder, helped me out heaps, he is normally too flat out but give him a go.
Thanks Struggler
_gtr-xu1_
Posted 04 October 2010 - 04:04 PM
extreme engineering did a removable patch panel for my tunnel
