Cable clutch setup, help!
34 replies to this topic
#1 Heath
  • 18,375 posts
Posted 05 October 2010 - 06:37 PM
My Torana is no longer driving because the clutch actuating system is stuffed. After battling for ages to try and get the bastardized cable out of the pedal, I have given up and come in for some advice.
I've had the system apart once (a long time ago), and I remember it being a massive pain in the arse - definitely the most unpleasant job I've done on the car. But until today, I didn't understand why it was a problem. I think I've now worked out that the clutch cable is a normal UC clutch cable that has had the end trimmed down and it is fitted into a pedal which it isn't designed for. What I don't know is what the hell the pedal is out of. It doesn't have a hook - it has a complex strainer setup (which I guess is made for a ball on the end of a cable, like the handbrake cable has)
The crappy setup is how it came with the car, I have just at one point pulled it apart and lubricated it before re-assembly, without really understanding what it consisted of
The incident/failure occured with a crack sound when I had my foot depressing the clutch to the floor - there was a 'crack' kinda sound, followed by the clutch pedal staying on the floor and not wanting to move from the floor. The ends of the cable still seem to be directly connected (what the?), and at first the clutch stayed completely disengaged (what the?) although that is no longer the case. I wanted to just pull it all apart to find out what has actually broken, and the only thing I can really spot is that the sheath of the cable seemed to have broken? I am so confused and it has put me in the worst mood. First time the car has ever broken down on me
Here are some photos...
Is this factory? Doesn't really look like it lol
I can buy a new UC clutch cable, but it won't suit this pedal and there is a significant waiting time. This pedal's little strainer linkage thing's pivot point is stuffed as (I can remember that from when I pulled it apart a long time ago) and it would be much more serviceable if I replaced it with a hook setup like it probably should have, but is a pedal with a hook on it going to cost me the earth? And am I going to be able to get one quickly? Can I buy a clutch cable that has a ball on one end and a hook on the other and what did it come out of or would it be a custom job? Is this the clutch pedal out of a rat trap setup? Please tell me what you can
#2 _evil UC hatch_
_evil UC hatch_
Posted 05 October 2010 - 06:54 PM
I cant help you with too much, but there was a forum member selling the hook part of the pedals a while back to convert the pedals to the hook type. from memory it was just a matter off cutting back the original linkage part and welding on the hook.
I too would assume its a rat trap pedal but Im not exactly a reliable source for that info
#3 _aussie4speeds_
_aussie4speeds_
Posted 05 October 2010 - 07:12 PM
call me i can help you out on what to do
#4 TerrA LX
Posted 05 October 2010 - 07:50 PM
is it a rat trap system?
imo convert it to a UC cable system.
You will need pedal, cable, folk, carrier and bell housing.
#5 rodomo
  • 18,030 posts
Posted 05 October 2010 - 07:57 PM
UC pedal here for a LEND (read lend) until you get yours sorted, might have a cable too?
Did you read the bit about LEND??
#6 MRLXSS
  • 12,400 posts
Posted 05 October 2010 - 09:14 PM
This should solve your problems... Don't think the BBQ 202 will blow it up anytime soon as well...
Heath's Saviour
#7 LXCHEV
LXCHEV
  • 3,542 posts
  • Car:'76 LX - 383 Chev
Posted 05 October 2010 - 09:33 PM
I think it's time you convert to the proper UC type setup too.
I personally have no idea about that current setup... not sure if it's factory or a hack job.
Somewhere buried in my shed, is a spare hook that I bought off Craig a while back. I never used it, as I ended up buying a complete pedal off him already modified. So if you decide to convert your pedal, you can have my hook for $10. Just let me know if you're keen, as I need to find it first!
What's at the other end of your cable... are you running the rat-trap with push type clutch, or this already a pull type full cable??
#8 Heath
  • 18,375 posts
Posted 05 October 2010 - 09:45 PM
lol a slushie in my shitbox? No thanks!
Brett, SMS sent.
The car has a pull type full cable arrangement, the only problem with it is that the pedal end is really dodgy, and where it feeds through the firewall it isn't that glamerous either. Hopefully I can fix both of those problems
I just borrowed that UC pedal off Rob and I've found a spare UC cable in the shed. I'm gonna pull the car apart when I get a chance (working flat out atm) and see what I have to do to get rid of the strainer thing. I might just need to drill into the existing bracket and grind out an area to make it hook in, but I doubt it. I'll try and get Brett's hook and weld it on
I found these old photos of when I had it apart.
Now, how #@$^%& is THAT!? That is the pivot shaft between the pedal and the strainer.
#9 rodomo
  • 18,030 posts
Posted 05 October 2010 - 09:54 PM
THAT is the clevis pin we spoke about
#10 76lxhatch
  • 7,201 posts
Posted 06 October 2010 - 06:17 AM
I must say I'm a little surprised Heath, you don't seem to hesitate at a bit of custom work in most areas, but you can't make a little steel hook and weld it on the end of the pedal?
#11 _Bomber Watson_
Posted 06 October 2010 - 05:43 PM
I got a UC brake and clutch pedal setup for free, not hard to find Heathyboy.
#12 Heath
  • 18,375 posts
Posted 06 October 2010 - 06:59 PM
Yeah look maybe I am being a bit of a girl about it, it's just that I have no access to the problem area (I still haven't figured out why it isn't actually working!) and that I'm not really familiar with the system, or more to the point - how the system is supposed to be.
Half the things I have been reading are confusing the shit out of me. I just want a standard UC setup with the MC6 and everyone is talking about V8s with aussie boxes and 25mm this, getting rid of rat trap that. If I wasn't working on a complete car, things would be a bit more simple.
Anyway, I should have it sorted soonish, I just need to spend some time on it and I should be able to figure out which way to go
#13 76lxhatch
  • 7,201 posts
Posted 06 October 2010 - 08:32 PM
Measure the cable movement required at the gearbox end, and match it at the pedal end. Sounds like you have it under control anyway :)
#14 _Bomber Watson_
Posted 06 October 2010 - 08:46 PM
Sounds to me like you broke the inner cable....
#15 MRLXSS
  • 12,400 posts
Posted 06 October 2010 - 09:01 PM
Sounds to me like you should just get an auto....
#16 _Bomber Watson_
Posted 06 October 2010 - 09:09 PM
An auto in Heaths car would suck.
#17 Heath
  • 18,375 posts
Posted 07 October 2010 - 05:01 PM
Matt, you are such a girl. Did you swap to auto because you broke your clutch pedal? lol
Anyway, great news. Got the frOcker all apart and made some findings. I bought the hook off Brett but I don't need it so I might chuck it in the blue car instead.
This is the only breakage of the cable
Looks like the sheath where the flange is connected has snapped and slipped up over the metal casing, removing the tension in the setup. From my observation, it is the only way in which the setup has 'failed'. Now unless there is a problem at the bellhousing end, that's it. That's all!
Bastardized end:
Strainer that they made it fit into:
What does this mean? Originally a rat trap or something else? Body plate says it came with an MC6...
Guess what tool I will be using? That's right, the angle grinder!
So yeah if you want to do a full cable conversion without doing any welding (or spending), just find an LX Sunbird pedal like mine
#18 _BLACK LH_
_BLACK LH_
Posted 07 October 2010 - 08:37 PM
Bastardized end:
Love the post heath, i am having very similar problems setting up my v8 lh with the 4cyl sunbird clutch pedal ( i think)
if ya can get any pics with all assembled in the car, especially where clutch cable comes out fire wall would be great
#19 _BLACK LH_
_BLACK LH_
Posted 07 October 2010 - 08:40 PM
My dodgy pedal, i think uc sunbird?
#20 Heath
  • 18,375 posts
Posted 07 October 2010 - 09:24 PM
Yeah that is the same as my pedal before I dis-assembled it. I think LX Sunbird. TO ME, there is no reason that a UC Sunbird pedal would be any different to a UC Torana pedal, because as far as I know, the gearboxes and clutch arrangements are the same. Which is also re-enforced by the fact that the 4cyl and 6cyl clutch cables have the same part number.
But seriously, that pedal is a good thing to have. All you need to do is remove the strainer and turn its mount into a hook by grinding it, and you have essentially a UC manual pedal. That might be no good for a V8 though, I dunno. Worst case scenario you cut the mount off and buy a $12 hook off Toranamuk and weld that on. Easy as piss
Mine already had that hole arrangement in the firewall, and I probably won't need to change it. I'll know soon enough
Edited by Heath, 07 October 2010 - 09:27 PM.
#21 _Toranamuk_
_Toranamuk_
Posted 07 October 2010 - 09:53 PM
There's more to the story than meets the eye,
Heath, you're sort of right, the 4 & 6 cyl UC's do have the same part number cable- when they have the 6cyl or Starfire 4cyl fitted. These cars had the same base clutch set-up & the same pedal.
The early UC's had the Opel 4cyl same as the LH/X's had & all used the same pedal with the same cable that crossed to the left hand side of the car.
From what you've described you require the "late UC or Commodore" style of setup, this is presuming that the clutch fork & bellhousing is what your describing it as, maybe you could post some pics so it can be verified.
The hook can be welded to your pedal in the shorter of the 2 measurements (unless you want to weld it in the longer V8 position which will give you shorter pedal travel).
more info later
Craig
#22 MRLXSS
  • 12,400 posts
Posted 08 October 2010 - 06:43 AM
Nope, because it was the weakest point in my driveline...
#23 _fryzem_
_fryzem_
Posted 08 October 2010 - 07:05 PM
looks to me as someone has done what i did ten years ago in my car when it was a manual, we used a commodore cable and slipped the end into the pedal same as what they had done with yours. only thing is mine lasted for more than 5 years that way and did well over 100,000kms. no drama's at all.
#24 Heath
  • 18,375 posts
Posted 10 October 2010 - 03:24 PM
Well this setup obviously lasted a while too, but the cable really needed to be a fair bit shorter than it was. I compared the cable to the standard UC unit (which I have ordered a new one of, I should get it late Monday) and it did not match in length. Don't know what it was out of, potentially Commodore or full sized Holden, or something else again (don't know about Camiras and shit like that?)
Anyway I got the car driving about half an hour ago, just with a dodgy cable I had left over from the Brock UC, but it is fraying so it should be gone by Knox for Tuesday night. So it hasn't cost me anything so far, just used Rob's pedal as reference. But obviously the new cable isn't going to be that cheap. Doesn't help that I am getting it couriered across town either. That's what money is for though!
Looks a bit neater under the bonnet too now. Still a shitheap under there but progress is progress
No more dodgy brackets, just a zinc plated washer.
Thanks for the help all
Edited by Heath, 10 October 2010 - 03:30 PM.
#25 rodomo
  • 18,030 posts
Posted 10 October 2010 - 03:59 PM
NO!
I won't answer my phone with 10 laps to go and a safety car! :furious:
(you should know better)
