HJ panel van
17 replies to this topic
#1 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 16 October 2010 - 04:18 PM
Thought i might put up some photos of my van that i done in 2007.
Attached File  Car 1_resize.jpg   114.84K   0 downloads
To start i cut the chassis just after the spring mount and re-fabricated it to run 90mm higher about the diff and moved them in 40mm each side, then set up the triangulated
4 link using nissan patrol trailing arms and copied the angles and mounting positions from a hj sedan. The air bags are mounted to the front side of the diff with sedan shocks and the back.
I cut down a f100 diff to suit with moser axles, 3.55 LSD centre and modified WB rear disc brakes to work with the big bearing axles.
Attached File  Image009.jpg   307.84K   2 downloads
Edited by turbo76lx, 22 October 2017 - 07:51 AM.
#2 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 16 October 2010 - 04:34 PM
The motor is a rebuilt 308 with VN heads, i thought i might have a play with manifold and turn it into a twin throttle body setup.
Gearbox is a rebuilt T700 with a stage 2 shift kit and 2500rpm stall.
Inside the manifold.
Attached File  Image004 (4)_resize.jpg   150.4K   0 downloads
Attached File  Image006 (2)_resize.jpg   104.84K   0 downloads
Attached File  Image009 (2).jpg   575.38K   0 downloads
Attached File  Image015_resize.jpg   197.01K   0 downloads
Attached File  Image019 (3)_resize.jpg   137.35K   0 downloads
Attached File  Image021 (2)_resize.jpg   125.86K   0 downloads
Edited by turbo76lx, 22 October 2017 - 07:55 AM.
#3 lcgtr1970
lcgtr1970
  • 1,702 posts
  • Name:Jordan
Posted 16 October 2010 - 09:08 PM
looks cool mate! looks like it would have loved speed bumps!!!
got any more pics? interior?
#4 TerrA LX
Posted 16 October 2010 - 09:45 PM
Awesome, would love a PV myself.
Ol mate used to have SINBIN numberplates on his HZ.
#5 gtrboyy
gtrboyy
  • 3,209 posts
Posted 17 October 2010 - 01:34 AM
Would've liked to have seen you have a crack at doing a grp a replica manifold...some guys have had good results adding trumpets inside the manifold & also giving it a larger plenum area.
#6 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 17 October 2010 - 02:23 PM
Speed bumps are no problem when it's at ride height it looks like a standard panel van.
I did think about having trumpets on the inside of the manifold, but that was going to be to much work and make the manifold to high.
As it is it has 188rwkw (252rwhp) so it enough to have some fun with. Another reason i set the manifold up in this way is it would nice and easy
to pipe up a twin turbo setup.
Because the rear tyres are 275/60 15 and the chassis work i need to do a bit of tub work. I hate the look of square cornered tubs so made then with radius
corners and some folds to copy the orignal floor then cut the floor to go up and over the chassis.
Attached File  Image003 (2)_resize.jpg   138.64K   0 downloads
Attached File  IMGP1023_resize.JPG   152.87K   0 downloads
Attached File  IMGP1024_resize.JPG   170.29K   1 downloads
Edited by turbo76lx, 22 October 2017 - 07:59 AM.
#7 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 17 October 2010 - 03:26 PM
A dodgy video of the rear air bags working.
A few more photos.
Attached File  Car 2_resize.jpg   116.26K   1 downloads
Attached File  Image004 (2)_resize.jpg   121.76K   0 downloads
Edited by turbo76lx, 22 October 2017 - 08:02 AM.
#8 lcgtr1970
lcgtr1970
  • 1,702 posts
  • Name:Jordan
Posted 17 October 2010 - 08:30 PM
:clappin: that is awesome! love it!
#9 MRLXSS
  • 12,413 posts
Posted 17 October 2010 - 09:46 PM
That is COOL AS! I love it!
#10 Heath
  • 18,385 posts
Posted 18 October 2010 - 12:03 PM
Really love the form work in the tubs. Good stuff
#11 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 19 October 2010 - 07:57 PM
The interior is just retrimmed buckets seats, GTS dash with the original air chief radio, speedo converted to electronic (same as my torana) and a Lokar gear position indicator mounted in the dash.
Modified a VN shifter and used the original console.
Attached File  IMGP1025_resize.JPG   141.99K   1 downloads
Attached File  IMGP1022_resize.JPG   111.34K   1 downloads
Attached File  IMGP1027_resize.JPG   151.12K   1 downloads
Attached File  IMGP1026_resize.JPG   150.2K   0 downloads
Another photo of the back, the inner panels were cut and shut to fit back in to keep the original look.
Attached File  IMGP1023_resize.JPG   152.87K   1 downloads
Edited by turbo76lx, 22 October 2017 - 08:10 AM.
#12 _Torrie_Man_
_Torrie_Man_
Posted 19 October 2010 - 09:22 PM
thats mint!
#13 _Quagmire_
_Quagmire_
Posted 20 October 2010 - 12:12 AM
no bed, bar ,or crushed peeerple velvet Posted Image
I frocking lurve it
#14 308mate
308mate
  • 523 posts
  • Name:scott
  • Car:76 SS hatch (Royal Plum, Chevron Chamois interior), HQish Van (Orchid Metallic)
Posted 09 July 2011 - 07:03 PM
pannos n torys what could b fina. love the pannie on iys guts. cheers, \m/
#15 TerrA LX
Posted 10 July 2011 - 07:18 AM
Sweet PV.
one day... one day....
#16 orangeLJ
Posted 03 September 2012 - 02:25 PM
Have you got any detailed pictures of how you did the front bags?
also, how you setup the rear with the 4 link?
#17 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 03 September 2012 - 07:48 PM
I don't have any photos of the front bags but i brought the kit from airide http://www.airide.co...products_id/569
The rear is a triangulated 4 link that i copied from the angles of from a hj sedan rear end but using upper and lower rear trailing arms from a
GQ nissan patrol which are both 100mm longer than the hj arms.
I do have this dodgy video of the rear end.
Edited by turbo76lx, 03 September 2012 - 07:49 PM.
#18 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 22 October 2017 - 08:35 AM
Bit of an update, thanks to Dattoman I was able to fix the photos because of photobucker extortion attempt.
The GTS steering wheel always seemed to rub on the column, so pulled it out and compared it to a spare one I hand to
find the top bearing was never set up right and had lost some of the ball bearings.
Used the bearing out of the old column and repacked them into the column.
Attached File  IMGP3027_resize.JPG   150.47K   2 downloads
Attached File  IMGP3025_resize.JPG   143.3K   1 downloads
Attached File  IMGP3028_resize.JPG   164.57K   2 downloads
Attached File  IMGP3030_resize.JPG   151.27K   1 downloads
Also replaced the nolathane sway bay bushes the had collapsed.
Attached File  IMGP2960_resize.JPG   181.73K   1 downloads
And how it sits now, keeping it barn find fresh, since that seems to be the buzz word.
Attached File  IMGP3409_resize.JPG   78.87K   1 downloads
Attached File  IMGP3410_resize.JPG   71.59K   0 downloads
Found some more old photos.
Attached File  Image001 (2)_resize.jpg   83.94K   3 downloads
Attached File  Image01.6_resize.jpg   168.37K   2 downloads
Attached File  Image01a_resize.jpg   123.98K   0 downloads
Attached File  Image01d_resize.jpg   124.35K   0 downloads
Attached File  Image009p.jpg   13.48K   0 downloads
Attached File  Image012p.jpg   17.68K   0 downloads
Attached File  Image019 (2)_resize.jpg   178.67K   2 downloads
