Billet aluminium wheel hub made in Germany
34 replies to this topic
#1 The German
The German
  • 268 posts
  • Name:Uwe
  • Car:LH V8 1974
Posted 01 January 2011 - 04:15 AM
Dear Torana friends,
i have here a hub conversion kit for a Torana (i dont know what other Holdens have the same ...)
A front wheel hub set and a adapter plate for the rear.
To use racing or other brake disc systems.
Made in Germany from 7075 Aluminium.
Both are made with BMW measurements PCD 5x120 to fit at the original PCD 5x108
This kit will be available with custom PCD`s soon at my Holden-Torana website
Anodized in Green,Red,Blue,Clear
%3Ca%20href=Posted Image"> %3Ca%20href=Posted Image">
Weight difference of the front hubs to original is minus 4,2 KG
Uwe
#2 _CHOPPER_
_CHOPPER_
Posted 02 January 2011 - 10:36 PM
Adapters are illegal. Being BMW spec, does that mean the centre bore is 74.5mm as opposed to the VB - VZ Commodore centre bore of 69.5mm? And VE centre bore of c. 66.9mm?
#3 TerrA LX
Posted 03 January 2011 - 05:42 AM
BTW torana pattern is 4.25 inches which is 107.950mm.
Edited by TerrA LX, 03 January 2011 - 05:43 AM.
#4 The German
The German
  • 268 posts
  • Name:Uwe
  • Car:LH V8 1974
Posted 03 January 2011 - 06:16 AM
We manufacture all center bore measurements you would like to have.
This kit is for my Torana in Germany for race and street use .
This hubs are made to use other brake discs at the Torry.
We design our own brake system with Porsche 997 calipers front and rear with discs in front to fit in a max. 16" rim.
I did choose the BMW spec 5x120 to have a choice of a huge range of rims here at the market.
In Germany you can buy Adapter plates at every corner with a Street legal certificate,not a big deal.
We thought first just to drill 5x120 at both ends but this was my final idea.
Uwe
#5 ls2lxhatch
  • 5,332 posts
Posted 03 January 2011 - 11:58 AM
In Australia you can buy adaptor plates and spacers on every street corner as well however they are not legal in any state unless factory fitted.
The Torana factory studs 7/16" should be replaced with larger studs (1/2" or 12mm ) if you use an adaptor.
Edited by ls2lxhatch, 03 January 2011 - 12:05 PM.
#6 _Bomber Watson_
Posted 03 January 2011 - 12:28 PM
Um, guys, have a look at that spacer.
It looks like it locates over the center spigot of the hub assembly, and then it has a center spigot of its own for the wheel to locate on.
Perfectly safe.
And he's in Germany, who gives a frOck if you cant use it here Uwe is doing more R&D for Toranas than any of us have ever done.
Keep up the great work mate!!!
#7 ls2lxhatch
  • 5,332 posts
Posted 03 January 2011 - 12:40 PM
And he's in Germany, who gives a frOck if you cant use it here.
It appears that The German would like to sell the adaptors to Torana owners in Australia via his website. I thought he may be interested in knowing that they are not legal for street use in Australia although many people do use them.
Typically a centre bore locater does not add strength it is purely to ensure that adaptor is aligned to the axle. To provide strength the centre bore locater would need to be a press fit preferably a taper press fit.
Edited by ls2lxhatch, 03 January 2011 - 12:45 PM.
#8 _Bomber Watson_
Posted 03 January 2011 - 01:27 PM
Just because i replied in a thread you also replied in doesnt mean i was having a dig directly at you Andy. I agree with all that you said in post #5.
And whats wrong with selling them in Australia? Tyre shops dont tell you there illegal, infact i was in a tyre shop the other day who had them hanging on the wall and asked if they were illegal or not and he said and i quote "na mate there totally legal in QLD"
I didnt say anything obviously cause i was trying to get a good deal out of the bloke but i think a shop saying something like that is total bullshit.
At the end of the day im sure Uwe is developing all this stuff for his car, and the fact that he is willing to share it with us is great. We do have a lot of dedicated track only cars in AUS as well that can benefit from this gear.
#9 ls2lxhatch
  • 5,332 posts
Posted 03 January 2011 - 01:40 PM
I agree with you Bomber.
It was more of a heads up for Uwe if he plans to sell into Australia. The tyre shops that sell and fit the adaptors are exposing themselves to litigation should something go wrong. Uwe could cover himself by selling them as off road use only.
#10 _Bomber Watson_
Posted 03 January 2011 - 01:49 PM
One question for you actually, all this discussion has been about the spacers, but what of the alloy hubs?
In your impressive knowlege of the modification laws, for wa atleast, is there anything illegal about them??
I think the main reason for the spacers is to allow the OP to run BMW rims which tend to have very little offset....Probably also allow more room for the projected brake upgrades to i suppose.
Buttt i do like the look of the hubs.
#11 _CHOPPER_
_CHOPPER_
Posted 03 January 2011 - 02:56 PM
If you're going to post the pictures, you need to at least note that they weren't installed incorrectly.
and because of this the studs were taking all the load. so were bound to fail.
Dangerous assumption that. For all you know, he could have correctly installed them according to the supplied instructions. Clearly the adapters weren't designed to be centre bore located, which is obviously a conributing factor. This matter was discussed quite some time ago.
#12 The German
The German
  • 268 posts
  • Name:Uwe
  • Car:LH V8 1974
Posted 03 January 2011 - 05:38 PM
All what i am manufacturing here in Germany is that what i did desperately search in Australia and in the Internet in the past and could not find.
I am posting our results (Holger Boemanns and Me) to give you a option where to find it and i will share it.
To avoid dangerous technical problems,let the people do the work they understand the craft of engineering.
ls2lxhatch is right with the studs/bolts we use only high quality - minimum 12mm or 14mm wheelstuds at least.
Uwe
Edited by The German, 03 January 2011 - 05:48 PM.
#13 ls2lxhatch
  • 5,332 posts
Posted 03 January 2011 - 08:29 PM
The Hopper Stoppers front brake conversion kit has engineering approval and uses a similar style of hub. There is no problem getting the Hopper Stoppers hub passed as it is a similar design and material to many factory hubs.
The fundamental advantage of Uwe's hub over the Hopper Stoppers hub is that Uwe's hub is made from 7075 aluminium. As long as an engineer has approved the design and material there should be no problem with street use.
I expect the hubs will generate a great deal of interest amongst the circuit racers and people working on brake conversions. I think it is great that Uwe is going to make these available on his website with custom offsets and stud patterns.
Edited by ls2lxhatch, 03 January 2011 - 08:31 PM.
#14 The German
The German
  • 268 posts
  • Name:Uwe
  • Car:LH V8 1974
Posted 03 January 2011 - 09:27 PM
I had contact with Hoppers Stoppers a few month ago and did ask for a set of Hubs.
They only sell them in a complete brake kit not the hubs only.
Uwe
#15 _CHOPPER_
_CHOPPER_
Posted 03 January 2011 - 11:16 PM
I have known for at least 4 years of several places that sell aftermarkethubs to suit HR - HZ, LC - UC and VB - VP to suit various stud patterns and discs. Maybe not to the quality or price you are after, but they have been widely available for some time.
#16 _ls1lj_
_ls1lj_
Posted 07 January 2011 - 02:55 AM
Hi Uwe
Thanks for sharing your performance upgrades with us. How much for a set of alloy hubs + Freight? Do they use standard torana/early commodore bearings? And would they come with a material certificate (COC) for engineering purposes (you should get this from your material suplier anyway)?
I recently brought a set of conversion hubs off Mr Spares on ebay and they are bloody heavy and would be fine for light/mediuem truck use IMO. Other components would faillong beforethe hubs did.
Just to stir the pot, :stirpot: :stirpot: :stirpot: :stirpot: :stirpot: :stirpot::threadjacked: what is to stop the buget torana modifer from buying a new set of HQ/Torana/Early Commodore discs with integrated bearing/hub and just machining off the hat/disc section, leaving you with a conversion hub? They are already designed to take the load, but the load from the wheel would be 8mm? or so further offset once you fitted newer style commodore discs? Material thickness is comparable to aftermarket steel conversion hubs. :stirpot: :stirpot: :stirpot: :stirpot: :stirpot: :stirpot:
Ben
#17 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 07 January 2011 - 08:43 AM
Nothing at all....Posted Image
#18 _dirtbag_
_dirtbag_
Posted 07 January 2011 - 08:46 AM
That's a good point Ben.
Joshua, I agree on your concern for how the adaptors are being portrayed in this thread. I have used them on a number of cars and NEVER had any issues, as they were good quality, had good centre location and half inch studs. I'd be more worried about the thousands of cars out there that have wheels with no centre location and purely rely on the studs. That's much more dangerous than some adaptors, as long as they're good ones. Anyway, that's enough from me : )
#19 _ls1lj_
_ls1lj_
Posted 07 January 2011 - 12:12 PM
Nice work Litre 8, alot of nice shiny bits there. I can't easily see how the discs are attached - are they just a normal disc/hat section or a 2 piece like the DBA 5000 series discs or custom setup?
#20 ls2lxhatch
  • 5,332 posts
Posted 07 January 2011 - 02:05 PM
1. The studs always take the load on a Torana. It is not possible for the spigot to take the load as it is not a press fit. The sole purpose of the spigot is to help align the wheel to the axle before the nuts are tightened. Once the nuts are tightened there is an gap between the spigot and the hub. If the spigot was designed to take load then it would be a taper press fit.
2. Adaptors are not legal in Australia. If you are unlucky enough to have one fail your insurance company has the option of walking away.
One of the problems with using adaptors is that you have to align two things to the axle instead of one. A properly machined adaptor with a hub to locate on the spigot will only reduce alignment issues.
#21 _CHOPPER_
_CHOPPER_
Posted 07 January 2011 - 11:15 PM
ls2lxhatch said:
#1 The studs always take the load on a Torana.
#2 It is not possible for the spigot to take the load as it is not a press fit.
#3 The sole purpose of the spigot is to help align the wheel to the axle before the nuts are tightened.
#4 Once the nuts are tightened there is an gap between the spigot and the hub.
#5 If the spigot was designed to take load then it would be a taper press fit.
#1 The studs shouldn't take the load, they are primarily to secure the rim to the hub.
#2 Wrong, the hub IS designed to take the load and doesn't need to be a press fit to achieve that. Otherwise it would also make it hard to change the wheels.
#3 And to take the load.
#4 If there is, that would be due towear and tear over the last 30 - 40 years.
#5 See #2.
#22 _Bomber Watson_
Posted 08 January 2011 - 01:05 AM
Actually i've gotta say i agree with Andy on this one.
Ba dum da daaaaa (horror movie when all things go wrong type music)
Agree i was wrong earlyer, after thinking about it more i have seen plenty of factory wheels, even on new cars, with an air gap between the spigot and the wheel.
AFAIK once the wheel is secured to the hub with teh studs then the friction between the two is what secures the wheel.
Nuts tightened correctly the wheel and hub should become one....Like the Spice Girls song.
Edited by Bomber Watson, 08 January 2011 - 01:06 AM.
#23 76lxhatch
  • 7,199 posts
Posted 08 January 2011 - 07:00 AM
Exactly.
(dunno about the Spice Girls bit though... :P )
#24 rodomo
  • 18,030 posts
Posted 08 January 2011 - 08:26 AM
http://www.gmh-torana.com.au/forums/index.php?showtopic=13721
http://www.gmh-torana.com.au/forums/index.php?showtopic=47868
http://www.gmh-torana.com.au/forums/index.php?showtopic=16196
http://www.gmh-torana.com.au/forums/index.php?showtopic=15994&st=25
#25 The German
The German
  • 268 posts
  • Name:Uwe
  • Car:LH V8 1974
Posted 08 January 2011 - 07:39 PM
Data sheet of Aluminium EN AW 7075
7075 Datasheet
7075 Datasheet 2
