coil over suspension lh lx torana
_TUFF75LH355_
Posted 08 January 2011 - 08:49 PM
_TUFF75LH355_
Posted 09 January 2011 - 05:51 PM
_TUFF75LH355_
Posted 10 January 2011 - 05:19 PM
Posted 10 January 2011 - 08:13 PM
If you want to fit coil overs you need to fit a crossmember to mount them off.
Any combination of the two will require chassis work.
In my own car I moved the shock inboard and made new rails and tubs. I can fit a 275/60R15 drag radial with room to spare with a spring in the standard position.
Hope this helps.
_TUFF75LH355_
Posted 10 January 2011 - 08:45 PM
If you want to fit minitubs you need to move the rail from at least the spring platform rearward.
Hope this helps.
thanks for that struggler do you have any pics you could share cheers ben
Posted 10 January 2011 - 10:14 PM
They are still in development and untested... but you'll get the idea
Posted 10 January 2011 - 10:54 PM
Once you have moved the shocks out of the wheel tub you need to make a new upper mount point. The typical method is the crossmember you can see in the picture above.
This is another method but this section would usually also be removed when you fit mini tubs.
Marks Workshop
_Viper_
Posted 10 January 2011 - 11:29 PM
Posted 11 January 2011 - 07:45 AM
Hope this helps.
It's all in here Ben..... http://www.gmh-toran...showtopic=35451
_TUFF75LH355_
Posted 11 January 2011 - 05:52 PM
_TUFF75LH355_
Posted 11 January 2011 - 06:32 PM
_2wild4u_
Posted 16 January 2011 - 05:09 PM
and here are the bottom mounts i made up for the diff
Posted 17 January 2011 - 12:16 PM
What shocks and lb springs did you use?
_2wild4u_
Posted 18 January 2011 - 01:50 AM
Posted 18 January 2011 - 05:21 AM
Did you remove the bump stop/spring locater from the middle of the spring seat?
_2wild4u_
Posted 19 January 2011 - 01:16 AM
yeas they had to be cut out
Posted 19 January 2011 - 02:32 AM
Edited by ls2lxhatch, 19 January 2011 - 02:33 AM.
_2wild4u_
Posted 19 January 2011 - 11:22 PM
#21
Posted 19 January 2011 - 11:53 PM
#22
_2wild4u_
Posted 21 January 2011 - 12:15 AM
#23
_2wild4u_
Posted 21 January 2011 - 12:45 AM
#24
_2wild4u_
#25
_LE38OY_
Posted 06 September 2012 - 11:04 AM
basically i just had two discs laser cut, then welded the two mounting plates to each one, they then bolt through the old spring seat into the boot area, springs are king springs and are 150lb, and shocks are gaz,
Hi im new to modifying cars. Could you explain a bit more on how you mounted the coilover in the torana and do you have anymore pics.
Thanks Heaps
