Glass date codes?
#1 _sunburst73-xu1_
Posted 10 January 2011 - 07:15 PM
Was looking at some quarter windows today and had 2 different types,to faint to take pics but noticed little dots around the emblem.Been told that they stand for the date,is this true???
cheers Dane
#2 _73xu1_
Posted 10 January 2011 - 07:41 PM
i think it is true about the dots.
i tried to id all my windows awhile ago, every on the forums was helpful
but i did not really get a clear answer.
i hope some sort of thread could be made if its not to confusing.
cheers peter
#3 _sunburst73-xu1_
Posted 10 January 2011 - 07:47 PM
I will post up a copy on a piece of paper tomorrow of what I have and see if anyone can decode it.
cheers Dane
Posted 10 January 2011 - 07:59 PM
Posted 10 January 2011 - 08:20 PM
Hope this helps cheers Dave
#6 _BATHURST-32D_
Posted 11 January 2011 - 05:27 AM
cheers gong
Posted 11 January 2011 - 06:35 AM
#8 _sunburst73-xu1_
Posted 11 January 2011 - 06:04 PM
First glass reads
ARMOURGLASS Dot above the R
ASRI Dot below the S
APPROVED Dot below the second P
Second glass reads
ARMOURGLASS Dot above the M
ASRI Dot below the I
APPROVED Dot below the A
So if the Armourglass means the year and the asri means the quarter,whats the approved dot for??
Yel327 that would be very helpfull when you get time.
cheers Dane
Edited by sunburst73-xu1, 11 January 2011 - 06:09 PM.
Posted 22 January 2024 - 01:31 PM
This is one of the rear door windows from my 7-74 L34.
The word ARMOURGLAS has one S to make it a ten letter word so you have one for each decade. The dot over the O signifies 1974.
The dots under the first four letters of APPROVED signify the quarter of the year. Mine is second quarter.
The last 3 letters of ASRI are the months of the quarter, making mine May 1974.
Window May 1974 My L34.jpg 112.02K 6 downloads
It changed at some point and LX looks like this. Can someone decode it for us? (Antisun is the factory tint that makes it look green)
IMG_0513ss.jpg 104.8K 7 downloads
Posted 25 January 2024 - 08:11 PM
Photo of my 2/76 hatch rear window.
I guess a chance it was made Dec 75 like most other dates I have found on the car.
Posted 26 January 2024 - 08:15 AM
Pretty normal for parts industry supplied stuff (bulk of the cars - ie stuff that isn't body steel or cast parts). They were procured in bulk order contracts and supplied according to the production schedule hence why lots of stuff is made months prior to compliance. Sometimes bits will be just prior to compliance but normally 1-3 months.
Posted 26 January 2024 - 08:47 AM
So it seems like roughly the same system...
T O U G H E N E D equals the years 1 2 3 4 5 6 7 8 9 and I'd guess that no dot at all would equal zero?
Just unsure about the "Quarter" dot as the later glass abbreviates "APPROVED" to only three letters?
If Stuart's glass is December then maybe the first quarter is also represented by no dot at all?
BTW, do we know when exactly they switched suppliers from Armourglass to Pilkington?
Edited by Bigfella237, 26 January 2024 - 08:48 AM.
Posted 26 January 2024 - 02:15 PM
I agree with the years you have proposed Andrew (would like to see an example of no dot to be sure).
Could the year quarters be under the ASRI and the month under the APP, would make mine Dec 75?
Posted 26 January 2024 - 02:30 PM
T O U G H E N E D equals the years 1 2 3 4 5 6 7 8 9 and I'd guess that no dot at all would equal zero?BTW, do we know when exactly they switched suppliers from Armourglass to Pilkington?
AFAIK Armourglass and Armourfloat are both Pilkington brand names.
Posted 26 January 2024 - 02:42 PM
~ would like to see an example of no dot to be sure ~
1980 would have to come from one of the very last UCs or a very late HZ or early WB Holden.
Would Commodores have the same branding?
~ Could the year quarters be under the ASRI and the month under the APP, would make mine Dec 75?
You could well be right. Either way, yours would be Dec '75 so we'd need to see further examples (and also know what build dates the cars they come from were).
Okay, let me re-phrase my question...
When did the branding change? I assume there would've been a rough changeover date?
Edited by Bigfella237, 26 January 2024 - 02:49 PM.
Posted 01 February 2024 - 10:25 AM
The quarter and the month are swapped around on the Pilkington branded ones. APP is the month and ASR1 is the quarter. TOUGHENED is the years. I haven't worked out when the PILKINGTON brand appeared, but it is somewhere between 5-74 and 12-75.
ANTISUN only appeared on UC as far as I can make out.
Another clue to dates is that the Australian Standards changed from ASR1 to 2080 on the 1-1-77, however it may have taken some time to get online (or maybe GMH had large stocks) as the ex Seton GMP&A hatchback has ASR1 fitted. EDIT. I just noticed this car has ANTISUN glass.
Windscreen side window Seton GMPA.jpg 58.08K 1 downloads
This one. APP AS 2080 is dated 2-79. On the 5-10-95 it changed again to AS/NZ 2080 to reflect New Zealand coming into line with Australia.
Windscreen New type APP AS 2080. Feb 1979.jpg 34.53K 1 downloads
Edited by Shiney005, 01 February 2024 - 10:32 AM.
Posted 01 February 2024 - 10:46 AM
~ ANTISUN only appeared on UC as far as I can make out. ~ EDIT. I just noticed this car has ANTISUN glass.
I have a complete set of LX Hatch factory tinted glass somewhere in one of my sheds (no, it isn't for sale) and while I couldn't swear to it, I *think* it says "Antisun" as well?
Posted 01 February 2024 - 11:32 AM
