Am i using the right flares
18 replies to this topic
#1 LJGTR6
LJGTR6
  • 309 posts
  • Name:Steve
  • Car:1977 LX SL 4 Door and 1973 LJ 2 Door
Posted 09 February 2011 - 06:59 PM
I spoke with John Wilson today about getting a new set of flares from wilsons for my LX.
With him we worked out that i have a set of the smaller ones (L34 type i think i have seen them called).
He worked this out from my description of the small flare part that attaches to the door and the flat in the bottom.
My question is "have i used the correct flares back in the late 80's ??"
I had problems with damaging the rears as in pic 1 when reversing and getting the car twisted in a drive way and it caught on the tyre.
The fronts used to clip the part where it attaches to the front spoiler on one lock and rubbed on the back of the front on the other lock.
(saw a thread from ruts about trimming where the fronts attach to the spoiler to stop the tyre catching it)
did i just have crappy shocks and springs in the rear which allowed too much movement..
Or should i have used the bigger flares.
tyres are 14 inch rim with 265 / 50 rear and 14 inch 245 / 50 front.
The car looks good with these flares. not sure if bigger would look funny.
any experiences similar to mine would be really appreciated.
The fronts would clip the front and rear only on full lock
#2 _2wild4u_
_2wild4u_
Posted 10 February 2011 - 12:20 AM
i would of said they are the a9x ones???????????????????????
#3 LJGTR6
LJGTR6
  • 309 posts
  • Name:Steve
Posted 10 February 2011 - 05:06 AM
I thought so too.
I will take one side with me next week and he will compare it to his mold.
After reading a few threads i thought i had A9X until talking with wilsons.
His reason for saying they were small was the flat on the bottom of the rear door small piece??
#4 76lxhatch
  • 7,207 posts
Posted 10 February 2011 - 06:09 AM
The second pic down definitely shows the L34 type, with the bolt arrangement and the flat edge you are talking about.
If you can get a good fitting set they should be basically the same size but won't pinch in at the wrong spots, fixing your clearance issues. Worst comes to the worst you will need to slightly modify them when fitting to gain this clearance.
#5 _dirtbag_
_dirtbag_
Posted 10 February 2011 - 09:27 AM
They're definitely the L34 flares. The A9X ones come out at a much more aggressive angle making the top bolt hole recesses a lot deeper.
These are A9X flares.
Excuse the 3 pics I scanned them all in together ages ago, but it's the middle one I'm trying to show.
Hope that helps a bit.
#6 _Herne_
_Herne_
Posted 10 February 2011 - 11:01 AM
I agree, they look L34 to me and I have A9X on mine.
If given the choice again I would go L34 style because you can get away with a slightly smaller tyre/rim than 10" (265 or larger) and still fill the flare with meat and have it looking good and more street legal.
Herne
Edited by Herne, 10 February 2011 - 11:02 AM.
#7 Ruts
Ruts
    How Fast!?
  • 1,118 posts
  • Car:Blown A9X replica, Black SS hatchback, LH SLR5000
Posted 10 February 2011 - 12:20 PM
What you have are L34 flares with crappy shocks and springs. I see you are at Menangle which is about 15 minutes from my place. Give me a call if you like and I can come and have a look for you.
Ruts
#8 LJGTR6
LJGTR6
  • 309 posts
  • Name:Steve
Posted 10 February 2011 - 05:41 PM
Ruts
Thanks Guys seems they are L34.
I might take you up on that Ruts. I would value 5 minutes to see how close i got them that many years ago.
I'l PM you.
Thanks again to all. really helps out.
#9 _2wild4u_
_2wild4u_
Posted 10 February 2011 - 06:54 PM
so mine are definately l34 ones arent they??
as i want the larger a9x ones but i dont want to redrill holes?????/
#10 _Herne_
_Herne_
Posted 10 February 2011 - 07:08 PM
I cant tell from that angle mate but someone may.
Yes the holes are different and it means taking on a fiddly job to re set the new ones, thats why I have not yet changed mine to L34 and it's a very low priority job which may or may not get done at all :)
Herne
#11 _Yella SLuR_
_Yella SLuR_
Posted 10 February 2011 - 09:18 PM
^ As well as the springs and shocks, Eagers have a fairly wide track width. Mine used to touch every so slighlty. I've now chage to Yokohama's and no touches. It is magic.
Definitely L34 type flares that you have.
WILD4U, you need a pic showing front and rear, so you can compare the angle at the top of the flare. If front and back similar, L34, if wildly different, like Dirtbag's pic, then A9X.
#12 MRLXSS
  • 12,414 posts
Posted 10 February 2011 - 09:28 PM
Hatchback flares should all be A9X, but I swear the A9X flares I have seen on Sedans look heaps wider than Hatchback flares.
#13 _Yella SLuR_
_Yella SLuR_
Posted 10 February 2011 - 09:49 PM
^ Good question. I've never seen an A9X four door flare next to a hatch flare. Never even compared front to back flare on a hatch!!!
#14 76lxhatch
  • 7,207 posts
Posted 11 February 2011 - 04:59 AM
There are a lot of hatches around with the wrong flares, they seem to be L34 style joined together into one piece. If I recall correctly the A9X hatch rear flares should be add around 70mm off the body
#15 LJGTR6
LJGTR6
  • 309 posts
  • Name:Steve
Posted 11 February 2011 - 03:18 PM
Holey smoke how did you get that wheel so far up inside the flare?
That looks cool. If i had done that i could say good bye to the flare at the
first bump in the road.
I think good springs and shocks are in order for mine.
They definetly look the same as mine though.
the rear ones in dirtbags barbados green pics definetly arch out more.
That being said the fronts look the same in all the pics to me.
#16 _Herne_
_Herne_
Posted 11 February 2011 - 04:00 PM
Thats correct fronts are the same on the 4 doors ie L34, never compared the hatches though. However I believe the hatches front are also L34?
Herne
#17 _2wild4u_
_2wild4u_
Posted 11 February 2011 - 11:38 PM
heres a side pic showing the flares
i run coil over shocks in the rear, theyre a 10 wide rim, and they fit perfectly
#18 _Quagmire_
_Quagmire_
Posted 12 February 2011 - 03:43 AM
helps to work in a suspension store lol
be up there soon buying bits/getting bits fitted soon cuz
al
#19 _2wild4u_
_2wild4u_
Posted 12 February 2011 - 11:48 AM
true true
