Firstly, this is what I have got- My inlet manifold is the in-correct one, I know what i need but after a lot of searching i still couldnt find the correct one (need#9929854) so im using one that I hope will do the job,(i dont really know but it had the similar ports) its number is 2823087
My carbie is a rochester quaddie # 7045281 with the numbers underneath those of 3425. I know this suits a LH slr5000 manual, but I have no idea if this is the correct one for the LX.
So..
1. Looking at the 1st photo, is my intended heater hose routing correct? The longer hose from the front of the engine is going to the bottom pipe in the firewall and the shorter to go to the top.
Ive had to cobble these up because of unavailabilty of new items (yet)
2. Looking at the second photos, is my carbie the correct one?
On the non-standard set up, the carbie was sitting on a wooden spacer plate, ive taken it off(correct?)
Is this where My front driver side vent pipe goes to? (pipe from rocker)
Where does the passenger side vent got to? (the rear rocker one)
And where does this go? Does it go to the cannister ( if so which port) or is it blocked off?
Can you buy new /2nd hand vent fittings? (go into the rocker cover)
I know this is a lot of information to ask and any info or comments (if you see anything else incorrect please let me know!!) would be greatly appreciated. Thanks.
![Posted Image](https://cache.gmh-torana.com.au/i296.photobucket.com/albums/mm180/Drfegg/IMG_3421.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i296.photobucket.com/albums/mm180/Drfegg/IMG_3425QUESTIONS.jpg)
