thanks
Posted 02 April 2011 - 10:10 AM
Posted 02 April 2011 - 02:28 PM
Posted 02 April 2011 - 02:58 PM
Hi Brendan
AFAIK nobody makes a replacement bush.
How bad is the wear, like how much slop do you reckon there is between the bush and the shaft??
Dave
Posted 02 April 2011 - 03:01 PM
Hi Brendan
Dave
its faily floged out, 1mm or more i guessing?
if its the same shaft as the LX/LH toranas i can replace it with bearing 6205-2RS-1. this is a 1inch bore fitting on the shaft and a 52mm outershell.
Posted 02 April 2011 - 03:05 PM
Posted 02 April 2011 - 03:16 PM
Posted 02 April 2011 - 03:34 PM
Posted 02 April 2011 - 03:35 PM
Go to a bearing shop and ask for a case roller bearing with the same inner and outer diameter, a hose clamp should hold it or glue it in place with appropriate glue.
Posted 02 April 2011 - 03:39 PM
A roller bearing would need to be less than .770" ID to be a snug fit on the steering shaft.
Posted 02 April 2011 - 03:44 PM
Posted 02 April 2011 - 03:45 PM
I would use acetal rather than nylon.
Harder and self lubricating but very nice to machine.
So the LC's don't use a roller bearing? just this plastic bush?
Edited by brendan_h, 02 April 2011 - 03:50 PM.
Posted 02 April 2011 - 08:21 PM
there wouldnt be a problem using nylon though would there? what about brass, even aluminium?
cant imagin LC having a roller bearing and LJ have a bush.
anyone got a rought idea on cost to machine this up?
Posted 02 April 2011 - 09:04 PM
Posted 02 April 2011 - 11:06 PM
Going to get one made up from nylone on monday. Anyone confirm the dimentions it needs to be
Posted 03 April 2011 - 11:09 AM
Posted 10 April 2011 - 10:16 AM
Posted 13 April 2011 - 03:52 PM
Posted 13 April 2011 - 05:19 PM
Posted 13 April 2011 - 06:00 PM
what is the difference between a column shift and floor shift bearing? are they interchangable?
Posted 21 November 2011 - 01:07 PM
Posted 21 November 2011 - 06:01 PM
Posted 11 February 2013 - 10:54 PM
