Anyone keen on fabricating this
29 replies to this topic
#1 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 28 May 2011 - 09:30 PM
Those with the Muncie transmissions originally from LHD Chev vehicles e.g. M22 Rockcrusher will find that the standard range of Hurst shifters just don't suit.
I've worked out the correct dimensions for relocating the shift knob to suit RHD Torana LH/LX. Details below. I'm probably going to send it to a workshop but If anyone on here is capable and interested in a little extra cash please PM me.
See the attached pictures (White background available on request):
PERSPECTIVE (From driver's seat, perhaps)
Attached File  m22_torana_shifter_pers1_inv.jpg   45.18K   10 downloads
TOP
Attached File  m22_torana_shifter_top_inv.jpg   24.46K   5 downloads
REAR (From behind shifter, looking towards front of vehicle)
Attached File  m22_torana_shifter_rear_inv.jpg   49.02K   7 downloads
SIDE (Driver's view / Right hand side view)
Attached File  m22_torana_shifter_side_inv.jpg   42.88K   5 downloads
I think the easiest way to manufacture it would be to grab a ~360mm length of 24mm x 7mm bar, carefully make the two bends, drill a hole down the central axis in one end, insert and weld-in a stub of 3/8"-16 threaded rod into that hole to provide a 20mm section, grind back a taper, then drill the mounting holes at the bottom. I'm thinking mild steel that I can then paint black or chrome. Aluminium would be awesome but 6000 series would probably be too expensive or unable to be worked to such a angle.
#2 _Liam_
_Liam_
Posted 28 May 2011 - 09:43 PM
I may be seeing this wrong, but do you have the flat sides facing the doors or the dash? One view looks like it, and the other looks the other.
Never mind I see the perspective now.
#3 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 28 May 2011 - 09:54 PM
No worries it's not easy to pick out. Basically from the top hole in the Hurst gate, the shifter knob comes 100mm back, 160mm towards the driver and up 190mm, with the shaft at the knob angled 15 degrees towards the right, if that makes sense.
#4 _Liam_
_Liam_
Posted 28 May 2011 - 10:22 PM
Yep perfect sense, I would help you if I had an Oxy, used to love doing metal work in high school.
#5 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 05 June 2011 - 11:43 AM
No takers? Looks like I'll send it to a workshop then.
#6 Heath
  • 18,394 posts
Posted 05 June 2011 - 12:46 PM
If I was more settled in at my current job I'd probably do it, but kinda poor timing. Hope someone gives you a good product.
#7 _redrana_
_redrana_
Posted 10 July 2011 - 03:41 PM
Hi was this shift lever ever made and available for purchase? Or does anyone know another option to get the shift lever back over toward the driver with a muncie in an LH torana that can be bought? thanks!!
Edited by redrana, 10 July 2011 - 03:42 PM.
#8 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 10 July 2011 - 04:55 PM
I still haven't sent this to a fabricator yet - should I get a couple made up?!
#9 _rocket_
_rocket_
Posted 10 July 2011 - 06:14 PM
Hurst made a shifter in the day for the Toranas, I have the part number somewhere, Ill find it over the next few days and put it on here.
Maybe ask Shaun with the Forbes/Bartlett hatch, he will know for sure.
#10 _rocket_
_rocket_
Posted 24 July 2011 - 09:48 AM
I found the pic, but cant find the part number.
#11 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 24 July 2011 - 04:08 PM
I couldn't see it here:
http://www.hurst-shifters.com/s.nl/c.723089/sc.26/category.7326/.f
Thanks for the follow up but that looks about 6 inches higher than I'd like.
Meanwhile, I think I've worked out a cheaper/easier way of manufacturing it using 12mm rod:
Attached File  m22_torana_shifter_Rev2_pers1.jpg   111.18K   3 downloads
Still no luck with fabricators showing any interest in WA
#12 _hutch_
_hutch_
Posted 24 July 2011 - 04:18 PM
I
think if you made it out of mild it would bend fairly easy,think ya might need a peice of spring steel
Phillip
#13 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 25 July 2011 - 12:27 PM
http://www.hurst-shi...ategory.7326/.f
Hi there man i'am in brisbane and would be willing to give it a go for you if you are still interested.???
pm me if you are
#14 AbsynthHatch
AbsynthHatch
  • 738 posts
  • Name:Mark
Posted 25 July 2011 - 01:18 PM
I would be keen on purchasing one of these if anyone wants to make a few dollars
I have a hurst shifter in mine but the actual gear lever is very short and you need arms like Swartzanegger if you spend any considerable time changing quickly through the gears plus i'm not real happy with the mods I have currently made
I presume those measurements put the gear stick back into the original location so you can use a console?
#15 myss427
myss427
  • 1,636 posts
Posted 25 July 2011 - 02:11 PM
I'm going about it a totaly different way, currently relocating the shifter from the side of the T10 to over the top of the box like a depress shifter. Bought one of the hurst speedway billet shifters which have the shift linkage levers to the far left. That way if you move the shifter to the right it stops the shift linkages fowling the side of the box and you end up with the shifter centrally located and you have not changed shift geometry. Still have a bit to do, will post a pic when I know it works.
Edited by myss427, 25 July 2011 - 02:11 PM.
#16 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 27 July 2011 - 07:42 PM
made up one today here is a photo. made to the mesurments supplyed as close as possible within 2mm
#17 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 27 July 2011 - 07:59 PM
side on. you didn't give any mesurments for the horazontal section so i made it with 90deg bends.
Made out of high strenthe flat bar 300+ grade so it's very strong and has next to no flex unless you
lean on it hard as you can, and i weigh 110kgs and it only bend about 2mm
#18 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 27 July 2011 - 10:09 PM
Looks good!! Will try your number tomorrow.
#19 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 27 July 2011 - 10:13 PM
No, my experience is that the full LH console fouls on the base of the Hurst shifter when going for reverse. Moving the entire shifter block centrally as myss427 describes would be the better way (but requires more effort).
#20 AbsynthHatch
AbsynthHatch
  • 738 posts
  • Name:Mark
Posted 27 July 2011 - 11:56 PM
I've got an LX Hatch and yeh the hurst shifter does foul on the left hand side of the console by about 15-20mm
But the previous owner 'relieved' part of the console so it would all fit, then proceded to make a dodgey adapter out of a piece of box section, washes and long bolts
Something that was both sturdy and cosmetically appealing, such as above would be nice.
#21 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 29 July 2011 - 05:35 PM
I have made one and sent it to lima31 in WA. i will wait for his feed back and if anything needs to be changed.
Then if anyone wants one i will make them one aswell
#22 AbsynthHatch
AbsynthHatch
  • 738 posts
  • Name:Mark
Posted 29 July 2011 - 05:54 PM
Thats very generous Dave thanks for your willingness to help out
#23 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 29 July 2011 - 11:39 PM
i didn't realy do it for the money but i never say no to $$$$ thanks Lee i hope it's 100% correct if not let me know and i can make some changers to it for you.
#24 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 04 August 2011 - 08:24 PM
Just an update that I've received the shifter and it fits like a charm.
The thread on the top was just right, the shifter pattern on the shifter knob lines up when fully tightened.
I think for those with longer arms than average might want to move the shift point say 25mm forward, and heavier guys might want to move it 25mm back towards the centre of the car, but for me at 5'10" its spot on.
Top work Dave!
I've added some pics of it installed, I just need some floor panel work and to fit a shift boot.
Attached File  DSC_0197.jpg   72.88K   8 downloads
Attached File  DSC_0198.jpg   75.11K   3 downloads
Attached File  DSC_0195.jpg   73.19K   4 downloads
Edited by Lima31, 04 August 2011 - 08:25 PM.
#25 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 04 August 2011 - 09:38 PM
Thanks for the feed back Lee.
If anyone is interested in one let me know and i will let you know how much.
