Mech Fuel Pump Vs Elec Fuel Pump
17 replies to this topic
#1 hanra
  • 10,953 posts
Posted 03 June 2011 - 12:57 PM
Whilst I have all the wiring loom out of my L31 SL/R Im wondering if I should install wiring/relay for an electric fuel pump? How do the mech fuel pumps go in terms of reliability, flow and pressure compared with a elec pump these days?
#2 _fatlh5000_
_fatlh5000_
Posted 03 June 2011 - 01:04 PM
Hanra,
I spoke to Burwood Carburettor(Sydney) a while ago, who are reputable, and have been around for deacdes.
I was having a few issues with my 327 chev running a bit rich. Tim from Burwood carburettor asked some specs of my car, and when I told him that I had a Holley Blue pump fitted to my mild 327, he was quite suprised.
His oppinion was for a stockish engine, fun on the street that the mechanical fuel pump is the way to go.
Also- the holley Blue is quite noisy.
#3 MRLXSS
  • 12,403 posts
Posted 03 June 2011 - 01:07 PM
What Carby are you running?
I had a good chat with my engine builder about my new engine... He said that if I wanted to run my old Quaddy, I could... But would need a Elec fuel pump to supply it... But if I ran a Holley with the bigger fuel bowls... The Hi-Volume Mechanical Pump should be up to the job no problems...
I chose to get a bigger carby to stay with the mechanical pump.
#4 _Big T_
_Big T_
Posted 03 June 2011 - 02:13 PM
Is there an easy way to tell what sort of pump is on a 308? As in, how would one identify a Hi Vol pump as opposed to a standard one?
#5 hanra
  • 10,953 posts
Posted 03 June 2011 - 03:10 PM
Im currently running a 650DP spreadbore, and dont intend to go any bigger then that. I guess the opinion is to stay with a mech pump. I might just run the wiring to the rear of the car anyways. Just in case......
#6 76lxhatch
  • 7,204 posts
Posted 03 June 2011 - 05:15 PM
With the Holley the mechanical pump should be fine, the poor old Quadrajet is great in many respects but not blessed with a large fuel bowl so needs a pump that can keep up under full acceleration hence the electric pumps many use
#7 _RTS Guy_
_RTS Guy_
Posted 03 June 2011 - 05:28 PM
spot on
#8 _Mint_
_Mint_
Posted 03 June 2011 - 11:14 PM
err no..that is if its the original holden rebuildable type..you can buy kits for em both standard(4psi) and hi pressure(7psi) the difference is the spring
the after market sealed type pump is not rebuildable ie: throw away
#9 mr5000
mr5000
    chief break-everything
  • 3,455 posts
  • Car:77 lx 4door
Posted 04 June 2011 - 08:19 AM
i got A ac delco hi vol fuel pump from rarespares for around 80- bucks give that a go
#10 _darrenmark1_
_darrenmark1_
Posted 04 June 2011 - 10:39 AM
i bought something like this shiney one, altho the chrome on mine is much better, then got a kit and re built it, cheap enough works great.
http://www.ebay.com....=item33680d6b3b
#11 _chrome yella_
_chrome yella_
Posted 04 June 2011 - 12:07 PM
mech pumps are safer, if the engine stops so does the fuel, in an accident such as you are unable to turn the ignition off, the electric pump will keep pressure up.
i have a clay smith hi volume mech pump for my s/b chev and its capable of feeding 1300hp. so there are some great mech pumps out there
#12 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 04 June 2011 - 12:44 PM
I would fit an electric unit with a oil pressure safety switch - for security as you could run an independent hidden switch just for the pump. Whilst the engine can start without the pump running, it usually dies in the time it gets on the road, and from the stories I've heard once they are in a public space without a running car and considering how long it might take to diagnose no fuel and power the pump, they usually bail.
#13 _Mint_
_Mint_
Posted 04 June 2011 - 02:03 PM
i have thought about fitting a electric pump to my ss hatch which is soon to have a new 308 in it..but as we probly all know theres bugga all room near the tank with full exhaust standard tank etc
i dont want to cut holes in the floor or mount it in the boot area..so will use the mech hi pressure one i have
have seen the CARTER electric silver series looks quiet small sized an they have a good rep..so may look at fitting that at some stage unless someone else has a betta idea
#14 EunUCh
EunUCh
  • 2,769 posts
  • Car:japos
Posted 04 June 2011 - 07:42 PM
did Mr.P.Brock use an electric pump on the ones he raced? Maybe convert it to alcohol that needs round about 2-2.5 times more fuel and pour vodka in the tank
premium of course?
#15 _LH SLR 3300_
_LH SLR 3300_
Posted 07 June 2011 - 04:51 PM
My 304 has a mechanical pump fitted but it was fed fuel through a Holley Blue regulator. I thought this was unusual & then someone pointed out that the aftermarket throw away type mech pumps can fluctuate pressure up to 10psi causing overfueling so the regulator is a safeguard to maintain constant even pressure. Anyone else come across this?
#16 76lxhatch
  • 7,204 posts
Posted 07 June 2011 - 05:25 PM
I doubt the mechanical pump can deliver much more than 10psi all up...? It would have to fluctuate due to the nature of the mechanical pump operation, a regulator would limit the maximum (only an issue if its lifting the needle off the seat) but I can't see how it would even it out much. The carb fuel bowl should provide constant fuel delivery regardless of how it is filled (within reason).
#17 _Mint_
_Mint_
Posted 07 June 2011 - 07:09 PM
this is exactly what i did..i have the reg right next to the carb..one outlet to rear bowl an one to the front..mainly to even the flow and pressure to both fuel bowls..and i have a hi pressure original mech pump
#18 rodomo
  • 18,034 posts
Posted 07 June 2011 - 08:24 PM
Or a LPG safety switch.
