I purchased it about 5-6 years ago it had a healthy offset stroked 308 in it that dynoed at 304rwhp, toploader gearbox & the obligatory 9" & had run a 12.2@116mph on street tyres.
I have not had it regoed, so it has just been sitting around in sheds, i dragged it out for the NQ PRO Burnout comp last year, i was stopped by an electrical problem.................... the dizzy stopped turning due to the camshaft being smash into pieces by the conrod that broke in half after it seized to the crank from the lack of oil.
![Posted Image](https://cache.gmh-torana.com.au/i781.photobucket.com/albums/yy100/fugly2/Torana006.jpg)
So that left me needing a new engine & i have decided to go LS.
After much deliberation i have also decided to drop the toploader & go T400.
Where i am at so far -
A mate had bought a set of CAE part# CH-EM70 mounts
![Posted Image](https://cache.gmh-torana.com.au/i781.photobucket.com/albums/yy100/fugly2/LS1inToranaCAECH-EM70.jpg)
which i borrowed to dummy a LS2 in place, the block rested on the firewall lip on the RH side, i have since found out that that lip has to be cut off to allow the motor to fit on these mounts, the plastic heater demister cover would have to be modified as well to run these mounts.
I looked at these mounts as well but they look like they will sit the motor in the same poition as the CAE mounts.
![Posted Image](https://cache.gmh-torana.com.au/i781.photobucket.com/albums/yy100/fugly2/LS1inToranaVelocityTUFFMOUNTS.jpg)
I bought a set of CRS part# EM105 engine mount adapters, these sit the motor approx 10mm lower & 20-25mm further forward,
![Posted Image](https://cache.gmh-torana.com.au/i781.photobucket.com/albums/yy100/fugly2/LS1inToranaCRSEM105.jpg)
so now i could bolt the dummy T400 to the back of the block, mind you the T400 into LH gearbox cross member i bought off CRS goes nowhere near fitting, the mount is about 3" to far forward, still talking to CRS to try & sort this out, anyone had this problem before???????????
![Posted Image](https://cache.gmh-torana.com.au/i781.photobucket.com/albums/yy100/fugly2/LSintoTorana008.jpg)
Some things i have to sort out that hopefully the guy's who have done the LS conversion before will be able to help with.
I have read that some guy's have used the MSD Starter part # 5096, Is it that much smaller than the factory Starters or was the main reason because of the solenoid?
With the VE starter solenoid standing up at 12 o'clock would it still be an advantage to use the MSD starter?
Which sump & engine mount combo did you use & was any mods required to make it fit?
I am looking at either the Milodon part#30915 or part#30916 or the Moroso part# 20140, most conversions seem to be using the Moroso pan but it looks to me like the Milodon would fit better with the CRS mounts?
![Posted Image](https://cache.gmh-torana.com.au/i781.photobucket.com/albums/yy100/fugly2/MIL-30915.jpg)
Or
![Posted Image](https://cache.gmh-torana.com.au/i781.photobucket.com/albums/yy100/fugly2/mor-20140_w.jpg)
That will have to do for now
If you can share any details that would be very much apprieciated.
Cheers Brenton.
