Rear Brakes
23 replies to this topic
#1 hanra
  • 10,931 posts
Posted 26 July 2011 - 10:57 PM
I cracked the drivers side hand brake lever arm when removing the handbrake cable.... So Ive since bought two off ebay both claim to suit LH Torana's....
My old lever is on the RHS... Clearly either something funny is up with my brakes, or Ive been sent the wrong lever arm again???? Please help.
#2 hanra
  • 10,931 posts
Posted 27 July 2011 - 10:08 AM
Can any one identify the lever on the left???
#3 ReplicarSLR
ReplicarSLR
  • 518 posts
  • Car:Not anymore unfortunately
Posted 27 July 2011 - 10:13 AM
Left hand one might be from a H/T/K or HQ to HZ etc as they had larger diameter rear drum brakes than LH/LX. Datto will be able to confirm.
#4 hanra
  • 10,931 posts
Posted 27 July 2011 - 09:07 PM
Yeah I think its from a drum/drum HQ...
#5 hanra
  • 10,931 posts
Posted 28 July 2011 - 03:00 PM
I must ask some silly questions?
#6 AbsynthHatch
AbsynthHatch
  • 736 posts
  • Name:Mark
Posted 28 July 2011 - 03:32 PM
I gave away all my drum brake bits and pieces to a mates brother about a month ago Brad but the one on the left looks like the one that came off my LX
The one on the right definately from a V8 rear and not a 6 cyclinder or from a drum brake front end?
#7 hanra
  • 10,931 posts
Posted 28 July 2011 - 05:51 PM
Well this diff/brakes is a bit of an unknown.....? Its the only part of the car not powder coated. So I reckon its been swapped out at some stage of its life... brakes included.......
#8 hanra
  • 10,931 posts
Posted 29 July 2011 - 07:35 AM
Well can anyone answer this question:
Were the drum brake components all the same across the model line up of 4/6/8 cylinders with banjo diffs?
#9 76lxhatch
  • 7,201 posts
Posted 29 July 2011 - 08:07 AM
Yes. The larger one being HQ or HK makes the most sense.
#10 hanra
  • 10,931 posts
Posted 29 July 2011 - 10:12 AM
If any one has there rear brake components in pieces could some one please measure the hand brake lever arm please? Id like to confirm if I indeed have the incorrect brake components with the car or have I been supplied with the incorrect hand brake lever?
Im thinking perhaps the entire rear end is out of something non-Torana?
This is from the GM Torana Part book. The shape of this arm does look more like the arm on the left in my pic??????
#11 S pack
  • 15,684 posts
Posted 29 July 2011 - 02:42 PM
Hi Hanra
The lever on the left is the same in length and 99% identical to a NOS LC/LJ 6cyl lever I have. As the LC/LJ/LH had 13" rims it is probably reasonable to assume they had the same or similar 9" rear drum brakes.
#12 hanra
  • 10,931 posts
Posted 29 July 2011 - 02:51 PM
Thanks for that mate. So it leaves me to wonder what the lever on the right is from???
#13 EunUCh
EunUCh
  • 2,769 posts
  • Car:japos
Posted 29 July 2011 - 07:20 PM
The one i measured off a duo servo type rear brake setup measured 155 from centre of pin to centre of cable clamp
bit on bottom.
#14 S pack
  • 15,684 posts
Posted 29 July 2011 - 07:44 PM
Don't quote me on this but I have a suspicion the handbrake levers on your brakes could be from an earlier model Holden. Maybe HR or earlier?
#15 hanra
  • 10,931 posts
Posted 29 July 2011 - 08:30 PM
I just noticed that the part circled below was not present in either side of my brakes when I stripped them....
#16 LXM21
LXM21
  • 450 posts
Posted 29 July 2011 - 10:14 PM
Parts circled is the auto adjusting mechanism. Tend to be missing on many cars.
#17 hanra
  • 10,931 posts
Posted 08 August 2011 - 10:01 PM
My rear brakes are still a bit of a mystery... Im not sure where my rear end is from...? These are the bits that Ive got... Does this look Torana?
And what the parts book says I should have......
#18 dattoman
  • 16,486 posts
Posted 08 August 2011 - 10:06 PM
Are the shoes Torana ones ?
9" diameter... 3/4" wheel cylinders ?
#19 hanra
  • 10,931 posts
Posted 08 August 2011 - 10:49 PM
The brake drum is 9in, Ive turfed the wheel cyls without checking.. The shoes went to the tip to....
#20 hanra
  • 10,931 posts
Posted 08 August 2011 - 11:10 PM
This is how it looked fitted to the car,
#21 dattoman
  • 16,486 posts
Posted 09 August 2011 - 12:16 AM
Plain old Torana shit
With the self adjusters turfed cause someone was too lazy to put them back on or didn't know how
Very thick linings
Drums are likely to be rooted
#22 hanra
  • 10,931 posts
Posted 09 August 2011 - 06:30 AM
Your a wealth of knowledge mate! Thanks.
Is it going to be an issue with the self adjusters missing? Should I try and source some?
I had the drums machined already. The brake shop didnt say anything bad about them?
So I wonder why my handbrake lever is a weird one if this is all Torana?
#23 76lxhatch
  • 7,201 posts
Posted 09 August 2011 - 09:00 AM
Not an issue as such, but it will be nicer to have them - in my experience Toranas are best with the rear brakes adjusted up tight
#24 hanra
  • 10,931 posts
Posted 09 August 2011 - 10:12 AM
Hmmm, more parts to put on the Wanted To Buy List.
