Home made extractors
46 replies to this topic
#1 ACJ
ACJ
  • 197 posts
  • Name:adam
  • Car:LH
Posted 12 August 2011 - 12:01 AM
I started to make my extractors. First up was the collector.
I cut all 4 pipes at 12 degrees. Then rotated the pipe 90 degrees and made another 12 degrees cut. Placed all 4 pipes together and welded them.
Welded a plate to the bottom of the collector, filled with sand and welded 4 nuts to the top then put the bolts in to hold presser on the sand. Heated and bent them.
End result is a mega collector with 12 degrees convergent angle and mandrel bends. Still in a ruff state but will clean up OK
Hope some one like it
Thanks.
#2 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 12 August 2011 - 07:18 AM
Nice work !
#3 _nial8r_
_nial8r_
Posted 12 August 2011 - 08:59 AM
they look the goods so far, cant wait to see some more pic's
#4 _Viper_
_Viper_
Posted 12 August 2011 - 09:10 AM
Thats awesome man.
Just wondering what you made the cuts with and how did you work out the angles and stuff?
I'm going to be making some extractors soon too what thickness pipe did you use and where did you get it?
Are u going to buy off the shelf mandrel bends or will you be making the bends yourself?
#5 _Quagmire_
_Quagmire_
Posted 12 August 2011 - 11:22 AM
you can do your own if your keen
http://www.youtube.c...CA0630749CF11D4
#6 ACJ
ACJ
  • 197 posts
  • Name:adam
  • Car:LH
Posted 13 August 2011 - 09:36 PM
This is my very expensive collector jig. Its not even my drop sew. The plat bolts to the drop saw, the 2 rings are welded on at 12 degrees to the blade. The other ring fits over the tube and has 2 stopper (bolts welded on) set at 90 degrees.
Do one cut then rotate the pipe 90 degrees (to the other stopper). This is not exhaust pipe tube just some old pipe I had.
This is what it should look like.
Finniest off other collector today.
I got my tubing from midalia steel 1 � 6 meters long, 1.6mm thick for $39
My next plan is to cut black poly pipe to the length I need for the primaries. Heat and bend them for templates. I have mandrel bends only for the first bend out of the head. So I will sand bend the rest of the primaries.
#7 _Viper_
_Viper_
Posted 13 August 2011 - 09:50 PM
Good stuff man, I might use the method for making my Turbo exhaust manifold collectors
#8 rodomo
  • 18,070 posts
Posted 13 August 2011 - 09:55 PM
Sum off yoose blokes r just a bit 2 cleva :spoton:
#9 _bunkerjest_
_bunkerjest_
Posted 14 August 2011 - 07:10 PM
why do u fill the pipes with sand???
#10 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 14 August 2011 - 07:36 PM
That is what everyone did before they invented mandrel bending.
It stops the pipe collapsing while you heat and bend it.
#11 ACJ
ACJ
  • 197 posts
  • Name:adam
  • Car:LH
Posted 14 August 2011 - 09:08 PM
Yeas it minimizes distortion to the pipe. A good sand bend will look just like a mandrel bend.
Also bangs for bucks for me. I bought 10 mandrel bends (off eBay $80) and 2x1 � 6 meters lengths of pipe for $78. A total of $158 for hand made tuned length extractors. I will also make 2 more collectors, 1 short set and 1 long set all with swaged end to slip onto the primary pipe. As I no my tuned length is between 29 and 32 inches long, I can change the length when my engine goes on the dyno to fine out the right length and get the best out of it all.
If it all goes good I think I will also get them ceramic coated (about $350 I think) so for $500 I will have ceramic coated dyno tune extractors for my eng combo, I think that�s good value.
Any thoughts or criticism much appreciated.
Thanks all
#12 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 14 August 2011 - 09:41 PM
Lovin your work and following with interest.
#13 _Woodsy_
_Woodsy_
Posted 14 August 2011 - 11:23 PM
Awesome work
#14 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 29 August 2011 - 08:10 PM
http://www.jalopyjou...d.php?p=3686748
#15 _Inj gtr202_
_Inj gtr202_
Posted 02 September 2011 - 09:13 AM
Cheers for posting this up.
Nice work!!!
I am considering making a set for the 6 banger, keep posting your methods please. Picking up a few good tricks off ya. :P
Adam
#16 _oldjohnno_
_oldjohnno_
Posted 02 September 2011 - 05:16 PM
Mate this is great stuff. And I'm not just talking about your pipework either - the photos and story are beautifully clear and will be absolutely invaluable to anyone else wanting to do similar work.
#17 Steve TPF
Steve TPF
  • 784 posts
  • Name:Steve
  • Location:Adelaide... city of... anyone know something good about it?
  • Car:UC hatch
Posted 02 September 2011 - 05:57 PM
They sure will. I'd like to add - nice welding! I always love to see someone's DIY photos, shows what's possible with a bit of know-how and a lot of elbow grease.
#18 RBTORY
RBTORY
  • 133 posts
  • Car:lj 2 door / RB30ET
Posted 16 September 2011 - 12:37 AM
Nice work, allways better to have a go
Edited by RBTORY, 16 September 2011 - 12:43 AM.
#19 RBTORY
RBTORY
  • 133 posts
Posted 16 September 2011 - 12:43 AM
sand bending is a dying art
Edited by RBTORY, 16 September 2011 - 12:46 AM.
#20 _markymark20_
_markymark20_
Posted 22 September 2011 - 08:05 PM
what sort of sand do you use, does it matter?? Like everyone else, "love your work!!!"
#21 ACJ
ACJ
  • 197 posts
  • Name:adam
  • Car:LH
Posted 22 September 2011 - 10:41 PM
Thanks for all the good comments
Yes, sand bending is just about dead. But why ? for me it is much easier to get a very smooth and good flowing pipe with sand than cutting and welding.
Yes, there is a special sand I think its only fond deep in the Amazon jungle ? But a old timer that is very good with sand bending said yellow brickys sand is the next best thing. More important is that it is very dry �VERY DRY� I sit it on top of the potbelly stove for 24 hour or in the welding rod stove a work for 24 hour just to be sure.
If you are doing a long bend you may have to stop and tap the pipe some more to tighten the sand then tighten the end caps some more. Heat up a good 2 or 3 inches of pipe cheery red more on the out side of the bend. Bend slowly if it start to wrinkle on the in side edge try more sand pressure or more heat on the out side edge.
Have fun.
#22 _TorYoda_
_TorYoda_
Posted 24 September 2011 - 12:53 AM
I make these at work using a similar principle for cutting, however we bend the pipes in the Mandrel bender first. Very Nice MIG weld there ACJ. That takes some skill and a well set up machine. I have done a little sand bending over long raduis but learned something from you here with the bolts to compress the sand. Thanks!
Here's a set in stainless I made for a big cube stroked big block in a Chevy Nova. Tuned length 4 into 1 stepped with all lengths within a half inch. Pipes were 2 3/16" off the head stepped to 2 1/4. Merge collector into twin 4" system. Posted to show collector..... Engine made a tad over 850 at the wheels. Got pics of other stuff but won't let me upload due to the size or something. I'm better at making pipes than I am at computers. :dontknow:
Edited by TorYoda, 24 September 2011 - 12:58 AM.
#23 _TorYoda_
_TorYoda_
Posted 24 September 2011 - 01:09 AM
#24 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 24 September 2011 - 05:09 AM
JESUS! Some great work there!
#25 _oldjohnno_
_oldjohnno_
Posted 24 September 2011 - 07:43 AM
Here's a set in stainless I made for a big cube stroked big block in a Chevy Nova...
Bloody hell, that's too pretty to hide under the car..
