L34 and A9X 308 HP figures
60 replies to this topic
#1 _CHOPPER_
_CHOPPER_
Posted 07 September 2011 - 01:07 PM
GMH quoted 240 HP ( 179 KW ) for stock pre ADR27 308's. Did they ever quote anything higher than that for the L34 or A9X?
#2 Dr Terry
Dr Terry
  • 3,325 posts
Posted 07 September 2011 - 02:15 PM
Hi Chopper.
Pre-ADR27A 308 engines had either 240 or 250 bhp, depending on the version.
HT/G/Q & early LH had 9.0:1 compression & 240 bhp.
HJ & LH (Nov 74 onwards) & early LX had 9.7:1 compression & 250 bhp.
GM-H didn't quote any different figures for the L34, even though they were more powerful, the book says 240 bhp.
The A9X was an ADR27A car & the engine was no different in spec to any other late LX (or HX/Z, VB) 308/5.0 Litre.
AFIAK an A9X engine was a bog stock L31, whereas the L34 had many items upgraded like heads, cam, rockers, exhaust, distributor, even on the standard (non-HO) engines.
Dr Terry
#3 _CHOPPER_
_CHOPPER_
Posted 07 September 2011 - 02:43 PM
Thanks, I was just enquiring due to the RTA 120% power ruling.
#4 _Liam_
_Liam_
Posted 07 September 2011 - 04:26 PM
The L34 supposedly had 290bhp where the HO option had closer tk 350bhp I read.
#5 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 07 September 2011 - 05:04 PM
This has come up a lot in the past.
Quoted figures LH SLR5000 179kw, LX SLR5000 161kw.
The A9X engine wasn't the same as the HZ or late spec SLR5000 at all, it had an upgraded crank, cam, no engine fan etc.
A HO version (as in an L34 with the HO kit fitted straight from the dealer) would not have been close to 350HP when 350HP was the best HDT were getting out of their race L34 engines before moving onto the A9X.
#6 _Liam_
_Liam_
Posted 07 September 2011 - 05:07 PM
I guess there is a lot of misinformation then. The 350bhp was a figure quoted by Australian Muscle Car Magazine. You'd be more in the know than I am tho red.
#7 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 07 September 2011 - 05:09 PM
I think if you have a look it says 350HP for race cars. Have a look at what actually came in the HO kit and you'll realise it needed more than that to really make it sing. Holden only had to homologate the bits they couldn't change on the race cars, so thats all they supplied in the kit.
#8 Dr Terry
Dr Terry
  • 3,325 posts
Posted 07 September 2011 - 05:27 PM
As I understood it the camshaft was just late HX 5.0 cam (pre-HZ upgrade) & the crankshaft was similar. The only 'real' change was the removal of the engine fan.
I remember in those days, guys with stock dual exhaust HX & HZ 5.0 V8s getting the same rwhp figures as the A9X once they had removed the engine fan.
Red have you got any factory literature as to what the actual differences were (I realise the listed part numbers were different).
GM-H didn't need any engine parts homologated, why build anything 'special'. If they went to the trouble of building special cranks & cams, why not do something with the dreadful inlet manifold & heads on the stock L31.
On the subject of L34s, I believe one of the Marque/Spotlight books quotes HDT as getting 270 bhp from an L34 fitted with the HO kit, with no others mods.
Dr Terry
#9 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 07 September 2011 - 05:34 PM
Terry the changes made to the A9X engine were from the lessons learnt from the L34 problems. The crank was stronger and the cam was thicker at the front and had a different grind from the SLR5000. Again a lesson learnt from the ADR27A mods. It wasn't designed to give more power (why bother they only needed a smooth car not a race car) it was trying to cope with the rough running engines most of the magazines at the time complained about and a lack of urge.
I'm sue I have some GMH paperwork somewhere about some new parts being homologated and more as the race cars progressed along.
#10 yel327
  • 13,655 posts
Posted 08 September 2011 - 06:46 AM
Cool stuff to learn if correct. I always thought what Terry states, ie A9X engine was standard HX as L34 engine was already homologated for Group C (I imagine it'd have been unlikely that production crank and cam were used in race cars). If crank was made stronger for A9X then it'd probably also have been used in all other 308's as well.
#11 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 08 September 2011 - 09:56 AM
The rules of the day stated what you had to use from the production car, or what was homologated for use. You have to understand the homologation process of the day and how complicated it was.
The L34 was homologated for racing, but the car had certain freedoms, wheels and tyres were the most obvious, and for the engine the most obvious was exhaust was free after the first break. This is one of the reasons the L34 was no screamer off the showroom floor, combined with pain from the supercar scare.
The cam while you could use any grind you liked was always prone to breaking at the front, and the cranks broke too. You had to use the crank from the road version, obviously you could balance it.
To fix these problems, Holden had to homologate new items, and these came with the evolution of the A9X with a thicker cam front journal and stronger crank. Holden did the bare minimum they had to do, so while I have never checked it, I seriously doubt these stronger parts made their way into other engines at the time because of the costs involved otherwise every engine from L34 onwards would have been an upgraded version of the L34 rather than a stock 308.
#12 yel327
  • 13,655 posts
Posted 08 September 2011 - 11:03 AM
I'm still not sure how a thicker cam journal helped though, as didn't they use Wade or some other aftermarket cam on the race cars anyway (whatever was homologated for L34)? Was the A9X change simply to allow the aftermarket cams to have a thicker journal?
Although I have no idea on what actually happened, I would have thought the opposite for changes though, if you changed the design of a cam or crank for one you'd do it for all. Like GMH did when they destroked the 308 for Group A. Didn't the re-designed 308 and 253 (late HQ, early HJ) blocks get many of the L34 design changes incorporated as well?
#13 _CHOPPER_
_CHOPPER_
Posted 08 September 2011 - 11:07 AM
If the cranks and cams broke, they weren't strong enough. Making them thicker in the area they broke would've made them stronger. Maybe they didn't make the changes for all as maybe they already had a large stock pile of bits to go? Or was it because the A9X was only made in the one factory?
#14 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 08 September 2011 - 11:19 AM
You could use whatever brand cam you liked in the race cars. As Chopper says, if it had a habit of breaking in a certain area, making it thicker in that area would stop it breaking. Whilst you could use any brand of cam and grind, it still had to be the same basic specs as the road car in that you couldn't suddenly make your cam thicker or bore out a journal to stop your cam breaking, you still had to work within the rules.
Yep the extra webbing from the L34 block did find it's way into later blocks , but not the other 308 blocks at the time the L34 was produced, i would imagine it was the same deal with the crank and cam in the A9X, it probably made it's way into later versions, again I'd have to check the numbers but i don't believe the crank made it's way into all of the 308's being produced at the time of the A9X. Again, why would Holden do more than they had to to homologate the parts, the stronger parts would have cost more to produce, and if the standard crank was good enough for road application in the average 308, why spend the money.
With the Group A the rules had changed again and you had to have 500 evolution models and 5000 of similar specs which meant 5000 of those 4987cc blocks/cranks rather than the old 5044cc.
#15 _outer control_
_outer control_
Posted 22 September 2011 - 09:01 PM
I would like to know of examples of L34 cranks breaking in the L34 race program .However repco only rated the L34 crankshaft for 10 hrs use in the f5000 engines running around 8,000rpm plus ,keep the revs under 7,500rpm you doubled the life keeping under 7,000rpm no teams encountered problems.The A9x crank i heard were made using mallory metal for ease of balancing ..Malcom Preston of REDCO fame said he never encountered in any race team a crankshaft failure.Bring on the examples either through experience or magazine reading.
#16 _chrome yella_
_chrome yella_
Posted 24 September 2011 - 12:13 PM
the reason Holden had to find an alterative method for balancing the A9x cranks was purely for the reason of
cost cutting measures by GMH when they fitted the engines with single row timing chain, without such measures
the engine created terrible harmonics at certain rpms causing the flywheel to loosen and the necks on the camshaft.
#17 _LXSS350_
_LXSS350_
Posted 24 September 2011 - 01:21 PM
Along with the different crank and cam the A9X also got different piston pins from other 308's. The somewhat controversial subject of the L34 has a very interesting history. All the reviews in magazines at the time had the SLR5000 vs L34 either as a dead heat or as the SLR5000 being slightly faster. GMH where pushing it as the durability option rather than a performance option.
Edited by LXSS350, 24 September 2011 - 01:22 PM.
#18 _outer control_
_outer control_
Posted 24 September 2011 - 05:22 PM
The different part numbers they the [A9X] i believe was a balanced assembly for the extra money you needed to get more for your money than strap ons.
Edited by outer control, 24 September 2011 - 05:22 PM.
#19 _outer control_
_outer control_
Posted 24 September 2011 - 05:31 PM
If your lucky you will get to drive a L34 then comment on performance as not all L34,s were hobbled to keep press and Goverment on side remember V8 Xu1 story
#20 AbsynthHatch
AbsynthHatch
  • 738 posts
  • Name:Mark
Posted 24 September 2011 - 11:03 PM
Sounded like Holden purposely hobbled the performance of the press cars on a number of models over the years
#21 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 25 September 2011 - 09:25 PM
The only way to do a fair comparison is get a time machine, go back and buy a new L34, new SLR5000 and a new A9X. Blokes with great memories of over 30 years ago still go on today about how good the L34 was engine wise, and it was, but not off the factory floor. Take it home tune it fit a decent exhaust and aircleaner and it went better, certainly nothing close to the 350hp suggested by some people. Do the same thing to an A9X engine, the performance wouldn't be there, simple. Fact is it's a lot easier to modify an A9X engine up to make it go than it is to slot a 10 bolt diff and rear discs into an L34.
#22 _LXSS350_
_LXSS350_
Posted 25 September 2011 - 09:41 PM
Driven a few genuine L34's (taxi's) back in the 70's and early 80's. Even back in the day I would never have called them grunty. The HO Fraud :stirpot: was grunty (as per the factory spec), but the road going L34 was at best mild.
Ive still got most of the original magazines like Wheels that I had brought back in 1974 when the L34 was first released. So it was interesting to revisit the tests again.
In 1974 GMH issued notice that no motoring writer would get an L34 from GMH and that the press are to be discouraged from searching for one elsewhere. Wheels got a hold of one for their Dec 74 issue via Don Holland and Bruce Sutton. They took both the L34 and an SLR5000 to Oran Park and Castlereagh Drag strip. Holland drove and directly compared Sutton's stock 5000 to the L34. The basic verdict was that the L34 was equal down the 1/4 mile but slower in it's 0-100kph & 0-160kph times. The L34 was faster around the Oran Park track but due to its better brakes and handling & tyres.
The story of 380Hp probably stems from the non clarity in the Sports Car World (L34 test) that appeared in the mag in late 1974. (below is the text) Although it doesn't clarify ........ its actually talking about the race cars power not the road cars. (even race cars struggled to get 380hp in 74)
"The special high performance kit is avaliable through General Motors Parts and Acc (formally Nasco) and consisted of a Holley 780 cfm carb,Crane roller rocker arms,hi performance GMH cam, special racing piston rings, an oil cooler and a solid valve lifters kit. That lot boosted the cars power to a reputed 283kW (380 bhp)"
Edited by LXSS350, 25 September 2011 - 09:54 PM.
#23 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 25 September 2011 - 09:51 PM
LX SLR 5000's produced before the dreaded ADR27a were factory rated at 186kw, possibly courtesy of their 9.7:1 compression.
#24 _LXSS350_
_LXSS350_
Posted 25 September 2011 - 10:09 PM
Not many LX's are pre July 1976. Besides the full length tray on the garage floor that should have been offered with every 308, ADR27A really put the gremlins into the old 308. They where a real pig to get running smoothly and the reviews suffered. It was made worse because the 302/351 fat ass Frauds had handled ADR27a much better.
Edited by LXSS350, 25 September 2011 - 10:10 PM.
#25 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
Posted 25 September 2011 - 10:18 PM
There were a few pre July 1976, mine is a Feb 1976 build.
