removing bearing from steering coloume 'coffe pot'
57 replies to this topic
#1 _brendan_h_
_brendan_h_
Posted 09 October 2011 - 12:09 PM
how do i remove the bearing from the steering colum? heres 2 pics of what i am talking about
#2 76lxhatch
  • 7,199 posts
Posted 09 October 2011 - 05:05 PM
That top bit that you've already attacked is part of the pot, it has to be removed by force (then you have to figure out how to retain the new bearing without it)
#3 _brendan_h_
_brendan_h_
Posted 09 October 2011 - 06:09 PM
Pretty much use force to get it out?
#4 76lxhatch
  • 7,199 posts
Posted 09 October 2011 - 08:01 PM
Break it or grind it off
#5 dattoman
  • 16,485 posts
Posted 09 October 2011 - 08:14 PM
But then you have to figure out how to hold the new bearing in
I'd say don't touch it unless you have to replace the bearing
And even then.... most here have opted for another pot with a better bearing and left it as is
#6 _brendan_h_
_brendan_h_
Posted 09 October 2011 - 08:32 PM
The bearing fell to bits, tiny little balls everywhere
#7 dattoman
  • 16,485 posts
Posted 09 October 2011 - 08:42 PM
I believe there is supposed to be as thin metal retainer for holding the bearing in... like a circlip that goes into a groove in the pot
But your bearing looks like its moved so the retainer might have been long gone
BFI might be your only hope
#8 davelh
davelh
  • 818 posts
  • Car:74 LH SL
Posted 09 October 2011 - 08:48 PM
drift it from the rear is how I got mine out, there should be enough of a lip to get the punch on, and slowly work around the bearing race.
To retain the new one, just centre pop it in a couple of places on the front.
#9 _brendan_h_
_brendan_h_
Posted 09 October 2011 - 09:03 PM
Will give it a go.
Rare spares sell new bearings ive herd, expensive too so they say. Is there al alternative like a roller bearing ect
#10 S pack
  • 15,668 posts
Posted 09 October 2011 - 11:34 PM
I can tell you've never removed one of these bearings Datto.
No groove and no circlip. The alloy lip is simply machine rolled over to retain the bearing in place.
#11 dattoman
  • 16,485 posts
Posted 09 October 2011 - 11:41 PM
Just once
And there was a sliver of metal left over... that as you say might be the lip... or a retainer
And according to my workshop manual theres a retainer... but not a very good pic of it
So just going on what I've seen
http://www.gmh-toran...ing-coffee-pot/
http://www.gmh-toran...bearings-upper/
#12 76lxhatch
  • 7,199 posts
Posted 10 October 2011 - 07:08 AM
Sadly no, the ID and OD are so close that there's really nothing available. You can get needle roller bearings in roughly the right size if you could figure out how to retain it but it really needs a proper radial ball bearing. I've considered machining the sleeve away completely to allow more room but the column attaching bolts are really a bit too close to allow this, the sloppy factory bearing is about the only option.
#13 _brendan_h_
_brendan_h_
Posted 10 October 2011 - 01:59 PM
just got back from rare spares. sadly they dont make them anymore, so now im stuck. prob have to look into getting a bearing made to suit
#14 S pack
  • 15,668 posts
Posted 10 October 2011 - 03:17 PM
G/day Brendan
AFAIK Rare Spares never made repro upper column bearings, they just bought up the last of the stock that GMH had.
Les or Cavan may like to correct me if I'm wrong.
I'll have a look tonight and see what I've got laying around.
PM you soon.
Dave.
#15 _brendan_h_
_brendan_h_
Posted 10 October 2011 - 04:32 PM
they guy just said 'not avalible anymore' thanks
#16 davelh
davelh
  • 818 posts
  • Car:74 LH SL
Posted 10 October 2011 - 05:13 PM
Try a few Holden dealers, that's where I got mine from.
#17 _CHOPPER_
_CHOPPER_
Posted 10 October 2011 - 05:58 PM
That's where I got my last one a couple of years ago.
#18 _brendan_h_
_brendan_h_
Posted 10 October 2011 - 06:50 PM
Anyone got a part number i can try for holden
#19 rodomo
  • 18,028 posts
Posted 10 October 2011 - 07:33 PM
Try 7800269
#20 76lxhatch
  • 7,199 posts
Posted 10 October 2011 - 07:38 PM
I believe they are the same item right up to at least VK Commodore if that helps
#21 rodomo
  • 18,028 posts
Posted 10 October 2011 - 07:51 PM
If I've got the right part no. from the LJ parts book, it says "all" inc 4 cyl. I reckon you're right.
#22 dattoman
  • 16,485 posts
Posted 10 October 2011 - 08:00 PM
Listed as NLA Holden
But thats the number
This might be of interest to some
http://www.camaros.n...hp/t-71203.html
Fits a bunch of Chevs... maybe our yankhatch guy can find some :)
#23 S pack
  • 15,668 posts
Posted 10 October 2011 - 08:02 PM
PM sent.
#24 rodomo
  • 18,028 posts
Posted 10 October 2011 - 08:03 PM
That makes sense too. I couldn't see HQ+ using a different bearing being kinda sorta chev?
#25 dattoman
  • 16,485 posts
Posted 10 October 2011 - 08:05 PM
http://corvetteparts...mn/?itm=Bearing
Lots of chevs/buiks etc
