Brake Light at Engine Start
16 replies to this topic
#1 _Yella SLuR_
_Yella SLuR_
Posted 18 October 2011 - 08:55 AM
Just got Yella checked for her annual inspection check. Mechanic reckons the brake light should come on prior to kicking over so you know the brake warning switch is working. As far as I know, Yella has never done that, light is working cause it comes on when park brake applied. I know it works, cause it warned me when the rear wheel cylinders were leaking.
Can anybody confirm that the brake warning light should or should not come on prior to ignition on the LH's?
I reset it as he suggested, but still no difference in operation of the light at engine start.
Cheers in advance.
Quietly puzzled.
Edited by Yella SLuR, 18 October 2011 - 08:57 AM.
#2 hanra
  • 11,033 posts
Posted 18 October 2011 - 10:09 AM
You might need to find another mechanic mate? Thats pretty picky!!! Maybe he is thinking of the oil pressure light?
#3 hanra
  • 11,033 posts
Posted 18 October 2011 - 10:17 AM
The brake light only has two paths to GND. Via the handbrake switch or the brake fail switch. One of these points need to supply GND for the light to illuminate. Turning the key to IGN prior to START would not allow the light to illuminate.
#4 _nial8r_
_nial8r_
Posted 18 October 2011 - 10:59 AM
surly he didnt knock you for that ?????
#5 ls2lxhatch
  • 5,335 posts
Posted 18 October 2011 - 11:06 AM
If you have a single pin switch on the prop valve then the light is tested via the handbrake (pre ADR31 1977). If you have a two pin switch on the prop valve then the light is tested by the ignition switch.
Point out to the mechanic that ADR31 is not on your compliance plate and your car was built before 1977.
Firstly, LX Toranas have 2 different versions of the brake pressure switch, but why do they have 2 variations ??
It goes like this. Early LX is wired the same as the LH series, where the handbrake light & the brake fail light are one in the same. This was before the introduction of ADR31 (for 1977) where 2 separate lights were compulsory.
The single pin switch was used on the early cars & the 2-pin switch was fitted to the ADR31 cars.
Ever since the EH series, Holden had been using a globe-checking system where the temp light was lit momentarily when the ignition switch was turned to the start position. It was only the temp light which did this, because unless the engine actually overheating the driver never saw it lit. The oil pressure light comes on every time the ignition is switched on, but before the engine is started, so it wasn't wired the same as the temp light. Likewise the brake light was tested when the handbrake was pulled on.
When the separate brake fail light was introduced, this same test facility was required. The brake pressure switch was wired with 2 pins which completed the circuit to the dash globe. If you look inside the 2-pin switch you will see that the pins are joined with a link. If the switch if left un-plugged, the dash light will not work, part of the fail-safe wiring. One of the wires goes to the dash light & the other to the ignition switch as part of the test circuit. To test the circuit, what you need to do is un-plug the switch & use a paper clip to bridge the 2 pins together inside the plug. Then turn the ignition to start, so the brake fail light will come on. If it doesn't find out why. It can only be the globe or the ignition switch. Once that is fixed, plug the brake pressure back in. If the light stays on, reset the switch.
Edited by ls2lxhatch, 18 October 2011 - 11:21 AM.
#6 _fatlh5000_
_fatlh5000_
Posted 18 October 2011 - 11:31 AM
OMG...... am I reading this ?
ADR rules pre and post 1977 to get a pink slip.
Did he use a tread guage to check the tyres are roadworthy ? I bloody hope so ?
#7 Dr Terry
Dr Terry
  • 3,342 posts
Posted 18 October 2011 - 02:59 PM
I gather this is for an annual NSW rego inspection.
If it is, then the inspector is wrong !!
The only 2 rules that apply here are Rule 101.01 parts f & h:-
f) = Brake failure warning light doesn't comply (with ADR31)
h) = (if fitted with ABS), the ABS self test/failure warning lamp does not operate when the ignition is turned on, and the engine is either not running or the starter motor is engaged.
Ask the inspector to show you the rule in the RTA rule book or on the website, which he must.
If your car is OK then you can afford to push the point & even dob him in to the RTA if necessary. If your car is a bit 'iffy', then wire up a relay to make the light work on start-up to keep the fool happy.
I am an authorised inspector, so I know only too well how all this works.
Dr Terry
#8 _shan620_
_shan620_
Posted 18 October 2011 - 07:01 PM
yeh my engineer told me the exact same thing. He said the brake light needs to light up for a second after start up, and automatically go off.
#9 _76S.L.R_
_76S.L.R_
Posted 18 October 2011 - 08:33 PM
For some reason the brake warning light on my LX is constantly on!??,Ive recently fitted the hoppers brakes to the front and the rears got new brake shoes / wheel cylinders but still that light is constantly illumimnated?.
Does that light being on all the time mean my Proportioning valve is faulty in some way?
Edited by 76S.L.R, 18 October 2011 - 08:33 PM.
#10 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 18 October 2011 - 08:52 PM
The plunger in your proportioning valve most likely needs to be reset.
It may have triggered when bleeding the brakes or if there was an issue with your old brakes or there may be a current issue with your brakes.
Reset the plunger and try the brakes out and see if it triggers again.
#11 hanra
  • 11,033 posts
Posted 18 October 2011 - 09:12 PM
Well if it's an LH or early LX, show em the circut diagram.....! It simply won't happen that way!!!!
#12 rodomo
  • 18,063 posts
Posted 18 October 2011 - 10:26 PM
Later ign. switches supply the earth while cranking.
#13 S pack
  • 15,764 posts
Posted 18 October 2011 - 11:21 PM
^^^ Correct. The combined handbrake/brake fail warning light will stay on until the handbrake is released.
#14 _Yella SLuR_
_Yella SLuR_
Posted 19 October 2011 - 09:25 AM
Didn't fail it for it, just said I needed to fix it. Reset the swicth, by removing and reinserting, but still doesn't illuminate, and your posts confirm to me that it never has at start.
Thanks fella's.
I do need to adjust my rear brakes though.
#15 hanra
  • 11,033 posts
Posted 19 October 2011 - 10:04 AM
Good one. Least your armed with this info in case there is a "next time"!!
#16 _Yella SLuR_
_Yella SLuR_
Posted 20 October 2011 - 11:10 PM
It's more a peace of mind thing. If there were a problem with the brakes, I'd like to fix it.
Edited by Yella SLuR, 20 October 2011 - 11:11 PM.
#17 marko1au
marko1au
  • 207 posts
  • Car:LX sadan
Posted 13 December 2019 - 04:55 PM
DR Terry,
              i have a lx torana that im rewiring ...... could you please show how to wire up the warning light to illuminate when the ign is on before starting please ...... i have the single pole sender fitted ......
        mark
