Tips on fitting Roof Lining
40 replies to this topic
#1 hanra
  • 10,936 posts
Posted 02 November 2011 - 08:36 PM
Ive purchased a roof lining off Boomfunk and am getting close to fitting it...
Ive had a look on there website which gives a basic run down:
http://cgautoupholstery.com/cart/index.php?main_page=page&id=8
One big concern I have is about the 2 wires. There are hooks in the beams running across the roof which the wires are held up by. The rear beam has all the hooks in tact. The front beam however.... out of the 6 hooks total, 3 have been broken off....
From right to left it goes. hook-missin-hook-interior light-missing-missing-hook.....
Im not sure what to do here.... I was thinking drilling another hole next to the existing one where the hook is missing and feeding a small cable tie through? Or even just some lockwire?
Ive been told to fit the wires first up???
Ive bought 2m of pinch weld which Ill cut up into bits to keep the edges in place when Im fitting.
Any hints,tips or suggestions would be appreciated.
From the GMH Manual:
Intact tab
Missing tab
#2 rodomo
  • 18,031 posts
Posted 02 November 2011 - 09:10 PM
Drill a small hole beside it. Find a small self tapper and a small washer. Put a bend in the washer, Screw the self tapper and washer in, hang your wire over it, then tighten the screw so the bent washer captures the wire.
#3 hanra
  • 10,936 posts
Posted 03 November 2011 - 04:23 PM
Good idea, however do I want to clamp the wire totally or still allow movement of the wire?
#4 _HER 76_
_HER 76_
Posted 03 November 2011 - 04:36 PM
I am fairly capable at most thing, however after doing one headlining, I found it to be a PIA. Next time i'll just pay someone to do it.
The headlining in question was for a XM Ford Falcon, so maybe that's why I had trouble.
#5 hanra
  • 10,936 posts
Posted 08 November 2011 - 03:10 PM
I guess most people get upholsterers to fit there roof linings?
#6 _BIGCAV_
_BIGCAV_
Posted 08 November 2011 - 03:54 PM
how about a spring steel horse shoe clip? for instance something like a door handle clip etc
#7 _hatch76_
_hatch76_
Posted 08 November 2011 - 08:11 PM
I also bought a headliner from boom funk for my hatch and found it easy to install. I put the wires and rods in first, then started from the middle and worked out from there. I cut some old pinch weld into 50mm bits to hold the edges on. It fitted like a glove, was very happy.
#8 _mick74lh_
_mick74lh_
Posted 08 November 2011 - 10:29 PM
Rodomo's tip is perfect. Just follow the diagram of how it all goes together. Judging by the rest of the work you've done on your car it should be a piece of cake. Along all the pinch weld areas make sure you've got lots of stuff to secure the material while the contact adhesive goes off. Cut up some old pinch weld. And plenty of small clamps and someone to help would make it easier as well.
- Yeah sorry Daniel I missed that you mentioned using the old pinch weld. But it works well eh
Edited by mick74lh, 08 November 2011 - 10:30 PM.
#9 ribz0
ribz0
  • 512 posts
  • Name:Eric
  • Car:LC Torana & 1975 South African Mini
Posted 09 November 2011 - 06:12 AM
Great tips thanks guys!!
Im about to give it a go on mine as soon as I get it back from the painters.
:3gears:
#10 hanra
  • 10,936 posts
Posted 09 November 2011 - 02:01 PM
Yep got 2m of pinch weld that Ill cut into 50mm sections.
#11 _Brad1979UC_
_Brad1979UC_
Posted 09 November 2011 - 10:56 PM
Having a second pair of hands to hold bits up certainly makes the job easier too.
It's easy enough to fit though, but make sure you use all of the hooks in the roof....otherwise it may not look right in the part you didn't use a hook.
When we did mine a hook broke off and I really didn't think much of it, and it's just a little inconsistent in that spot, otherwise it was an ebay buy that looks great :D. Good luck!
#12 _UCV80_
_UCV80_
Posted 10 November 2011 - 06:39 AM
This happened to me last week while fitting mine, a tiny drill hole and a small screw worked a charm. I cut up pinch weld also, brilliant idea. Start from the middle and work your way outwards. Getting all the wrinkles out of the vinyl is geat fun.
#13 hanra
  • 10,936 posts
Posted 12 November 2011 - 09:50 PM
I used the trick of a small screw and a bent over washer. It has worked well. Made a start on it today. Its just held up by pinh weld at the moment.
Can I ask a BIG FAVOR..... Can someone please take a pic of the B pillar where the roof lining meets the pillar? Im not sure how high or low this part of the lining should be....
Edited by hanra, 12 November 2011 - 09:52 PM.
#14 hanra
  • 10,936 posts
Posted 13 November 2011 - 01:49 PM
#15 EunUCh
EunUCh
  • 2,769 posts
  • Car:japos
Posted 13 November 2011 - 02:57 PM
[attachment=16885:HOOD LINE.jpg]
#16 hanra
  • 10,936 posts
Posted 13 November 2011 - 03:00 PM
Brilliant effort there NO BALLS. Thanks for that. I noticed your date is wrong in your pic though?
#17 hanra
  • 10,936 posts
Posted 13 November 2011 - 04:35 PM
Righteo, thanks to all the support from members here, I think I've got the right idea. Good one.
#18 hanra
  • 10,936 posts
Posted 15 November 2011 - 09:55 PM
So its coming along pretty well... Just need to glue up the passenger side rear pillar and then trim the excess.. Week long process this has been!!!
#19 boomfunk
boomfunk
    Forum Trimmer
  • 2,065 posts
Posted 16 November 2011 - 10:30 AM
Nice, looking good there, when its totally fitted are you able to email me some better quality photos if thats possible.. i dont have good ones of a 4 door torana
#20 hanra
  • 10,936 posts
Posted 16 November 2011 - 10:39 AM
Yep yep. Still keeping that in mind! Ill have to power up my good camera and try and get some shots at day time. Perhaps this weekend.
#21 ribz0
ribz0
  • 512 posts
  • Name:Eric
Posted 16 November 2011 - 12:50 PM
Looking great!!
What adhesive will / did you use? Is a Kwik Grip type of glue ok to use when gluing the edges?
The pinch weld looks like its the goods to use as well!
:clap:
#22 hanra
  • 10,936 posts
Posted 16 November 2011 - 12:57 PM
Pretty sure its just a Selleys contact glue. Apply to both surfaces, leave for 5-10 then bring surfaces together. Pinch weld does an awesome job! Thanks to Boomfunk for the tip of there website!
#23 _LH8VD69_
_LH8VD69_
Posted 16 November 2011 - 01:43 PM
I paid a upholsterer to do mine. He stripped out the old roof lining/ all old pillar velour that was glued on including the old velour door tops then fitted all the factory stuff including the vynal on the 'a' ? pillar at the front. All done in 24 hrs at a cost of $300. Money well spent I think ;-)
#24 hanra
  • 10,936 posts
Posted 16 November 2011 - 08:47 PM
That is a good price!
One small thing I did prior to fitting the headlining was to take a few bits of paper and mark out the positions of all the holes for the grab handles, sunvisor mounts and rear view mirror. Hopefully will save me having to poke around endlessly searching for a hole...?
#25 _dunger_
_dunger_
Posted 17 November 2011 - 07:19 PM
where can i buy sienna roof lining trim in sydney for my ss hatch?
the trim code is 1916-65v (sienna)?
