Harmonic Balancer
22 replies to this topic
#1 warrenm
warrenm
  • 2,114 posts
  • Car:1972 LJ Torana
Posted 05 November 2011 - 08:33 AM
In the quest to keep the Holden 6 in 1 piece, I've adapted a larger balancer. I could use the Romac unit but I'd heard good reports about several units that help the Chev 6's stay together. After looking at the pro's & con's I decided to purchase a ATI Super Damper as the hub is separate from the damper which made it more appealing should I stuff up.
After some measuring I welded the centre of the hub as ATI don't make one to fit a Holden 6, then set it up in the lathe & started machining. This is the end result.
Attached File  P1010838 (600 x 450).jpg   63.01K   11 downloads
Attached File  P1010852 (600 x 450).jpg   64.42K   11 downloads
Attached File  P1010853 (600 x 450).jpg   60.59K   8 downloads
I then modified a timing cover by removing the timing marker as the ATI damper is larger, this hasn't been welded up at this stage.Attached File  P1010850 (600 x 450).jpg   59.1K   7 downloads
This is the damper fitted to a spare motor so that it's easier to work on.
Attached File  P1010846 (600 x 450).jpg   60.77K   13 downloads
Attached File  P1010845 (600 x 450).jpg   57.95K   6 downloads
As this damper doesn't have a belt groove in it,(because I ordered the wrong one) I purchased a 5.25" Moroso pulley to bolt on the front. The smaller pulley also keeps the alternator speed down.
Attached File  P1010848 (600 x 450).jpg   64.73K   5 downloads
Attached File  P1010849 (600 x 450).jpg   67.41K   7 downloads
Also had to move the water pump pulley forward, I'll make an alloy one when I can get a bit of alloy the correct size.
Because the balancer is heavier, the crank is drilled so that a bolt can help keep everything on.
Here's a pic of a std & modified alternator bracket to move it forward.
Attached File  P1010855 (600 x 450).jpg   67.92K   7 downloads
Attached File  P1010856 (600 x 450).jpg   64.3K   4 downloads
Almost ready to fit to the car, just need to refit the electric fan as I prefer to use an engine driven, but there's not enough room in an LJ.
#2 warrenm
warrenm
  • 2,114 posts
Posted 05 November 2011 - 11:56 AM
I've been busy this morning, I made a new adjustable timing pointer, I'll add the pin when I fit it to the engine.
Time to kick back, I'm off to see "COLD CHISEL" this arvo.
Attached File  P1010857 (600 x 450).jpg   63.72K   12 downloads
Attached File  P1010860 (600 x 450).jpg   73.93K   5 downloads
#3 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 05 November 2011 - 01:23 PM
Looks good. can't wait to see how it all comes up when the engine is finished
#4 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 05 November 2011 - 04:34 PM
nice work, could be a market for those hub adapters!
#5 _oldjohnno_
_oldjohnno_
Posted 05 November 2011 - 05:50 PM
Great stuff. These things have quite a reputation for themselves, I'm keen to try one myself on the next build. What application was it originally for? I was thinking of using a BB Chrysler unit, they're big enough in diameter without being too wide and are neutral balance. Did ATI suggest a starting point for the o-rings to use?
#6 _CHOPPER_
_CHOPPER_
Posted 05 November 2011 - 06:19 PM
I heard that Massey Ferguson balancers used to be used a long, long time ago.
But nice to see new options.
#7 warrenm
warrenm
  • 2,114 posts
Posted 06 November 2011 - 07:21 AM
I looked at the BB Chrysler after seeing the "Rattler" that you were fitting to a project, but I ended up getting one to suit a 6cyl 5MG Toyota that I thought had a serpentine belt, but I miss read the catalogue. No starting point for the o-rings, use it as is. This neutral balance.
#8 _Inj gtr202_
_Inj gtr202_
Posted 07 November 2011 - 12:12 AM
:spoton:
#9 warrenm
warrenm
  • 2,114 posts
Posted 13 November 2011 - 12:16 PM
I've now fitted the balancer to the car.
Hub fitted
Attached File  P1010885 (600 x 450).jpg   60.34K   11 downloads
Attached File  P1010886 (600 x 450).jpg   70.39K   7 downloads
Balancer fitted & torqued.
Attached File  P1010887 (600 x 450).jpg   70.1K   8 downloads
Attached File  P1010888 (600 x 450).jpg   70.47K   7 downloads
Car is back together.
Attached File  P1010890 (600 x 450).jpg   71.62K   8 downloads
Something that I didn't take a pic of was the 7/16"unf stud that I fitted in the crank to hold it all on.
All seems OK, the timing pointer is good, far better than the std Holden one. It's just a pity that I can't get the engine fan in there, as I'm not overly fussed on using an electric fan.
Edited by warrenm, 13 November 2011 - 12:20 PM.
#10 _Agent 34_
_Agent 34_
Posted 13 November 2011 - 06:25 PM
Hi Warren,
I assume this is for the drag strip ? as i was looking at your photo.
Again i assume that you have adjusted the water pump pulley to be bigger than the standard one, could you expand out on this a bit and again i assume that at high revs it automatically pumps more water anyway ?
one last question - can you clarify if cast impellor are Worse that the metal pressed ones - i have heard that the cast one don't cavitate -- This could be the other way around - may be the cast don't cavitate not sure now.
grant
#11 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 13 November 2011 - 06:45 PM
looks real good. :spoton:
did you crack test the crankshaft after the flywheel loosened?
#12 warrenm
warrenm
  • 2,114 posts
Posted 13 November 2011 - 06:56 PM
Hi Warren,
grant
Hi Grant
Yes the car is predominantly(the car is still street registered) for the dragstrip, but no reason that it couldn't be used for circuit or speedway or street.
The water pump pulley is still the std Holden size, at this stage I haven't had issues with water. I did fit a larger pulley to the alternator as it was spinning up to 19000 rpm so it's been slowed down. The Moroso pulley that I fitted is 5 1/2" which is 1/2" smaller that a std Holden balancer, so this has slowed things down a little more.
The impeller on this engine is a pressed steal one, but has had every second vane removed to "slow" the water down, it was modified 12 or 13 years ago when this engine was in a speedway car & it did drop the temps. My other engine had a cast impeller & didn't have any heating issues with an engine driven fan & a std LH/LX radiator, so I've used both.
Warren
Thanks & no crack testing.
#13 _Inj gtr202_
_Inj gtr202_
Posted 15 November 2011 - 02:38 AM
Does removing every second blade on the pump cause heating problems in low rev's? I was told about this mod but was not brave enough to do it due to the amount of street driving I will do.
Nice work with the balancer.
#14 warrenm
warrenm
  • 2,114 posts
Posted 15 November 2011 - 07:51 AM
I can't comment on the low speed cooling problems, it may have an effect.
#15 warrenm
warrenm
  • 2,114 posts
Posted 21 February 2012 - 01:11 PM
Time for an update with the balancer. I had a run at the Test n Tune at the WSID on the 11/2/12 the result is that the balancer stayed in place, so did the flywheel. :party:
6000rpm on the clock, side step the clutch, flat change at 7000. :driving:
Here's some footage & pics.
Attached File  SD20120211_T&T_SuperStreet_0774.jpg   93.15K   11 downloads
Attached File  SD20120211_T&T_SuperStreet_0906.jpg   93.53K   9 downloads
Attached File  [email protected] (230 x 600).jpg   23.93K   8 downloads
#16 mr5000
mr5000
    chief break-everything
  • 3,455 posts
  • Car:77 lx 4door
Posted 22 February 2012 - 02:45 PM
not a bad effort there out of a 6 nice work
#17 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 23 February 2012 - 09:20 PM
:spoton: good stuff
do you know what ratio first gear is in your sag box?
that mph is good for a 12.40, if you can get it out of the hole a bit better.
Is there a reason why it sits a bit high in the bum?
#18 warrenm
warrenm
  • 2,114 posts
Posted 24 February 2012 - 07:02 AM
1st gear is 3.11:1.
It can't sit any lower in the rear with those tyres on, I've also fitted std LJ springs to the front which has lowered it a bit.
#19 warrenm
warrenm
  • 2,114 posts
Posted 04 February 2014 - 07:43 AM
A couple of pics for Kevin
1/2" cap screw turned down to 7/16"unf & washer.
Attached File  IMG_20140131_104704.jpg   59.65K   6 downloads
Attached File  IMG_20140131_104758.jpg   108.33K   5 downloads
#20 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 04 February 2014 - 07:55 PM
:spoton:
What do ya torque it to?
#21 warrenm
warrenm
  • 2,114 posts
Posted 04 February 2014 - 11:07 PM
60ft/lbs, I think it was.
#22 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 07 February 2014 - 06:21 AM
Dunno if this is on the same page or not... mate used to build/race circle track modifieds, big wing on the roof. His had a chev beating 179, that ended up being  mine for 24 years. He gave me a std Chev 6" balancer that I fitted to the Holden item, using three cap screws. All matched up like it was sposed to be there. Of course, I didn't hear/feel/notice any difference, just figured extra weight spins up slower... then gave it back to him for his new 327(?) he's building.
#23 _AED262_
_AED262_
Posted 05 June 2014 - 06:15 PM
Years ago we used a pink perkins fluid filled dampner, it is just like the fluid dampners you see now. I never had a problem with anything coming loose.
I made up a moly hub just like the ATI one in previous thread, held on with a 7/16 bolt.
I also had 7/16 arp flexplate bolts with very thick hardened washers [very important] and two 3/8 dowels. Nothing ever came loose after that.
