K frame rebuild
Thoughts?
35 replies to this topic
#1 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 07 November 2011 - 01:10 AM
At some stage i will need to rebuild mine
There are kits available i see through this mob
http://www.ebay.com....=item519b48fb49
Is this "hamburger with the lot" any good or are there others available ?
I just want a quality product
#2 ls2lxhatch
  • 5,332 posts
Posted 07 November 2011 - 02:15 AM
The upper rubbers are original so they should be good.
There are better lower rubbers that have a solid crush tube instead of the rolled steel tube.
Moog ball joints are probably better quality.
The grease nipple on top of the tie rod ends could cause clearance issues depending on the which brakes you have.
The k-frame mounting rubbers look good. Personally I prefer to use SuperPro bushes for the k-frame mounts
I don't see anything wrong with the rest of the parts.
#3 ls2lxhatch
  • 5,332 posts
Posted 07 November 2011 - 02:31 AM
#4 dattoman
  • 16,487 posts
Posted 07 November 2011 - 09:34 AM
I've got access to the upper and lower rubber bushes if need be
And I think a Moog order is coming soon
#5 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 07 November 2011 - 11:35 AM
Yep I'm fitting one of these kits this week, looks better quality than anything else on ebay...
Make sure you tell them if you've got a RTS front end or not.
#6 _CHOPPER_
_CHOPPER_
Posted 07 November 2011 - 01:49 PM
Based on what was listed, it wouldn't matter what front end you had with that kit. The only real difference is the rack mount bushes, which are not included.
#7 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
Posted 07 November 2011 - 07:13 PM
I didn't think so either, but according to the seller the front lower arm bushes are slightly different.
#8 TempesT
TempesT
  • 493 posts
  • Name:James - JImmy or Jim
  • Car:LX hatch
Posted 07 November 2011 - 08:42 PM
personally, there are better brands than what is supplied here, youll pay more, but they might flog out in half the time. I also would spare no expense on ball joints there are some good examples on here how bad it can go it they let go!
#9 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 07 November 2011 - 09:17 PM
Thanks for the responses
Neil is there a place in Perth that i can go to pick up what is needed -- will be down that way mid Dec so i can sort it then
And if there is a spare set of the Moog in the next lot i will take them if i could
Read somewhere on here it is best to go nolothane on the lower control arms and the original rubber on the upper - thoughts?
So according to the ebay add needed is -- anything else?
  • 4 x New upper inner pivot bushes (genuine GMH)
  • 4 x New lower arm inner bushes (quality Aust manufacturer)
  • 2 x New outer tie-rod ends - Castle nuts and Greasable
  • 2 x New upper ball joints - Castle nuts
  • 2 x New lower ball joints - Castle nuts and Greasable
  • 2x Upper Bump Stops
  • 2x Lower Bump Stops
  • 8x K-Frame Rubber Bushes
  • 2x Outrigger Bushes
  • 2x Sway Bar Link & Bush kit
  • Rack mount bushes
#10 dattoman
  • 16,487 posts
Posted 07 November 2011 - 09:41 PM
Send me an email with the list on it mate
I'll see what I can get and what cost for you
#11 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
Posted 07 November 2011 - 10:25 PM
  • Rack mount bushes
That kit doesn't come with sway bar D-bushes, I bought some of these - http://cgi.ebay.com....em=370557022199
#12 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 07 November 2011 - 10:30 PM
Cheers Garth - i'll ad it to the list :spoton:
#13 _CHOPPER_
_CHOPPER_
Posted 07 November 2011 - 10:31 PM
The D bushes I would presume are not included, as they would vary depending on the diameter of the front bar used.
UCgazman, GM-H used different bushes in the lower arms as an exercise in bullshit baffles brains. Just use 4 stiff rubber bushes in the front.
#14 LX2DR
LX2DR
  • 1,763 posts
  • Name:Paul
Posted 08 November 2011 - 04:22 PM
I just finished doing mine, ,all parts from Rares except ball joints
FEK9 - Kit front end mounting $110.00
BKLF4 - Bush kit, Front suspension lower $57.13
BKUD4 - Bush kit, Front suspension upper $32.50
SKB1004 - Stabaliser bar bush kit $65.00 (This is complete with rods and nuts & D rubbers std size)
FEBK11 - Control arm bumper kit $36.90 (Upper & Lower incl)
K5103 Moog ball joint
K5108 Moog ball joint
I bought the ball joints direct from Rock Auto, some time ago.
Edited by LX2DR, 08 November 2011 - 04:24 PM.
#15 dattoman
  • 16,487 posts
Posted 08 November 2011 - 05:24 PM
They are actually quite good prices
I can't do any better than that with Mackay rubbers individually
#16 ReplicarSLR
ReplicarSLR
  • 518 posts
  • Car:Not anymore unfortunately
Posted 08 November 2011 - 05:36 PM
When WA Suspensions did my first Torana they reccomended a combination for the front end. They fitted poly for the lowerrear two and rubber for the lower front two or the other way around I cannot remember, but can check my photos if someone else doesn't know. K frame to car were all poly as were the steering bushes and sway bar. All bump stops were rubber.
#17 _gen3torrie_
_gen3torrie_
Posted 24 November 2011 - 09:48 PM
datto i'll need one of the moog ball joints for the upper unless you found out about parts?
#18 _CHOPPER_
_CHOPPER_
Posted 25 November 2011 - 08:47 AM
One? It's normally good practice to replace ball joints as a pair. This is because they are both generally as old as each other, so are probably just as rooted as each other.
#19 dattoman
  • 16,487 posts
Posted 25 November 2011 - 09:34 AM
He'll be replacing 2 ... but one of the ones I sold him seems to be minus a boot and plate to hold the boot on
So I need to find those parts or get another joint
Well...I don't need too... cause I think he lost them himself... but I'm a sweet guy so I'm trying to help the poor unfortunate out
#20 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 25 November 2011 - 09:15 PM
i may have a spare boot and i'll look at the plate.
have some spare moog bits
#21 _gen3torrie_
_gen3torrie_
Posted 27 November 2011 - 06:25 PM
problem solvered thanks datto seem's datto got sold the wrong one...
#22 hawk
hawk
  • 2,166 posts
  • Name:steve
  • Car:UC Torana
Posted 06 December 2011 - 08:26 PM
i just bought the ball joints upper and lower bushes today and they will get fitted in the next few days they all look like quality parts but i dont know much about them
#23 _j.e.d._
_j.e.d._
Posted 20 December 2011 - 03:42 PM
Hey Garth, how'd you go with fitting this kit in your car? How do you rate it?
Cheers,
Jase
#24 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
Posted 20 December 2011 - 06:41 PM
Yeah it all went in fine mate, quality seemed good on the aftermarket bits and of course the genuine nos bushes were spot on. Glad I didn't go nolathane, these ones fit heaps better.
#25 _j.e.d._
_j.e.d._
Posted 21 December 2011 - 02:50 AM
Sweet cheers mate, I'll have to look into getting this in the new year when I've saved my pennies after Xmas! I'm definitely keen on a kit that supplies everything you need so you don't have to shop around for every little thing.. :spoton:
