fire wall lip cut out for distributor
jonesy
, Nov 25 2011 06:36 PM
9 replies to this topic
Posted 25 November 2011 - 06:36 PM
Hey just getting some research done for my build,
Can people please help to supply me with pics of the amount of fire wall that I will need to cut out to fit the distributor of a small block chev into lx hatch.
Ps this forum is great … thanks for all the help so far guys….
Posted 25 November 2011 - 08:18 PM
Depends on the dizzy and engine mounts
It doesn't actually NEED cutting on alot of cars
I'm sure pics are pending from those that have though
Posted 25 November 2011 - 08:29 PM
thanks for the response dattoman,
msd pro billet is the dizzy
Posted 26 November 2011 - 12:17 AM
I will be using tough mounts
_nial8r_
Posted 26 November 2011 - 10:10 AM
if you plonk the motor in without the dizzy on it you would be able to get a better measurment than just from pic's.
Posted 26 November 2011 - 11:10 AM
I have always cut the lip behind the dizzy with a Small or BBC (have done about 12). Better too much room than not enough.
I'm sure there are pics in my thread. Its the area just below the middle tag.
http://www.gmh-toran...__fromsearch__1
Will take another pic later today if you like.
_nial8r_
Posted 26 November 2011 - 12:19 PM
Did you just trim the rain gutter back flush Andrew or have you taken some of the firewall out also ??
Posted 26 November 2011 - 01:44 PM
As you can see there is heaps of room and it is not neccessary to go to this extreme.
I cut the lip right off then use a large cold chisel to tap the plenum back, almost flush with the firewall (there is almost a full inch of overhang here standard). I then lean in from behind (through the wiper cowl/plenum) and weld it from the inside. Lay another bead on the outside that you can sand back to look good. I then tapered the lip off from nothing to the full width on both sides.
The firewall as pictured will accommodate a BBC, should I ever want to go that way. For a SBC you really only need to grind/cut the lip off and weld it up.
Posted 27 November 2011 - 09:34 PM
pics if ya got them..
