steering stops with harrop arms
#1 _coil62_
Posted 25 November 2011 - 11:51 PM
have a couple off questions that hopefully somebody can help me out with.
1. have fitted hq discs,wb girlock calipers and harrop arms to uc k frame for my lx hatch.
the calipers are on the front of the stubs with the caliper bracket machined down to fit the tie rod to steering arm. how do you stop the caliper , mainly the brake line where it bolts to caliper from going in under where the spring sits and been torn off during suspension travel on full lock.? as there is no steering stop on these harrop arms.
2. with the hq stubs I've dropped the front end down a bit. what would be the best springs to put in the front end keeping it at a fairly standard ride height.? it will spend its life as a street car but i would still like it reasonably firm. also advice on rear springs would be appreciated. driveline will consist of 5litre t400 9inch rear with drop tank and 15 inch rims. if anyone can point me in the right direction on any of this it would be a great help
regards coil
Posted 26 November 2011 - 03:06 AM
I think you will find that full suspension travel at full lock is not possible. On full lock the front tyre should hit the guard long before the the suspension is on the bump stops. You would also have to wonder under what scenario you would actually bottom out the suspension when at full lock.
I have a similar setup but with tubular control arms. On full lock the Harrop steering arms just contact the lower control arm. I decided to reduce the steering rack travel on full lock by fitting a 10 mm spacer at each end of the rack.
The axle on the HQ stub is around 20 mm higher than the axle on the LX stub therefore the difference in ride height between the two if nothing else has been changed is 20 mm.
The most reliable way to get the exact ride height you want is to fit a set of springs and then get springs custom made based on the springs you fitted and the height difference you want. Custom made springs are not much more expensive than off the shelf springs. If you want something off the shelf then A9X springs would be a starting point.
Edited by ls2lxhatch, 26 November 2011 - 03:10 AM.
Posted 26 November 2011 - 10:40 AM
#4 _CHOPPER_
hello all.
#1 There were 4 different calipers fitted to HQ-WB Holdens. One of them fits with little trouble, I just can't remember which one.
#2 It wouldn't be much good to you, but I get my springs custom made in melbourne. The last pair cost me $130 and the first height reset is free. So if you install them and want the ride height altered by X amount, they will reset it once for free. After that they charge you.
Posted 26 November 2011 - 10:47 AM
as in the ones that look like the a9x that have the hose bolted to the side an had the artical done somewhere in these forums
Posted 26 November 2011 - 11:00 AM
Posted 26 November 2011 - 12:23 PM
#9 _coil62_
Posted 26 November 2011 - 01:17 PM
regards coil
#10 _coil62_
Posted 26 November 2011 - 01:50 PM
No thats something I did'nt think of ls2lxhatch.There would'nt be a picture of a genuine A9X caliper anywhere with the hose and nipple set up on it.So I can see what you mean?Have you considered moving the brake hose from the side to the top of the caliper as per the A9X.
regards coil
Posted 26 November 2011 - 02:40 PM
The simplest solution I have so far is to remove the rack boots and slip a wiring grommet with about a 22 mm inside diameter over the rack end and over the lock nut so it is crushed when the steering is turned full lock. Normally the rack travel is limited by the rod end lock nut.This method will reduce the travel around 5 mm for each grommet.
It is possible that the grommet on the drivers side could split and somehow work its way into the rack teeth but it seems rather unlikely. You will have to use your own judgement.
As I have disassembled the rack I will probably press a 10 mm nylon spacer into the rack tube at each end. It may be possible to make a similar nylon spacer with a slit in it that will allow it to be fitted over the rack while the rack is still assembled.
Photo by antelopeslr5000 from this thread
Edited by ls2lxhatch, 26 November 2011 - 02:50 PM.
Posted 26 November 2011 - 02:46 PM
Edited by ls2lxhatch, 26 November 2011 - 02:47 PM.
#13 _coil62_
Posted 12 December 2011 - 10:30 PM
Posted 13 December 2011 - 01:08 AM
The spacers with grub screws was one of the designs I considered. I also found that the rack steps up from the threaded section enough so a spacer that is a snug fit on the thread will not be able to slide past the threaded/machined section on the rack.
After experimenting with several designs I ended up machining up alloy spacers that are a snug fit in the steering rack housing and are held in with an internal c-clip.
Posted 13 December 2011 - 01:16 PM
Coil62, where did you get a torana rack with 4.5 turns lock to lock? What is that out of?
Posted 13 December 2011 - 03:17 PM
Posted 13 December 2011 - 08:45 PM
According to one of the parts manuals one of the racks 9940277 is listed as 25:1 which is about 4.5 turns lock to lock. I have a UC rack that is 9940277 but it is 3.25 turns lock to lock which works out around 18:1.
Edited by ls2lxhatch, 13 December 2011 - 08:47 PM.
Posted 13 December 2011 - 09:16 PM
What i am interrested in is if there is a difference in the rack and pinion ratio between UC and LX racks. I know they state different figures for the steering ratio, but they are very similar so this could be achieved with just the difference in steering arms. The only time I have ever directly swaped a rack LX to UC, I did a steering arm change as well so I couldn't compare just the rack ratios. I just need to know if there is a difference in number of teeth on the rack and number of teeth on the pinion. For no other reason than I like to know what options are out there.
Matt
#19 _coil62_
Posted 13 December 2011 - 10:22 PM
cheers coil
Posted 13 December 2011 - 11:15 PM
Matt
#21
Posted 13 December 2011 - 11:45 PM
9932244 (was 9942632) gear assy 20.4:1 also shows it as 18:1 exc A9X
92003971 gear assy 18:1 A9X
92001807 gear assy 25:1 A9X
According to REDA9X there are only two standard Torana rations 20.4:1 and the 18:1. There is apparently another two A9X ratios one of which may be 25:1.
Toranamatt posted that the steering is around 34 degrees in and 31 degress out for a total of 65 degrees. Using this figure we can calculate the following.
18:1 65 * 18.0 / 360 = 3.25 turns lock to lock.
20.4:1 65 * 20.4 / 360 = 3.68 turns lock to lock.
25:1 65 * 25.0 / 360 = 4.51 turns lock to lock.
I have seen my UC rack 9940277 is listed as 25:1 which should be 4.5 turns lock to lock. However my UC rack has 30 teeth and the pinion has 5 teeth as posted by coil62. I just checked it on the bench without arms and from factory rack stop to stop is was a little over 3.5 which again is the same a coil62 posted. I am not sure where I got the 3.25 from, it may have been that my steering arms hit before the rack stops due to steering alignment issues.
It looks like LH/LX racks will be 18:1 and UC will be 20.4:1.
Edited by ls2lxhatch, 13 December 2011 - 11:52 PM.
#22
Posted 14 December 2011 - 12:13 AM
#23
Posted 14 December 2011 - 08:27 AM
Edited by myss427, 14 December 2011 - 08:27 AM.
#24 _rob350hatch_
Posted 14 December 2011 - 05:31 PM
you asked about rear spring rate i just use 180lb for racing and i think about 250 for the road car but this is very stiff and causes the back to be uncomfortable on shitty roads ill be going back to standard i think or buying a kidney belt.
#25 _coil62_
Posted 15 December 2011 - 10:24 PM
regards coil
