V8 water pump
39 replies to this topic
#26 V-SLR5000-P
V-SLR5000-P
  • 1,311 posts
  • Car:L34 x 2
Posted 17 March 2018 - 08:34 AM
Genuine NOS impeller, curved blades
#27 Shiney005
  • 9,485 posts
  • Car:Toyota Mirai
Posted 17 March 2018 - 09:14 AM
this is the rear of an original Holden V8 pump with the cast impellor
Just getting back to RED's photo for a moment, at which model was the second heater hose outlet no longer required? ie. One is blocked off in the picture.
#28 MustardGTR
MustardGTR
  • 242 posts
  • Car:72 GTR, 73 GTR
Posted 17 March 2018 - 12:06 PM
Looks like the genuine 253/ 308 replacement impeller is very similar to the GMB I have.
Only notable differences between the two is GMH - 6 blades  and GMB - 8 blades. And also the GMH blades are laid back at a larger angle and the curve in the blade is more subtle.
#29 Dr Terry
Dr Terry
  • 3,316 posts
Posted 18 March 2018 - 07:22 AM
The second 'heater outlet' was added for ADR27A in July 76, but it was't actually for a heater hose. Because the 'pollution' motors ran about 10 degrees hotter than earlier engines the cooling systems were altered, for both 6 & V8 engines. A by-pass hose was added which ran from the water pump up to the thermostat housing.
All replacement pumps have the 2 outlets, so they supply a screw-in plug so that will fit early V8s, which have no by-pass hose.
Dr Terry
#30 Shiney005
  • 9,485 posts
  • Car:Toyota Mirai
Posted 18 March 2018 - 08:42 AM
Do you know when the steel plate was added? I only ask because the pump pictured below is a factory fitted post ADR27A LX Torana pump and it doesn't have it.
Attached File  308 factory lx.jpg   105.84K   8 downloads
#31 _arsewipe_
_arsewipe_
Posted 31 May 2018 - 06:11 AM
The change to the cooling system was that the inlet manifold was no longer heated with the water, it was now heated with the exhaust via the EGR system.
The Early engines still ran a thermostat bypass, but via the manifold, with the 3 way tap at the heater.
The engines have always had, and require, a thermostat bypass.
Dr Terry
#32 Dr Terry
Dr Terry
  • 3,316 posts
Posted 31 May 2018 - 11:09 AM
It is true that the inlet was no longer water heated, which was one of the reasons that the plumbing was changed. However on early cars HT & HG (& export cars) which had no heater, the hose fittings were blocked off & there was no thermostat by-pass, very similar to EH & HD 6-cyl red motors.
Dr Terry
#33 _arsewipe_
_arsewipe_
Posted 05 June 2018 - 10:11 AM
Pardon my saying this, as I do bow to your knowledge, (much respect).
But they still ran a bypass through the manifold..
The systems MUST have a bypass,if you do not run a bypass hose, when the thermostat is closed, you get no water flow, which will:
A: Prevent the hot water being circulated to the thermostat to open it on time.
B: Create Hot spots via not having the water circulating, and
C: Cavitate the water pump as it is trying to pump water, that cannot go anywhere.
I have a Pic of the first 253, showing the manifold heated via the thermostat outlet, with no heater, but bypassing the thermostat, and returning to the water pump..
Again, much respect, but the system MUST run a bypass..
#34 TerrA LX
Posted 05 June 2018 - 02:45 PM
Maybe there is confusion as the "by pass" as such was part of the heater plumbing?
#35 Dr Terry
Dr Terry
  • 3,316 posts
Posted 05 June 2018 - 04:34 PM
While it is true that it is more desirable to have a by-pass, especially for the reasons that you have posted, there are many engines which do not have one.
The original Holden Grey does not, nor do the 149 & 179 Red motors. HR onwards do have a water heated manifold, so they do get a by-pass. LJ XU1s miss out as well. 6-cyl Falcons up to & including the 4.1 Alloy head were the same, however all V8s back to the mid-60s did get one.
Dr Terry
#36 _arsewipe_
_arsewipe_
Posted 09 June 2018 - 07:10 PM
fair point.
I did not realise that the Fraud did not run a bypass, especially with the alloy head,
I'm scratching my head over that, wondering how they managed to have the thermostat operate correctly, and prevent hot spots, without water circulating
I was unable to post a pic of the HT 253 showing the bypass hose on the drivers side of the water pump, but did manage to upload it into my garage with the pics of my Torana.
#37 _arsewipe_
_arsewipe_
Posted 10 June 2018 - 07:27 PM
Just a quick question though.
Did the 149, and 179 run a water heated inlet manifold?
Dr Terry
#38 _1965mjr_
_1965mjr_
Posted 10 June 2018 - 07:44 PM
Eh Holden 149/179 had no heated intake.
#39 _arsewipe_
_arsewipe_
Posted 10 June 2018 - 07:51 PM
My original comment and point was tho, that the V8's do.
#40 Dr Terry
Dr Terry
  • 3,316 posts
Posted 11 June 2018 - 09:47 AM
Yes they do, it's just not water heated. Both Grey motors & the early Reds (149/179) have their intake manifold heated by heat from the exhaust manifold.
HR to HJ Reds & HT to HJ Holden V8s have water heated intakes & then they reverted to exhaust heating for HX onwards (ADR27A) motors.
Dr Terry
