kick down wires and inhibator switch wires
wires
2 replies to this topic
#1 _TOWEY LH SLR_
_TOWEY LH SLR_
Posted 13 December 2011 - 08:55 PM
hi my torana was a manual but now auto im have trouble working out where the orange wires go for the kick down and also have the problem of where the inhibator switch wires where they go from the tbar ? if some one could help it would be very apreciative thanks
Edited by TOWEY LH SLR, 13 December 2011 - 08:55 PM.
#2 S pack
  • 15,726 posts
Posted 13 December 2011 - 09:16 PM
http://www.gmh-torana.com.au/forums/topic/56348-lx-wiring-diagram-please/
#3 _torbirdie_
_torbirdie_
Posted 14 December 2011 - 05:50 PM
I doubt you will find any wires to run to the inhibitor switch on your tbar. The wiring diagram shows the wire going to the starter solenoid as a straight through wire in the manual setup You will have to cut into the solenoid purple wire, either on the interior side or engine side of firewall, and using extra wire run the ends to your inhibitor switch so it controls when the solenoid can be activated.
In regards to the kickdown switch for the auto, it would appear that there is no dual orange connector already there near the accelerator bracket?, (I never noticed whether they included it there on the manual torries Ive owned) All you need to do is add another wire to the "tell tales/backup" terminal on the fuse panel and run this to the switch on the accelerator bracket, then run the wire from the switch to the tranny.
Edited by torbirdie, 14 December 2011 - 05:51 PM.
