K-Frame legs: Detail on bolts attaching to side member needed
43 replies to this topic
#1 Tyre biter
Tyre biter
  • 982 posts
  • Car:Should have gone with Palais...
Posted 22 January 2012 - 08:50 AM
Ok, it appears I am missing the bolts that secure the K-Frame 'legs' to the 'side member' (the bit either side of the chassis rails adjacent to the transmission tunnel).
I've had a look at the LX Parts Calalogue (Page 374) and think P/N 272404 are the bolts I am after - refer View A in top left corner of page.
In the absence of being able to walk into my dealer and get these parts nowadays, I need a bit of help from anyone familiar with the whole mount please. I hope to then get something close from my local fastener shop;
a.The bolts are 5/8 right?
b. How long should they be?
c. Are the bolts threaded the entire length or smooth for a portion?
d. What grade tensile are they?
e. It seems there are two sets of washers - P/N 120389 and P/N 7205937 (labelled as '2' in the image). Appart from having to fit a 5/8" bolt - how big are they?
Any photos would be great, but I'll take any advice I can get right now.
Thanks in advance for your help.
Cheers, TB
#2 hanra
  • 10,975 posts
Posted 22 January 2012 - 08:53 AM
Mate mine are laying on the bench, I cleaned them up last night. I'll get some details for you when I get out of bed.
#3 hanra
  • 10,975 posts
Posted 22 January 2012 - 09:56 AM
This help?
#4 _My74LH_
_My74LH_
Posted 22 January 2012 - 11:28 AM
From left to right is the 3rd one along a 4mm thick washer ?
#5 hanra
  • 10,975 posts
Posted 22 January 2012 - 11:39 AM
Id have to measure it, but yes its quite thick.
#6 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 22 January 2012 - 01:17 PM
Bolts are measured from the bottom of the head.
#7 Tyre biter
Tyre biter
  • 982 posts
Posted 22 January 2012 - 03:07 PM
Brad (hanra) - that is perfect - exactly what I need - thank you.
My74LH & Toranamat69 - thanks for the tips.
Cheers, TB
#8 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 22 January 2012 - 03:44 PM
I don't have any spare bolts here but the hole in the metal sleeve of the bush is only 10.9mm so the bolt is not 5/8" - that would be 15.9mm OD. 7/16 is still too big at 11.13mm so I would have a stab and say these bolts would be 3/8 UNC. That looks about right from the picture with the ruler above. Socket size is not directly related to bolt OD.
I would try to get them in Passivated zinc high tensile if I were you are because I reckon that would be what the originals are (or should be at least).
Matt
#9 76lxhatch
  • 7,207 posts
Posted 22 January 2012 - 05:09 PM
The thread is 7/16" UNC. The bolt head is 5/8" and has a large shoulder on it, the nut is 11/16" (the ones above don't look like factory ones)
#10 ls2lxhatch
  • 5,332 posts
Posted 22 January 2012 - 05:26 PM
+1.
I am a bit confused as to which way round the k-frame leg bush is fitted. The parts manual picture above appears to show it the wrong way round.
Edited by ls2lxhatch, 22 January 2012 - 05:31 PM.
#11 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 22 January 2012 - 05:51 PM
I wanted to say 7/16" but the LC (looks like they are the same OD) the one I just measured the thread OD was 10.9mm - maybe it is a bit worn from the conelock nut winding on and off.
#12 hanra
  • 10,975 posts
Posted 22 January 2012 - 07:48 PM
Unsure if mine are original or not???
#13 76lxhatch
  • 7,207 posts
Posted 23 January 2012 - 08:29 AM
The ones in ls2lxhatch's pic are original - that's not a washer under the head, its part of the bolt head
#14 ls2lxhatch
  • 5,332 posts
Posted 23 January 2012 - 10:08 AM
The UC parts manual shows the leg bush fitted correctly. The LH and LX parts manuals are wrong.
#15 Tyre biter
Tyre biter
  • 982 posts
Posted 23 January 2012 - 10:58 AM
Thanks eveyone - I'll head try to get to my fastener store today and get 7/8 bolts and 3/8 bolts with bits - will let you know how it goes.
Cheers, TB
#16 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 23 January 2012 - 11:31 AM
I think you will find mate CB has some bolts cleaned up already to go for you. Check with him first.
Gez
#17 Statler
  • 6,317 posts
Posted 23 January 2012 - 11:36 AM
The factory bolts are too long.
#18 76lxhatch
  • 7,207 posts
Posted 23 January 2012 - 11:59 AM
The ones up front have a bit of extra length too, a safety thing perhaps...?
#19 Tyre biter
Tyre biter
  • 982 posts
Posted 23 January 2012 - 10:19 PM
Gez
Hi mate,
God bless CB - truely a bloody gentleman but I only just saw this now and I'm sorry to learn, as I have gotten the bolts from Specialty Fasteners already. They didn't come cheap either, but I visited Fyshwick in company with the bride today on the premise we were looking at some furniture and wouldn't you know it, we just happened upon the shop where I could dash in to grab something...
Back to the thread; with regards to what fits or not; As indicated earlier, I got both 3/8 and 7/16 bolts and have found the 7/16 to fit like a finger in... a glove!
Pity it fits so well really, because I can't for the life of me get the drive's side in - just can't get it to line up front to rear and given the car is on rudimentary stands, there isn't a lot of 'purchase' to pull the K-Frame forwards from the body. I'll keep trying though, have a bit of a think on how to tweak it and for sure it will sort out, Doesn't really matter right now in any case as I'm spendng the next few days building a deck with my F-I-L and so the Banana will have to wait at while - maybe in the interim the Torrie fairies might visit and align the two holes for me...or, maybe not :nada:
Cheers, TB
#20 ls2lxhatch
  • 5,332 posts
Posted 24 January 2012 - 03:05 AM
I use a tapered bolt ground off centre to align the leg bolts. The bolt is extra long because I have a CRS chassis kit.
More pictures and tips for fitting the k-frame here.
#21 Tyre biter
Tyre biter
  • 982 posts
Posted 24 January 2012 - 09:57 PM
Thanks for that - sorry to report that link you gave me is just to a larger pic of the same image.
However I think I get what you are suggesting; a long rod through the holes and then used as a lever to align the two holes?
I've had no more luck tonight with a 8" bolt - even loosened the top bolts and even hitched the k-frame to my ute via the old Telstra rope with truckies hitch to no luck.
I'll find myself a longer rod and give it another go tomorrow if I get a moment.
Thanks again and cheers, TB
#22 ls2lxhatch
  • 5,332 posts
Posted 24 January 2012 - 10:00 PM
Try this link
#23 _My74LH_
_My74LH_
Posted 27 January 2012 - 08:57 AM
Ok so found my chassis bolts and oater a quick blast ready for zinc here they are .
#24 ls2lxhatch
  • 5,332 posts
Posted 27 January 2012 - 10:32 AM
Those bolts look very similar to the LX bolts.
It appears that the early bolts had a seperate washer for the head and the later bolts incorporated the washer.
#25 Tyre biter
Tyre biter
  • 982 posts
Posted 29 January 2012 - 04:05 PM
Thanks guys - much appeciated.
The good news is that I got the troublesome driver's side bolt in this afternoon!
I tried all the suggestions above but couldn't get the holes to line up by leveraging them and so in the end I got 'creative' with the disc grinder on the end of the bolt, a wee tap with a 2lb hammer and voila!
I even remembered to re-tighten the top K-Frame bolts - I'd normaly say this outcome would suggest that I am learning but alas, like many of my jobs on the car so far, I had to repeat this one as I forgot to put the washers on the bolt after grinding it pointy...
Oh, and ls2lxhatch - that link is a ripper, especially for a noob like me - thanks.
Cheers, TB
