-Max engine size for LX Hatchback in QLD
_76BLO_
Posted 29 January 2012 - 09:33 PM
What is the basic ruling and what is the max cubic inch can one go????????
Thinking of going for a 434 or 500 small block BIG PAW option
_Liam_
Posted 29 January 2012 - 09:38 PM
_Big T_
Posted 29 January 2012 - 10:04 PM
_Big T_
Posted 29 January 2012 - 10:29 PM
Code of Practice for Light Vehicle Modifications found here http://www.tmr.qld.g...sreductions.pdf
Page 31
Section LA
2.3 Schedule B
Original weight (tare) in kg's x .294 (for mono constructed) gives maximum replacement engine size in cubic inches (naturally aspirated)
Tare weight figures for LX Hatch seem to vary between 1209kg and 1213 kg as per
http://www.gmh-toran...ck-tare-weight/
So based on the highest tare weight of 1213kg the max ci naturally aspirated for an LX hatch appears to be 356 ci
Best to speak to TMR and a couple of engineers though. Nothing beats hearing the correct information straight from the horses mouth.
Posted 29 January 2012 - 10:36 PM
In theory you should be able to use this figure as it is the heaviest sedan version of the model. Section 2.3.1.4
_Big T_
Posted 29 January 2012 - 11:04 PM
LS2 - Can you point me to a credible or verified resource that quotes the 1306kg figure please? It will be very handy
Cheers,
T
Posted 30 January 2012 - 02:00 AM
There a lots of discrenpencies in the kerb weight figures that I can not explain. For example there is 45 kg difference between the LX pre-RTS and RTS SL/R 5000.
LH SL/R 5000 is 1236 kg.
LX SL/R 5000 is 1236 kg.
LX RTS SL/R 5000 is 1281 kg.
The WA rego authorities have 1204 kg for the Torana. This appears to the the pre-RTS SL 6 cyl hatchback.
Posted 30 January 2012 - 06:59 AM
Virtually all of my figures come from GM-H literature, the few exceptions are where I've used CAMS homologation paperwork.
I can't explain some of the discrepancies either, some don't make sense, some I believe may be GM-H errors.
A possible reason for the differences in the LX SL/R 5000 figures, would be what is not mentioned. The first batch of LXs were virtually identical to the LH version (so they just publish the same weight). In July 76 ADR27A was introduced, which added quite a few small items. On there own they don't weight much, but if you add all of the small electrical switches, vacuum valves, EGR valves, exhaust vacuum flaps & extra wiring & plumbing this could add say 10-15 kg. By 1977 they added a larger heavier brake master cylinder (it was cast iron remember) & side intrusion bars in the doors. For the RTS upgrade, the shocks & springs were all slightly thicker & heavier but the heaviest add-on would have been the rear stabiliser bar & fittings. Another 25-30kg easily.
I'm sure all of this could amount to 45 kg. But as you can see, it's not just the result of the RTS.
The L34 & A9X weights came from CAMS literature.
Dr Terry
_76BLO_
Posted 30 January 2012 - 07:06 AM
When we talk tare weight of a vehicle dose the ADR take into account new engines ie the light weight billot or alum??
Australia needs to standardise laws.
Anyone know of an exceptional engineer in the Mackay area??????
_Liam_
Posted 30 January 2012 - 09:28 AM
Thanks guys guess i need to speak to the man that kinda dont like me or the car.
No it's the weight of the vehicle in its standard form. You can put as much weight, or take as much weight off as you want.
Posted 30 January 2012 - 11:09 AM
Hi Guys.
Dr Terry
Thanks for the explanation Dr Terry, it makes more sense when you consider the ADR changes around the time of the release of the RTS Torana.
Do you still have access to any official documentation regarding the L34 or A9X weights should a rego authority want more information?
Posted 30 January 2012 - 11:10 AM
Edited by Redslur, 30 January 2012 - 11:11 AM.
Posted 30 January 2012 - 12:46 PM
Posted 30 January 2012 - 03:51 PM
spoken to engineer he says if cars weight is under 1100kg you multiply by 4
and if over you multiply by 5, and it gives you a litre capacity
but the weight varys ,trying to put small block chev in one
Phil
_Liam_
Posted 30 January 2012 - 07:30 PM
Posted 30 January 2012 - 07:57 PM
Derek Clapton Automotive will be your best bet! He does the pre-inspection work for a Townsville based consultant.
The D.O.T will give you a printout of all the consulting engineers in the district & the mods [codes] they can approve.
_rob350hatch_
Posted 30 January 2012 - 08:33 PM
my lh slr replica 1435kg.
my red hatch 1438kg
_Liam_
Posted 30 January 2012 - 09:00 PM
_LXSS350_
Posted 31 January 2012 - 12:33 AM
#21
_AD_75_
Posted 31 January 2012 - 01:24 PM
#22
_sbchatch_
Posted 02 May 2012 - 03:03 PM
Edited by sbchatch, 02 May 2012 - 03:04 PM.
