Posted 30 January 2012 - 05:25 PM
Going to put aircon in the project 4 door.
Any Makes/Models to look out for
Any experiences recently
Any suggestions
Anything ?
Ta
Posted 30 January 2012 - 05:35 PM
Or copy what Jeff did in his hatch
Posted 30 January 2012 - 07:40 PM
Which Vintage air model best suits and where is jeffs link?
Posted 30 January 2012 - 07:57 PM
Posted 30 January 2012 - 08:19 PM
I cant remember where I saw it but looked like a great replacement for the old torana heater box.
Anyone else got info?
Posted 30 January 2012 - 08:53 PM
Factory Air in LX has vac controls and 4 speed fan, not sure about UC but as the dash is different cant see that UC setup would swap over as direct replacement, could be wrong on the last point? only my opinion.What about original integrated. UC 6cyl is the same as LH-LX V8. Even the control switch is the same, just has a different mounting.
#7 _Greg313662_
Posted 30 January 2012 - 09:12 PM
Anyway here's a couple of pics....
Posted 30 January 2012 - 09:35 PM
http://www.ebay.com....aa#ht_646wt_983
http://www.gmh-toran...ia/page__st__75
That thread has a lot of good info in it
If a yank can do it... so can we
#9 _1uzbt1_
Posted 30 January 2012 - 10:38 PM
What height do yu have between the trans tunnel and the Plenum? Most oe hvac units are around 400 mm high which is why nothing I've found so far fits in a q, it has only 200mm.
Edited by 1uzbt1, 30 January 2012 - 10:41 PM.
Posted 30 January 2012 - 10:46 PM
#11 _LS1 Hatch_
Posted 31 January 2012 - 01:36 AM
Not quite sure how to take that....
Oh, and just holler with any questions. I am really happy with how the air turned out, and it works excellent as well. (still working too so guess all the lines I made and crimped myself aren't leaking...lol)
Edited by LS1 Hatch, 31 January 2012 - 01:46 AM.
Posted 31 January 2012 - 02:33 AM
I have had three different systems on my hatch over the years.
The first used the standard under dash A/C mounted under the glove box with an extension to the middle of the car. Similar to this for the post above. This style was still available a couple of years ago. This worked fine but in my opinion it takes up to much space in the passenger compartment.
The second system I had used an aftermarket A/C evaporator from a HJ mounted in front of the standard fan under the glove box. I basically removed the plastic elbow and fitted the evaporator in its place. The fan sucked though the evaporator instead of from the plenum chamber. This worked ok but the air was heated as it went through the duct in the engine bay. If you fit a system to blow through the factory heater box then you will need to seal the factory heater box and fit drains. Eventually even with the drains the standard heater box suffered from condensation mould was a problem. Passenger legroom was improved and the evaporator was not as obvious as the first system.
The current plan uses a modified under dash heat and cool.The good points are that it does not interfere with the passenger compartment and you can toss the factory heater and fan ducting. I made an extension between the evaporator and the vents so I could mount the demister ducts. It was a Hot Rod Air Heat and Cool 50-00007 although I think they have folded. Vintage air have something similar as do a few other manufacturers. It could be made to work with the hatch style console but I prefer the sedan style console.
Edited by ls2lxhatch, 31 January 2012 - 02:40 AM.
Posted 31 January 2012 - 05:12 AM
They are basically identical. LH-LX 6cyl was different to the V8 setup on the evaporator housing under the bonnet. UC is the same as LH-LX V8. The only bit diffrerent inside is the fascia of the controller in the dash. I can't remember if the ducting is totally the same but there isn't much difference.
Edited by yel327, 31 January 2012 - 05:12 AM.
#14 _torbirdie_
Posted 31 January 2012 - 07:42 AM
The OP might consider removing the internals of the glovebox to get more room for whatever system they use, one can always find somewhere else to store the few bits of junk you put in there. Also remove the air duct for the left hand dash ventilation vent(block off at plenum) will give more room and wont be necessary if one has air.
The factory integrated systems didnt use the side dash vents for these either, only the central unit which allowed either flow to the floor, screen or centre vents.
Willing to be corrected here, but the factory systems did not have any drain coming from the heater box, only from under the condensor.
The key to avoiding mould,/dampness in any ac system is to not run the system then not use it for days on end. Good practice should be to switch off the compressor and run the fan at full speed with fresh air for at least 3 or 4 mins before shutting the system down for any length of time over 12 hours or more..
The fact systems also didnt have the evaporators hover near the freezing mark like the aftermarket cycling units do and were less prone to producing condensation
Its just the "hard to find" and the "30+ years old" factor that makes me mention the Vintage air system: datto
Very valid point, and given the OP has a project with an unknown engine arrangement, fitting the factory airbox could be a problem. The other concern is that getting the fact systems to work effectively on r134A refrigerant is a fine art and indeed if any of the working needs repair there aren't any people in this country that have the knowledge to do it. The newer generic systems are more simple and understood by most car aircon places.
AFAIK everything is the same except that the control panel is mounted on the right hand side of the steering column for LX/LH, this would obviously mean that if using the original looms and vac hoses that some may not reach the relevant points, but could be easily fixed with more wire/tubing.
The more problematical item would be the cable that controls the flap for screen floor and centre, a longer cable would most likely be needed if using UC controls for LH, but the existing cable on the non ac LH unit should just be a direct swap over.
Edited by torbirdie, 31 January 2012 - 07:52 AM.
#15 _LS1 Hatch_
Posted 31 January 2012 - 08:12 AM
I didn't bother with trying to squeeze and a/c-heater unit under the center of the dash, since figured how I mounted it still gives plenty of leg room on the passenger side, and I just used the area in front of the console for the ECM and some other things. I made my own center duct plenum and so the console looks pretty stock where the original vents went. Then aside from blowing out there, mine also feeds both sides of the fresh air dash vents, plus of course defrost when switched over as well.
#16 _Liam_
Posted 31 January 2012 - 09:46 AM
http://speedyairspares.com.au/
#17 _torbirdie_
Posted 31 January 2012 - 11:33 AM
Brain fade: the directional flaps are controlled by vac servos, now whats the cablee do? from memory its a flap that varies the amount of air that goes through the heater core, which is basically the heat lever control.
Posted 31 January 2012 - 02:07 PM
#19 _The Baron_
Posted 31 January 2012 - 04:04 PM
The arrangement in the engine bay is like the normal aftermarket arrangement with the compressor on the passenger side. Lots of ugly rubber hoses and crap.
Posted 31 January 2012 - 08:12 PM
The dealer unit originally fitted to my car, replaces JUST the plenum elbow under the glove box. It is the neatest one I have ever seen within the car.
My friend had one like that too on his 6cyl which I kept. There was a plastic cover that covered the plenum hole, the unit sat in front of the fan intake.
There is a small panel with thermostat control that screwed under the dash.
Important to this setup was a plastic cover with insulation that went over the fan assembly in the engine bay to insulate the engine heat from the cold air passing to the heater box.
The only problem I saw with this setup was, it didnt have a heater tap.
#21
Posted 05 February 2012 - 09:12 AM
Clearly some further research needed.
