cubic inch formula
13 replies to this topic
#1 zodiac GTR
zodiac GTR
  • 171 posts
  • Car:73 GTR
Posted 03 February 2012 - 07:37 PM
does anybody know the formula to work out how many cubes you can put in to your car ? (in Victoria )
weight x ?
#2 _Liam_
_Liam_
Posted 03 February 2012 - 07:44 PM
Heaviest weight for your model, in kgs x .294.
#3 zodiac GTR
zodiac GTR
  • 171 posts
  • Car:73 GTR
Posted 03 February 2012 - 07:53 PM
is that for victoria as well , I heard things might have changed but am not sure.
thanks
#4 zodiac GTR
zodiac GTR
  • 171 posts
  • Car:73 GTR
Posted 03 February 2012 - 09:10 PM
found this
VERSION 2.0 JANUARY 2011
Table LA1 Recommended Maximum Engine Capacity
MASS OF VEHICLE
Maximum Engine Capacity (refer to notes below)
Naturally Aspirated Turbo/Supercharged
All vehicles originally weighing
less than 800 kg.
Original mass (kg) x 3.0
= max. capacity in cc’s
Original mass (kg) x 2.5
between 800 kg and 1100 kg.
Original mass (kg) x 4.0
Original mass (kg) x 2.75
more than 1100 kg.
Original mass (kg) x 5.0
so if someone could tell me which 1973 LJ is the heaviest ,that would be great.
I googled it and there are to many variations,
one shows that the 73 Bathurst XU1 to be over 1100Kg.
so if anyone has some documentation to show this that would be great.
thank you
#5 ls2lxhatch
  • 5,332 posts
Posted 03 February 2012 - 09:28 PM
60 Years of Holden by Terry Bebbington aka Dr Terry pg 336.
LC GTR XU1 1102 kg
LJ GTR XU1 1096 kg
In theory you should be able to use the LC weight which just gets you into the next category.
#6 zodiac GTR
zodiac GTR
  • 171 posts
  • Car:73 GTR
Posted 03 February 2012 - 09:38 PM
tried to copy and paste the graph but it came up as text, so it probably doesn't make much sense(its all mixed up )
Edited by zodiac GTR, 03 February 2012 - 09:51 PM.
#7 zodiac GTR
zodiac GTR
  • 171 posts
  • Car:73 GTR
Posted 03 February 2012 - 10:16 PM
I don't know what happened there ?
#8 ls2lxhatch
  • 5,332 posts
Posted 03 February 2012 - 11:06 PM
Looks like this table from the NCOP. Don't know if that applies in VIC. It makes quite a difference if they will accept the LC GTR XU1 weight.
Edited by ls2lxhatch, 03 February 2012 - 11:08 PM.
#9 zodiac GTR
zodiac GTR
  • 171 posts
  • Car:73 GTR
Posted 03 February 2012 - 11:37 PM
that's it , thank you.
spoke to a engineer today,told me that on his guide it had 1064Kg for LJ torana and told me to look for a greater variant in the series.
just trying to find something to show vicroads and the engineer the variant that proves to be over 1100Kg.
would 60 Years of Holden by Terry Bebbington ,cary any wait on this mater ? or do I dig deeper ?
any help would be great
#10 ls2lxhatch
  • 5,332 posts
Posted 03 February 2012 - 11:50 PM
Buy the book and it should do the job :) You can check with the author as he is a member here.
Apparently the figures in the book are from either GMH documents or CAMS documents.
Edited by ls2lxhatch, 03 February 2012 - 11:51 PM.
#11 zodiac GTR
zodiac GTR
  • 171 posts
  • Car:73 GTR
Posted 04 February 2012 - 12:00 AM
book is first on my list , cheers
is there something that GMH could help me with ?
Edited by zodiac GTR, 04 February 2012 - 12:06 AM.
#12 ls2lxhatch
  • 5,332 posts
Posted 04 February 2012 - 12:35 AM
It would probably be quicker/simpler to talk to Dr Terry and your engineer. Hopefully the book is enough.
The book also has other specifications that come in handy for engineering modifications.
Edited by ls2lxhatch, 04 February 2012 - 12:39 AM.
#13 ls2lxhatch
  • 5,332 posts
Posted 09 February 2012 - 02:40 PM
Edited by ls2lxhatch, 09 February 2012 - 02:40 PM.
#14 _Muttley_
_Muttley_
Posted 03 November 2013 - 10:01 PM
hi i will check all of the manuals, bulletins, technical letters and engineering documents that might be held at the victorian automobile chamber of commerce.
They have nearly every publication released since 1917 ,i was a employee in their technical research department,  theyre library is bigger than most local libraries, i will be going in next week and will try find documents with weights over the 1100kg mark. I need to get this for my upcoming project. will keep you posted.
forgive the punctuation, i hate typing on a mobile
