350 Chev in LX Hatch
_v8toyota_
Posted 22 March 2012 - 06:04 PM
Posted 22 March 2012 - 06:13 PM
Hope this helps.
_LXSS350_
Posted 22 March 2012 - 06:18 PM
Just buy a set of appropriate engine mounts.
Very common engine swap.
Haven't brought or have an opinion about these companies, but gives you some mount options and info (a starting point).
http://velocityauto....ategory&path=59
http://www.rodshop.com.au/
_v8toyota_
Posted 22 March 2012 - 08:56 PM
Yer I need to get hold of another K Frame as it originally had an opel motor. Been told that a UC K Frame is a better option as it doesnt require the shims.
Is there any difference in the sump setup or will a standard 350 sump slot straight in?
_434LX_
Posted 22 March 2012 - 09:05 PM
Cheers for those links..
Hi Jason,
I have just gone through this setup in the last couple of months.
I used tuff mounts ->http://velocityauto....9&product_id=92
and a 350 vortech crate motor to get the ball rolling. Its a one piece rear main type sump.
Bolted straight to the k-frame with no issues. I have also removed part of the upper lip where the dizzy will sit (just in case).
Andrew
_LXSS350_
Posted 22 March 2012 - 10:08 PM
Few eg
http://www.ebay.com....=item4aad607a5c
http://www.rodshop.com.au/sumps.htm
_the gts_
Posted 23 March 2012 - 03:07 PM
I would get an LX RTS k frame it has the lower bolt holes and then use the UC upper control arm with the offset ball joint.
If you are going to go very serious and need big pipes then you also need to modify any K frame you get and thin the arms that go back to chassis. if you need pics of that pm me your email address
Posted 23 March 2012 - 07:53 PM
I think if you check CRS website they might still do the brackets to mount the Chev onto that frame still ... they used too
_v8toyota_
Posted 24 March 2012 - 08:12 AM
I think i will go the option that "the gts" suggested as I allready have an LX RTS frame. I will have to hunt down some UC upper control arms. Just waiting for a reply from CRS in regards to the adapters for the chev. I allready have the HQ stubs/discs with the harrop arms setup. So hopefully this setup will work.
Are all UC upper control arms offset?
Posted 24 March 2012 - 04:12 PM
Thats why everyone wants them
_v8toyota_
Posted 24 March 2012 - 08:28 PM
_the gts_
Posted 25 March 2012 - 11:14 AM
I am hoping for around 550hp with mine and I only have 1.3/4 primaries. what you need to remember is that you also have a starter on the drivers side.
Oh yea get a mini Hig torque starter. dont waste your time with any of the cheap brands just get a CVR. its a head f*ck to pull a starter out.
Also the best way i have found to fit the engine is by bolting it to the K frame and then lifting the body over the top. I can have mine out in about 2 hours now!
_v8toyota_
Posted 25 March 2012 - 03:04 PM
_the gts_
Posted 25 March 2012 - 03:42 PM
If you are in Perth go and visit Domenic from Prestige exhaust.
yes i have a modified chassis. Check out the car on the links i emailed you.
You may want to consider the fact that you will have difficulty getting 3" pipes down to the legal noise level though!
_LXSS350_
Posted 27 March 2012 - 01:26 AM
Everyone inc myself have different ideas of what we will do or will not do and what we want to acheive. Never can't have enough options imo.
Some images (might help you) of some solutions that Torana owners have used.
_AD_75_
Posted 27 March 2012 - 03:23 PM
The better way to do it is to scallop the K frame as some of the above pictures show and then to trim down the frame rails in the engine bay which is a legal mod and will give you more room for the header pipes.
This is a forum members car showing trimmed frame rails in engine bay.
_LXSS350_
Posted 27 March 2012 - 05:59 PM
I don't advocate any as none are mine. Personally for a hot chev street motor in LH-LX I would never use anything bigger than a 1 5/8 Tri-Y. Never in my life have I trimmed Kframe or any other part to fit them up.
For the race cars I always use 4 into 1's that are dyno tuned to engine specs. But front ends are all chrome moly tube and coil-overs. So nothing is Torana and can't be applied to any road licensed Torana.
_v8toyota_
Posted 27 March 2012 - 09:03 PM
Coz at the moment, if Ive gotta chop the front end, the 350 will be slotted to the back of the shed and i will build 308 stroker which was my first option.
Appreciate all the input so far..
_T0rana_
Posted 27 March 2012 - 11:04 PM
_T0rana_
Posted 27 March 2012 - 11:06 PM
had to get chev into torana sump,gearbox cross member,v8 eng mounts,extractors fit without mods,needed small starter motor,and best to use a small dizzy
#21
_LXSS350_
Posted 28 March 2012 - 02:59 AM
By doing it yourself (if no luck finding a good exhaust guy) its easy enough to get it spot on, really neat and tight. It takes many hours getting it tacked and sorted so if you don't have patience, start finding that elusive custom exhaust guy. The biggest primaries I have ever used in a street LX was 1 3/4 in a Tri-Y config, but most have been 1 5/8. This is because for real street use I prefer not to sacrifice low-mid range torque. Engines used into LH/LX have been 350-383-400 ranging between 400-580Hp with most engines being built to have max hp just under 6000rpm limit. I try to get max torque in by around 4500rpm.
Regardless of which v8, its tight in a Torana, so like any bolt on room saving solution I always use a rotatable small gear reduction starter for flexibility.
I move the engine forward a smidge on the mount adaptors. How much depends on the size of the distributor used, but by getting clearance this way is neater than something like the image below as I prefer not to cut the car. Specifically if its a genuine V8 SS. Don't mind cutting an SL for racing.
You can buy all the exhaust bits you need from place like difilippo, dkne etc
http://www.darrendif...au/diykits.html
http://www.dkne.com....ds-c-27_28.html
Edited by LXSS350, 28 March 2012 - 03:02 AM.
#22
_LXSS350_
Posted 28 March 2012 - 03:20 AM
http://www.gmh-toran...o-fit-v8-dizzy/
Found an old thread about the big 4 - 1 pipes above that you might find interesting reading and helpful.
http://www.gmh-torana.com.au/forums/topic/22779-castle-autos-extractors/page__view__findpost__p__237153
Edited by LXSS350, 28 March 2012 - 03:30 AM.
#23
Posted 28 March 2012 - 06:42 AM
For any street SBC Torana the Hurricane 4:1 1 5/8" pipes that T0rana has in both the red and black/chrome engine bays are sufficient and bolt in with no modifications. If you make more than about 300 HP then it pays to cut off the 2 1/8" collector and replace it with 2 1/2". This got my UC to an 11.0 quarter so they aren't too bad.
FWIW I would think an engineer would be more concerned about someone modifying the K frame than cutting a hole in an inner guard.
JMHO
#24
Posted 28 March 2012 - 06:54 AM
#25
_T0rana_
Posted 28 March 2012 - 09:55 AM
