lxv8 sedam wiring
32 replies to this topic
#1 _Torana Affair_
_Torana Affair_
Posted 19 May 2012 - 04:37 PM
Hey all , anyone have the wiring manual on pdf there able to send ?
also chasing 304i wiring .... want some back up while i wire up new motor in lx
thanks in advance
#2 _Torana Affair_
_Torana Affair_
Posted 19 May 2012 - 06:20 PM
Wonder if any one else who's done this has drawn a schematic ???
I go out to shed to make a start , scratch my head , have a smoke , scratch my ass ...... and stare at the wires going OMFG.....
hmmmmm
#3 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
  • Car:LXSS, VUSS, VESSv & the mighty HB
Posted 19 May 2012 - 07:23 PM
Well thats me done.
Cheers, Captian Obvious.
#4 _Torana Affair_
_Torana Affair_
Posted 19 May 2012 - 08:11 PM
great work paul............ ya need my address or ya got it ???
:nada:
#5 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
Posted 19 May 2012 - 09:06 PM
lol.
#6 _Torana Affair_
_Torana Affair_
Posted 19 May 2012 - 09:58 PM
getting there......... found this http://www.memcals.c...ing Diagram.pdf
#7 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
Posted 19 May 2012 - 10:04 PM
Thank god its got a colour code... lol
#8 _Torana Affair_
_Torana Affair_
Posted 19 May 2012 - 10:13 PM
found it from the following site , def think it will save thousands if not millions of fellow members hair follicles
http://www.memcals.com/
well did you notice Dl = dark blue ..... :mellow:
#9 _Torana Affair_
_Torana Affair_
Posted 20 May 2012 - 01:59 PM
hey does anyone know if you just leave the wires cut off that won't be used on the torana from vq wiring harness from ecu?
#10 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 20 May 2012 - 02:24 PM
This - http://osp.metrohost...o/VNharness.jpg was drawn up when we put a V6 in my brothers kombi, the V8 harness is almost identical. I'm working on one for the UC but its not finished yet. I've also got a better full size schematic of a conversion harness (same as the 'V6 conversions' one) but its bigger than A3 so im not sure if I can scan it, but I'll try...
#11 _Torana Affair_
_Torana Affair_
Posted 20 May 2012 - 02:29 PM
getting there......... found this http://www.memcals.c...g%20Diagram.pdf
gaz man i found this wiring schematic..... just wondering about all the stuff i won't be using.....
i tried ur link ...takes me to a search engine???
#12 _LS1 Hatch_
_LS1 Hatch_
Posted 20 May 2012 - 02:41 PM
When I did my own LS1 loom, I pulled all the terminals out of the ECU that I was no longer going to use, and then just put a little bit of silicone in the open cavities to seal it from dirt and moisture. Alot nicer way to finish it off then just have a bunch of cut off wires I figure.
And didn't draw anything up I'm afraid either... I used a factory service manual to go pin by pin on the engine loom, and just adapted/joined things in to the factory Torana loom for the ignition switch, dash stuff, etc, and added on a couple of fuse blocks to handle the new stuff. I used metric-pack/weather pack connectors on everything as well.
Pet peeve of mine is cheezy wiring, ha ha..
#13 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
Posted 20 May 2012 - 04:40 PM
oops, hows this -
This bit goes between the efi engine harness and the vehicles engine bay harness,
#14 _Torana Affair_
_Torana Affair_
Posted 20 May 2012 - 05:02 PM
yeah got the heads up on that...... so the ECU doesn't go FARK.... where the rest of my mates i had before ?
#15 _Torana Affair_
_Torana Affair_
Posted 20 May 2012 - 05:05 PM
oops, hows this -
Strike Two.........
ya gonna step up to plate again?
:clappin: "come on batterrrrrrrr upppppppppp " :stirpot:
#16 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
Posted 20 May 2012 - 05:14 PM
derr :banghead: my website host doesn't like the forum...
Photobucket to the rescue -
Also found this too if it helps -
#17 _Torana Affair_
_Torana Affair_
Posted 20 May 2012 - 05:19 PM
:party: Yay ..................... cheers
#18 Statler
  • 6,311 posts
Posted 20 May 2012 - 06:06 PM
Thankyou!
I was just about to go looking for this.
#19 _homer_
_homer_
Posted 20 May 2012 - 09:41 PM
Use this link. It worked for my VQ engine as well.
http://www.gmh-toran...fuel-injection/
#20 _Torana Affair_
_Torana Affair_
Posted 20 May 2012 - 10:16 PM
:party: You rock Dave............. recon they could pin that thread in elec ................ :lock:
#21 rodomo
  • 18,034 posts
Posted 20 May 2012 - 10:29 PM
I got your PM. The scan I have isn't any bigger. Another forum member has my book but it seems like you have it sorted now anyway?
Re flying over to do it for you........................................ your shout? :dontknow:
#22 _Torana Affair_
_Torana Affair_
Posted 24 May 2012 - 09:22 PM
3 wires left...... where do they go ?????
#23 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
Posted 24 May 2012 - 10:39 PM
Brown one looks like the extra tacho feed, its usually taped up in the loom in the engine bay. Top green ones (they are both green right?) I'm guessing top one is temp gauge sender, bottom one A/C compressor?
#24 _Torana Affair_
_Torana Affair_
Posted 24 May 2012 - 11:30 PM
top square is black bottom round is green - same pic
#25 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
Posted 24 May 2012 - 11:48 PM
I'll check on the UC tomorrow what colour the temp sender wire is, that square plug looks right but I thought it was a green wire :dontknow:
