FITTING RARE SPARES YELLOW INSTRUMENT DECALS
#1 _barbados1212_
Posted 10 June 2012 - 03:37 PM
Posted 10 June 2012 - 03:47 PM
Posted 10 June 2012 - 03:53 PM
#4 _barbados1212_
Posted 10 June 2012 - 04:51 PM
Posted 10 June 2012 - 05:46 PM
Is the speedo needle on the factory gauge balanced?
When I pulled the needles off my electronic VDO gauges I found that only the tacho needle was balanced, presumably because it moves quickly. As the speedo needle is not balanced I don't think paint would have any effect on the accuracy of an electronic speedo. If the mechanical speedo needle is not balanced then I think the same would hold true for a mechanical speedo.
Posted 10 June 2012 - 07:44 PM
Edited by hanra, 10 June 2012 - 07:49 PM.
Posted 10 June 2012 - 08:09 PM
If the needle is balanced there would be a lead weight opposite the pointer.
I suspect the weight of the needle is insignificant compared to the spring pressure.
Edited by ls2lxhatch, 10 June 2012 - 08:10 PM.
#8 _barbados1212_
Posted 11 June 2012 - 02:11 PM
Posted 11 June 2012 - 04:16 PM
Posted 11 June 2012 - 05:11 PM
If the needle doesn't have a balancing weight then the weight of the needle will vary depending on its position. An unbalanced needle will exert more weight on the spring when it is horizontal than it would when vertical. A balanced needle would have no effect regardless of whether it is horizontal or vertical.
The wieight of a needle doesn't even register on our electronic Kitchen scales (reading is 0 grams). A coat of paint on the needles will make no registerable difference to the instruments readings, these are automotive instruments not precision aircraft instruments.
Posted 11 June 2012 - 06:22 PM
Posted 11 June 2012 - 07:39 PM
Or if I cant fix it...chop it daddy!!!
Edited by hanra, 11 June 2012 - 07:52 PM.
Posted 11 June 2012 - 09:41 PM
#14 _LH8VD69_
Posted 12 June 2012 - 03:45 AM
As I've never seen the needles in operation fitted to a car, at night time, do the needles glow with the lighting?
Not even close mate. The dash lighting is very poor. Just a dull greenish light shining from the sides. With my dash I bought some LED bulbs in green to replace the original green just to add a little extra brightness whilst retaining the factory colour. Bare in mind u don't cut ally see the bulbs , only the glow from them is seen.
Posted 12 June 2012 - 07:18 AM
Posted 12 June 2012 - 09:30 AM
Though it is the best colour discription of most old Holdens' dash lighting colour
Its certainly nothing like newish type cars and even your Mini would have a clearer type incandescent glow to its guage/speedo cluster
Posted 12 June 2012 - 10:07 AM
Posted 12 June 2012 - 10:48 AM
Just an observation is all.
Posted 12 June 2012 - 11:01 AM
Posted 12 June 2012 - 11:21 AM
Ok cool. I just thought perhaps the instrument lamps were meant to have green condoms over them? The lamps I've fitted are all plain.
The LH SL/R dash I have has blue lenses fitted inside for the four dash lights. The speedo is the white needle 0-200 km/h only with a single slot for the odometer.
#21
Posted 12 June 2012 - 01:47 PM
#22
Posted 12 June 2012 - 02:21 PM
The SL clusters I have pulled apart do not have the blue lenses.
#23
Posted 12 June 2012 - 03:12 PM
The instrument lighting has always been abit on the dullish side, as suggested an LED style bulb sounds interesting
It would be nice to brighten it up a little without taking away the factory appearence
#24
Posted 12 June 2012 - 03:18 PM
I had actually fitted LEDs to the tail/brake and indicator lamps in my other car. But I swapped back to incandescent, the LEDs didn't seem to light the entire lens up as well as the incandescent.
#25 _barbados1212_
Posted 12 June 2012 - 03:52 PM
