Is 8.7:1 low enough turbo 202?
_rb3torana_
Posted 11 June 2012 - 10:26 AM
I know you get away with this much comp with an rb30 which Ive done before. But just would like to know wether it will be ok with a holden 6. Im figuring Ill have to run around 15psi to acheive my goal. Let me know on your thoughts. Cheers
Posted 11 June 2012 - 10:32 AM
Though Jason is going to chime in shortly and say you need 4:1, surely.......
Are you running an intercooler? Or water/meth?
_rb3torana_
Posted 11 June 2012 - 11:24 AM
Posted 11 June 2012 - 11:51 AM
With 6.8:1 I used to run 32 degrees at 20lbs boost with leaded super + water/methonal injection. Another big HP 202 used to run 30 degrees at close to 30lbs boost (again, water/methanol injection).
These were pre-intercooler draw through set ups.
_Drag lc_
Posted 11 June 2012 - 02:13 PM
mine will have 9.5 to1 hoping to not need more than 20psi boost.. ive got an alloy head aswell.. so i guess its not relavent to this..
_ljxu1torana_
Posted 11 June 2012 - 03:33 PM
thanks litre 8 for making some sense here.this what i try to tell other members about c/r.in a turbo 6.other people will learn the hard and expensive way.thanks jason.With an intercooler I would think around 28 degress max timing as a ballpark.
Posted 11 June 2012 - 04:24 PM
_Drag lc_
Posted 11 June 2012 - 04:42 PM
it sure does from my experiance.........
_rb3torana_
Posted 12 June 2012 - 07:25 AM
id think that would be fine,
How much comp and timing did the HR hand grenade have when it ran 114mph? I thought of E85 but just not that readily available yet where I am. Cheers
_ljxu1torana_
Posted 12 June 2012 - 05:53 PM
for a turbo 6 set up you need 7.5.1 cr.or even a bit lower.lower static compression ratio is always better than higher static compression ratio.if you want to run at least 114mph at the drags you will be building another motor really quickly with 8.5.1 or more c/r.thanks jason.How much comp and timing did the HR hand grenade have when it ran 114mph? I thought of E85 but just not that readily available yet where I am. Cheers
Posted 12 June 2012 - 06:01 PM
_Drag lc_
Posted 12 June 2012 - 08:05 PM
not sure what it has now prolly around 9 to 1 but it run 100mph to half track at a recent 1/8 mile drags a few weeks ago....pump gas 14psi boost..... the engine has had a few major refinements since the great race with dj.. and i must say i think its heading in the right direction pete is still trying to get a handle on the tune up...
but each to their own.....
Edited by Drag lc, 12 June 2012 - 08:07 PM.
Posted 12 June 2012 - 08:43 PM
WOW........ that is moving.
Edited by greens nice, 12 June 2012 - 08:44 PM.
_rb3torana_
Posted 12 June 2012 - 09:45 PM
_Drag lc_
Posted 13 June 2012 - 05:34 PM
