Tail light Chrome Surround mounting lugs
where to buy?
4 replies to this topic
#1 kingsly
kingsly
  • 235 posts
Posted 25 June 2012 - 08:01 PM
Not sure if this has come up in the past but where can I buy some of the mounting lugs for the LX tailight chrome surronds (pictured)
Any help would be great.
Edited by kingsly, 25 June 2012 - 08:02 PM.
#2 _LH SLR 3300_
_LH SLR 3300_
Posted 25 June 2012 - 08:05 PM
Pretty sure they are NLA from Holden, i have a few good second hand ones if you get stuck finding them.
#3 kingsly
kingsly
  • 235 posts
Posted 25 June 2012 - 08:32 PM
Awsome thanks for the prompt reply. i had a quick geeze on rarespares but i saw nothing.
Do they slide into the surround then click into the hole on body?
#4 _LH SLR 3300_
_LH SLR 3300_
Posted 26 June 2012 - 04:56 PM
They push into the holes, then the trim is clipped onto. Here are some pics of one, sorry they aren't the best.
If you look close, you'll notice the small pin sticking out of the center, this is to lock the clip into the body panel. Place the clip in the hole then push the pin in so it's flush, then the tail light bezel trim clips on. Your bezels should also each have a small stud, this clips into the hole in the panel each side between the fuel filler & tail light, the small metal retaining clip is the same as the ones that hold the 3300, 4.2 Sunbird etc badges on.
#5 kingsly
kingsly
  • 235 posts
Posted 08 January 2013 - 06:57 AM
PM Sent.
