Not really IMO, and regardless the profile of the bush tells the story - it doesn't make sense to go the other way.
And we can't rely on the LH Parts or Service manuals - jeepers they have the tie rod ends going into the steering arms from the wrong direction - because of the taper they physically cannot fit the direction they are depicted - and so cannot be routinely relied upon. Whereas I see the UC manual as being more reliable because errors of this ilk are likely to have been remedied.
But by all means, if your level of knowledge about these 'out-rigger bushes' is more intimate than mine, then by all means please share. To be honest I know very little about it - I've gone by what I was told, what I have seen, what I have read concerning other more knowledgeable folk's appraisal of the matter, and (as I said) just having a look at the bush and working out as best I can what seems right.
Given walloper's post/photos I reckon I might just be for once... however, usually this degree of cockiness is short-lived for me, and ordinarily means I am about to be well and truly schooled in all things 'LH Torana Out-Rigger Bushes'...
Cheers, TB
G/day Craig
Well I'm certainly not an expert in all thingsTorana, esp LH/LX/UC, but learning new stuff all the time just like everyone else thanks to this forum.
Please note that the following is related to the LC/LJ Torana, however as the LH uses the same outrigger bush it may be pertinent.
GMH Dealer Service Letter dated September 1973 advises Dealers that some Torana vehicles may have had the crossmember brace to frame side rail bushes Part Number 7211458 installed incorrectly.
Quote: This bush is designed so the larger diameter head accepts braking force and correct installtion is essential.
There is also a drawing showing the bush is to be installed with the large head facing toward the centre of the vehicle not the chassis rail.
Maybe this bush was installed differently for the LH Torana, however I suspect that the braking forces would be transmitted through the LH/LX crossmember brace in the same manner as in the LC/LJ's.
So, in my humble opinion the LH parts catalogue is showing the correct installation for the bush in an LH Torana.
Dave
Edited by S pack, 04 July 2012 - 11:24 PM.
