paint grip 253
_pocock_
Posted 15 July 2012 - 06:53 PM
leave it for up to six months or more and when your ready to paint you just give it a wipe over and clean with w&g remover and paint straight over it most paint companys will garentee there products over it scored some the other day from a friend who reckons it is the best stuff ever made sound alot easier then using deoxidine ,, just apply the 253 and leave it on there no washing sandind or worrying
about getting it in crevices so the paint wont stick sounds great
pocock
Posted 15 July 2012 - 07:05 PM
_Quagmire_
Posted 15 July 2012 - 07:10 PM
byrialyant
Posted 15 July 2012 - 10:09 PM
Posted 15 July 2012 - 10:11 PM
_pocock_
Posted 15 July 2012 - 10:39 PM
pocock
Posted 15 July 2012 - 11:31 PM
Posted 16 July 2012 - 08:11 PM
_pocock_
Posted 16 July 2012 - 10:47 PM
an epoxy solvent coating,, that will prevent rust for up to 6 months indoors . and it is wise to just wipe any bare metal panels over with a metal conditioner/ rust converter, like deoxidine wipe on leave it a minute or two then wipe off with a metho soaked rag then dry with a dry rag let surface dry properly and apply the paint grip 253 and you should be sweet he said some times when sanding metal with wire wheels or discs there can be rust in the small scratches on the surface of the bare metal you wont see. so the deoxidine will just get rid of it before applying the 253 dont know if he is right or not
Posted 17 July 2012 - 08:38 AM
_pocock_
Posted 17 July 2012 - 10:04 AM
on the right procedure
Posted 17 July 2012 - 10:13 AM
_RichoX1_
Posted 17 July 2012 - 10:46 AM
1 with water 5 min after neutralizing the panels re Oxadises back up in patches
2 with W&G remover no Oxadising
3 with thinners no more Oxadising
It seems to defeat the perpose of deOxadising the panle when whater intantly Oxidises it once more
Posted 17 July 2012 - 03:25 PM
_pocock_
Posted 17 July 2012 - 10:39 PM
pocock
_RichoX1_
Posted 18 July 2012 - 12:41 AM
im really not confident that this water is the right method described in the process, its a definite Oxidation that starts again its just common sense to see that water on bear mettle corrosion starts even just being exposed to the air rust starts developing.AFIK The orange tinge you see is not oxidising, it is part of the process.
brown patches start showing up all over the panels
Hear is another example there is a type of deoxidizer that has some material in it that when it drys it leaves a plastic like film, there for seals it from the air, thus removing it with water doesn't work only thinners will do it
Edited by RichoX1, 18 July 2012 - 12:53 AM.
_pocock_
Posted 18 July 2012 - 10:43 PM
pocock
