Failed manual conversion, clutch pedal fouls on steering column
30 replies to this topic
#1 _judgelj_
_judgelj_
Posted 16 July 2012 - 08:26 PM
Just having a bit of trouble with the pedals. The the auto brake pedal that i pulled out seemed to be a converted manual brake pedal. It had a longer flat plate welded on and the longer manual rod. not sure if its factory though as the pivot rod seems to have been welded somewhere and im not sure if its factory length but what i do know is its longer than the 'manual' pedal i acquired. now when i put the manual pedal in the rod was too short and i couldnt get the clutch pedal over enough to put the retaining clip on. i pulled it out and put back in the 'auto' brake pedal and the rod is long enough, but it fouls on the steering column and if i try to push it over it fouls on the heater box? did manual LC's not have heaters for this reason? I am pulling my hair out as its raining and the car is stuck at my uncles workplace or 3 days now and i want it home.
#2 S pack
  • 15,762 posts
Posted 16 July 2012 - 10:42 PM
Jacob, hate to tell you mate but your steering column has been moved across to the right through the firewall to fit a V8. Hence the LH type steering uni on the steering shaft in the engine bay. The original Torana clutch and brake pedal assy is never going to work. The clutch and brake pedals come down on the right hand side of the column, they don't go one on either side of it.
I'm also suspecting the engine mounts on the crossmember have been modified causing your engine to sit too high, making the 3/4 shift rod foul on the transmission tunnel.
Best thing to do right now would be to put the Trimatic back in until you can sort out how to bring it back to original (if possible).
#3 S pack
  • 15,762 posts
Posted 16 July 2012 - 11:11 PM
This is how the LC/LJ 6cyl pedal assy is set up.
#4 _judgelj_
_judgelj_
Posted 17 July 2012 - 09:14 AM
wow that has just gutted me. i suspected that the column had moved but didnt think it was enough to have caused such a problem. there goes my plans.
#5 S pack
  • 15,762 posts
Posted 17 July 2012 - 05:54 PM
G/day Jacob
Had a bit of think about your clutch pedal problem today. With some modification to the clutch pedal and using a cable clutch setup instead of the original linkages you might be able to do the manual conversion.
#6 _judgelj_
_judgelj_
Posted 17 July 2012 - 06:06 PM
Thanks Dave firstly for pointing it out as i was getting bad migraines from the drama, but, after thinking about it today and receiving encouragement from my mechanic (uncle), i have started to modify it to get it to work. the strange thing is the the auto brake pedal is actually a manual brake pedal adapted to work. what i couldn't figure out is why the pivot rod was longer on the 'auto' brake pedal, compared to the one i had acquired. This was so you could still slot a clutch pedal over on the other side and fit the retaining pin to prevent the clutch pedal slipping off. I spoke to CRS and they suggested the same thing so it can be done. What i have done is grind back everything from what was originally the auto pedal as the one i purchased has a short rod and will not work unless it is extended. Tomorrow i will cut up the clutch pedal and reshape it with a left hand kink rather than a right hand one. Hopefully this will all work, even with the rat trap cable as the clutch still sits where it should on the pedal box (i think). the only thing i am concerned with thus far is how to mount the clutch return spring because i cant seem to find the upper mounting rod. would anyone have an exploded view or even a picture of this?
#7 S pack
  • 15,762 posts
Posted 17 July 2012 - 08:16 PM
Is this the diagram you need, item #8? 1st post in the thread.
http://www.gmh-torana.com.au/forums/topic/54620-qld-wanted-ljlc-pedal-box-parts/
Factory automatic models don't have the clutch over centre pin/shaft (#8 in the diagram) fitted. I'm sure you will find the pin/shaft from a manual car will be too short and will also need to extended just as the brake pedal shaft has been extended.
Personally I would straighten the leg of the pedal to get past the column (as you have already thought of) and then kick it across to the right to get the clutch pedal pad closer to the brake pedal and also get away from the area of the firewall where it curves in to form the transmission tunnel.
If the pedal hits against this curve and not the flat part of the firewall you may not attain correct clutch pedal travel.
Also, with the clutch pedal having to be approx 30 or 40mm further to the left than normal I can't imagine the clutch pull rod through the firewall is going to want to line up with the pedal anchor properly.
Just a few suggestions.
Dave.
#8 debkar
debkar
  • 912 posts
  • Car:1971 LC 2 Door
Posted 17 July 2012 - 08:42 PM
Wow Jacob, just saw this thread, this is turning into a major project.
If it was my car, I would return the column to where it needs to be, unless you really plan a V8 transplant in the future and go with non modified parts.
I'm with Dave, possibly go with a cable set up if you can't go back to original, as you can drill the hole for the cable where you need it on the firewall. Cable would need cable type bell housing,
I've gone with cable in my car, sold all the rat trap bits, using 4 cyl torana clutch pedal (they have cable to start with) but you could use the 6 cyl pedal with a cable hook welded on, WB bell housing (fits blue pressure plate if you want to use one- larger diameter) and WB clutch cable.
Do you need the over centre return spring mount? I may have one in the shed,
Keep plugging away
Regards Simon
Edited by debkar, 17 July 2012 - 08:44 PM.
#9 _judgelj_
_judgelj_
Posted 17 July 2012 - 08:52 PM
and as always incredibly helpful suggestions. i did have that diagram but now i understand why i do not have the pin. im surprise no one mentioned this before.
i will probably need to sort something out for the return spring shaft as i think you are right it does not have one. one idea was to weld something onto the pedal box and make it self contained. the only issue i found was that i will have to relocate the high beam dimmer switch as my foot will hit. as for the clutch cable i am not entirely sure, where the clutch pedal sits now it is where it should be on the pedal box as it line up with the travel adjuster bolt, but whether or not the pedal box has been moved i don't know. either way i am sure i can figure something out for now. i found out that the car was originally a 308 supra 5 speed so this is consistent with the lengthened brake pedal pivot shaft. i could only assume that the owner ran the setup i am attempting with the only exception being the type of clutch, most likely hydraulic. one thing i must ask is how the rat trap clutch cable should connect to the clutch pedal. i have the bracket as depicted in the diagram but the cable will not connect straight to it, something is missing...
#10 S pack
  • 15,762 posts
Posted 17 July 2012 - 08:58 PM
Just looking at the pics of your pedals, I reckon you could cut up the brake pedal that is surplus to your needs and use that to modify your clutch pedal. That way you'll have a ready made kick to the right for the new clutch pedal.
Edited by S pack, 17 July 2012 - 09:07 PM.
#11 debkar
debkar
  • 912 posts
Posted 17 July 2012 - 08:59 PM
Hi Jacob,
The original clutch pull rod fits into a clevis that attaches to the clutch pedal, do you have that part?
Edited by debkar, 17 July 2012 - 09:00 PM.
#12 originalglenn
originalglenn
  • 595 posts
Posted 17 July 2012 - 09:07 PM
why not just move the steering back where it should be?
#13 S pack
  • 15,762 posts
Posted 17 July 2012 - 09:09 PM
Hi Jacob,
The anchor that fits onto the pin on the clutch pedal looks the same as the one that the other end of the pull rod connects to on the relay lever.
#14 debkar
debkar
  • 912 posts
Posted 17 July 2012 - 09:18 PM
Here it is Jacob,
#15 hanra
  • 11,033 posts
Posted 17 July 2012 - 09:21 PM
I reckon leave it where it is and fit a V8!!!!
#16 debkar
debkar
  • 912 posts
Posted 17 July 2012 - 09:22 PM
Last pic for the night, my LC 4 cyl clutch pedal in the 6cyl pedal box, works well
#17 _judgelj_
_judgelj_
Posted 17 July 2012 - 10:15 PM
reason i dont move the steering column is a: i would like to run a v8 in he future, and b: moving the column would mean steering uni modification and it just seems a lot harder than just doing what was already done which is to custom bend a clutch pedal. i am lucky the the brake pedal has already been modified for this so it just seems like the better idea. the only thing i need to work out is clutch return spring modification and the clevis thing which is easy enough i can just make something. thanks so much for the photos they are of great help! not sure what i am going to do about the clutch cable should it be offset to the pedal, ideas?
i would love to fit a v8 eventually, and the good thing is it will drop straight in with a supra 5 speed, which i assume is hydraulic in which case there are already mounting holes drilled in the firewall. first thing i would do is sort out a diff in the near future.
#18 _judgelj_
_judgelj_
Posted 20 July 2012 - 10:08 PM
Well in case anyone is wondering i have just finished fabbing up the new pedal, rat trap bell housing bracket, cable clevis bracket and currently up to clutch return spring mount. if anyone has any idea of what the original looks like in real life (parts catalogue diagram doesnt help that much) i would greatly appreciate it. might send a few pm's out.
#19 debkar
debkar
  • 912 posts
Posted 21 July 2012 - 10:32 AM
Hi Jacob
Do you have any pics so far of the work? I'm keen to see
Simon
#20 debkar
debkar
  • 912 posts
Posted 21 July 2012 - 10:46 AM
Hi Jacob
Here is one from another thread on here
http://i252.photobuc...07/PIC_0006.jpg
Edited by debkar, 21 July 2012 - 10:48 AM.
#21 _judgelj_
_judgelj_
Posted 21 July 2012 - 07:45 PM
simon i have about a thousand pictures it will be very interesting to see i will let you know when they are up in my build thread.
#22 debkar
debkar
  • 912 posts
Posted 21 July 2012 - 07:50 PM
Good stuff, will check them out,
#23 _judgelj_
_judgelj_
Posted 23 July 2012 - 07:08 PM
i purchased a set of pedal bushes from rares and i must say i am not impressed. the pivot rod would not push through the first bush no matter what so i had to cut part of it off and managed to get it through. it went through nicely on the other side however i could not get the bushes in the clutch pedal over the rod and had to assemble it without them. did i do something wrong?
#24 S pack
  • 15,762 posts
Posted 23 July 2012 - 09:43 PM
Hi Jacob
Are all the bushes in the kit the same or do two of them have a thicker wall than the other two (ie: same ID but larger OD)?
#25 _judgelj_
_judgelj_
Posted 24 July 2012 - 10:08 AM
they are all the same Dave, in fact, going by the diagram i have two should be completely different with a tapered edge.
i'm also machining up a new over centre spring upper bracket as the plastic one broke. if anyone has any reason why it shouldnt be metal please let me know. cheers.
