Mixed tyre size. Legal?
11 replies to this topic
#1 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 03 August 2012 - 09:13 PM
G'day boys,
Just purchased a LJ and noticed the rear tyres are 225/60 13 and the fronts 205/60 13.
It took me a week to realise this so it's not that noticable when on the car.
Question is, when I've finished the car and it goes over the pits, is it legal or will they spit the dummy.
This is a WA law question.
Marty
#2 Ice
  • 15,200 posts
Posted 03 August 2012 - 09:20 PM
All tyres must be of the same size unless some one changed the rules but i doubt it
#3 ls2lxhatch
  • 5,332 posts
Posted 03 August 2012 - 09:59 PM
There is no problem with different width/profile front and rear tyres within limits.
See page 21
http://www.infrastru...Jan_2011 v3.pdf
4.2.5 Tyre Aspect Ratio
Because of the different handling characteristics, the aspect ratio of tyres fitted to the front axle must not vary by more than 10 from the aspect ratio of tyres fitted to the rear axle (e.g. 175 65 R14 front and 205 45 R14 rear, has an aspect ratio difference of 20 and is not recommended, whereas 175 65 R14 front and 195 60 R14 rear has a difference of 5 and has similar handling characteristics).
#4 axistr
axistr
  • 1,212 posts
Posted 03 August 2012 - 10:08 PM
It states in our rego inspection rules that the tyres and rims must be the same size and cobstruction on the one axle, but does not mention from front to rear. Our beamer come from factory with 245x17 front & 265x17 rear. And no bloody spare.
#5 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 03 August 2012 - 10:26 PM
reading point 4.2.5 it may be legal as long as the aspect ratio is under 10. God knows how you work that out?
#6 _Quagmire_
_Quagmire_
Posted 03 August 2012 - 10:31 PM
10mm from memory
so a 215 on the back is within limits tmk anyway
and andy above is the rego guru but so he may confirm or deny
Edited by Quagmire, 03 August 2012 - 10:31 PM.
#7 ls2lxhatch
  • 5,332 posts
Posted 03 August 2012 - 10:41 PM
Your tyres have the same aspect ratio (60). What they are saying is you can have a maximum aspect ratio (profile) difference of 10. For example 50 front 60 rear or 40 front 50 rear but not 40 front 60 rear.
There is also a rule regard difference in width but you are within that.
I have WA approval for 215/40/17 fronts and 235/40/17 rears.
Edited by ls2lxhatch, 03 August 2012 - 10:52 PM.
#8 WA1TNC
WA1TNC
  • 358 posts
  • Name:Nig
  • Car:HX ute(daily) LH Torana(Harrop Blown LS1) in the build
Posted 15 August 2012 - 02:43 PM
What about people that run say 18" on the front & 20" on the back? I ask because I want to run 16" ve chasers fronts to clear my brakes & 15" vb-vz rims on the back because I've got a shed load of them.
#9 ls2lxhatch
  • 5,332 posts
Posted 15 August 2012 - 04:14 PM
If you can do it within the following rules then I don't see anything about the front and rear rims having to be the same diameter.
4.2.4 Overall Nominal Diameter
The overall diameter of any tyre fitted to a passenger car or passenger car derivative must not be more than 15mm larger or 26mm smaller than that of any tyre designated by the vehicle manufacturer for that model.
Because of the different handling characteristics, the aspect ratio of tyres fitted to the front axle must not vary by more than 10 from the aspect ratio of tyres fitted to the rear axle (e.g. 175 65 R14 front and 205 45 R14 rear, has an aspect ratio difference of 20 and is not recommended.
4.2.8 Maximum Passenger Car Tyre and Rim Width
Tyres fitted to passenger cars or passenger car derivatives must not be more than 30% wider than vehicle manufacturer’s widest optional tyre. The rim width must not exceed the recommendations for the tyre fitted.
#10 _CHOPPER_
_CHOPPER_
Posted 15 August 2012 - 04:43 PM
I got knocked back for RWC with differenbt diameter rims front and rear. You do realise that the centre bores on the VE rims are smaller than the VB - VZ rims?
#11 WA1TNC
WA1TNC
  • 358 posts
  • Name:Nig
Posted 16 August 2012 - 12:30 PM
Yeah I used to have a VY SS & I put VE SSV 19" rims on there, I just took them to Ajax & got them to machine the centre lip off them which allowed them to be bolted on, as long as you use the flared lug nuts so it centers the stud in the middle of each hole they bolt up fine. I was going to get them to widen a set of 15" chasers & see if they can do the machine work to the VE 16" steelies.
#12 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 19 August 2012 - 12:34 PM
Pretty sure tyre fryer (matt) has VE 16" stockies on his LC...
