Non GTR + XU1 tag verification thread
LJ Torana tag check GTR or XU1?
272 replies to this topic
#51 _LJdave_
_LJdave_
Posted 18 April 2013 - 09:40 PM
thank you so much, now I have some history on my baby
I actually bought this car from my best mates uncle in Swan Hill
my home town, when I got it they used it as a farm hack during harvest
#52 gad05
gad05
  • 420 posts
  • Name:Graham
  • Car:73 lj 2 door , 74 lj sedan.
Posted 14 August 2013 - 10:30 PM
Hi all,Looking for information on my lj,vin no. 8869ddh304264j .
Cheers Graham
#53 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 15 August 2013 - 01:18 PM
Hi Graham
That one appears on the VIN disc as an S Model, 4 door, 6 cylinder. It was completed in Brisbane on 24/1/74 and sold by Tweed Motors P/L - Tweed Heads during Feb '74.
There is no engine number listed, but the original was a 2850cc type and the number would have been in the CD44xxxx to CD46xxxx range. The car was fitted with an auto transmission, disc brake front end and a 2.78:1 conventional differential.
Bazza
#54 gad05
gad05
  • 420 posts
  • Name:Graham
Posted 15 August 2013 - 03:06 PM
Thanks Bazza,
Great to know the history of these cars.
Cheers Graham.
#55 gad05
gad05
  • 420 posts
  • Name:Graham
Posted 15 August 2013 - 09:55 PM
Another lj for you Bazza, vin no. 8b11dcl230538j.
Thanks Graham.
#56 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 15 August 2013 - 10:18 PM
Hi Graham
That would be an S Model 2 door completed in Adelaide on St Valentines day in 1973. The original engine number was CD286485. It left the factory with a 2850 engine, auto transmission, disc brake front end and a 2.78:1 conventional differential. It was sold by Bayside Motors, Frankston Vic the same month.
Bazza
Edited by Bazza, 15 August 2013 - 10:19 PM.
#57 torana?
torana?
  • 94 posts
Posted 16 August 2013 - 07:45 AM
can anyone tell me  what the original engine size was for mine? 82311CH207978
thanks
#58 S pack
  • 15,668 posts
Posted 16 August 2013 - 10:09 AM
thanks
173 engine (no engine number recorded), M40 Trimatic, disc front brakes, 2.78:1 conventional differential.
#59 gad05
gad05
  • 420 posts
  • Name:Graham
Posted 16 August 2013 - 11:36 AM
Thanks again Bazza.
Cheers Graham.
#60 _SHEZZ69_
_SHEZZ69_
Posted 04 November 2013 - 10:10 PM
Hi there, this is all new to me...
Any help with ID on my new torana is greatly appreciated
LC82569
449A
1275-42R
567-11206
568-11401
Thanks Sheridan
#61 S pack
  • 15,668 posts
Posted 04 November 2013 - 11:53 PM
Hi and welcome Sheridan
Model No. LC82569   SL 4dr 6cyl
Body No. 449A =  449th  4dr body,  A = Adelaide assembly plant.
Trim No. 1275-42R   1275 is the paint combination number (two tone, see colours below) and 42R  Baroque Red vinyl
Paint No. 567-11206   Monaco Maroon
Top (roof) 568-11401  Kashmir White
#62 _SHEZZ69_
_SHEZZ69_
Posted 05 November 2013 - 10:59 AM
Awesome!
Thanks heaps for that, I'm pretty sure it's a very original LC then...besides the 202 fitted
I'll post some pics ASAP...
Very much appreciated dave
#63 _hp179block_
_hp179block_
Posted 24 November 2013 - 12:11 PM
Hi All,
I have had a phone call from someone (who can't use a computer) trying to find out more about his project LC. Both front tags have been removed (believed to have had front end replaced in an accident repair). Only have the body number, LC14285B (date 08/70). So its Brisbane built but I can't provide him any other information. He believes it to be an XU-1, but who knows. He is keen to restore it mostly orginal but doesn't know what it should be. Any help is appreciated.
John, QLD Torana Car Club
#64 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 24 November 2013 - 03:12 PM
Hi John
The number that you have quoted is the "Chassis Number" not the "Body Number" but regardless of this, neither is any use in establishing the identity of the car in question. The missing VIN tag is the usual first step method of identification. From the number given it can be said that the car was probably completed in Brisbane around the third week of August '70.
If the car is a 2 door, 6 cylinder vehicle and it is not an 82911 model (ie GTR or GTR/XU-1) then it can only be an 82311 ("S" model). The Chassis Number LC14285B is only 1 off a known XU-1. This is a good sign but by no means definitive. There are distinctive features that can identify whether a 2 door 6 cylinder is an 82311 or an 82911 model but a close examination of the vehicle would be needed.
Bazza
#65 _hp179block_
_hp179block_
Posted 24 November 2013 - 04:08 PM
Thanks, I'll pass on that info.
John
#66 _Smega7_
_Smega7_
Posted 07 December 2013 - 08:25 PM
Hi guys,
Just bought a 2 door LJ today so this is all a bit new to me. I was hoping to get some info on my car as the seller seemed to be a bit dodgy.
He said it has 3 matching tags but the photos of the tags he sent were different to the ones he gave me. I didn't realise till I got home.
The tags are as follows;
8d11 dcl250222j
08/73 blj28114a
Model, lj82311
Body; 85341-a
Trim; 1864-59e
Paint; 567-15331
Eng; ld1
Rraxel; g95
There's nothing after trans
Stamped on car is blj28114a
#67 S pack
  • 15,668 posts
Posted 08 December 2013 - 07:53 PM
8B11DCL250222J   8B11= GMH LJ 2dr Torana S, D =173ci (2850cc) High Comp engine, C = Model year 1973,  L2= Adelaide assembly plant 250222 = Production sequence number, J = LJ.
08/73 BLJ28114A =  Compliance Date and Adelaide Chassis Number on Compliance Plate
Model, LJ82311 = LJ 2dr Torana S.
Body; 85341-A = Adelaide Body number
Trim; 1864-59E = 1864 = GMH Paint combination number  (Covert Metallic), 59E = Chestnut Vinyl
Paint; 567-15331 = Covert Metallic
Eng; LD1 = 173ci High Compression engine
Rraxel; G95 = 3.36:1 ratio differential
There's nothing after trans = M15 3 spd column shift manual (standard transmission for model)
Stamped on car is BLJ28114A. Matches chassis number on Compliance plate.
Edited by S pack, 08 December 2013 - 08:00 PM.
#68 _Smega7_
_Smega7_
Posted 08 December 2013 - 08:21 PM
Thanks very much!
#69 N/A-PWR
  • 9,632 posts
Posted 02 February 2014 - 01:50 PM
Hello All,
Just got a LC 4 Door off of Craig, and wondering if the only TAG matches the Chassis number:-
Just wondering if this:-
VIN - 82369CL6 6894
matches this Chassis number:-
Body# - LC04141A
I bought the VIN disc on eBay, and all the VIN info, is the same example, so that is a scam.
I had a bit of a search on Google, and all I  can see, is that the VIN is a LC 'S' 4 door 202motor.
Any help is appreciated. Dave I
#70 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 02 February 2014 - 02:46 PM
Hi
Can you clarify the VIN please. There should be 6 digits after the L
Bazza
#71 N/A-PWR
  • 9,632 posts
Posted 02 February 2014 - 03:09 PM
Sorry Bazza,
I thought that was a space 2 digits after the L, it is almost flattened out there and with a pen or pencil rub on paper reveals nothing, but with the light reflecting here and there, I can see an 0 or a part of an 8, but that is not clear :-
Attached File  IMG_4669.JPG   8.83K   4 downloads
Attached File  IMG_4670.JPG   9.68K   4 downloads
Attached File  IMG_4671.JPG   9.19K   3 downloads
Attached File  IMG_4672.JPG   11.94K   3 downloads
Thanking-you for looking. Dave I
Maybe it is a 7
#72 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 02 February 2014 - 03:29 PM
Hi Dave
The Chassis Number fits squarely in mid - November 1969. This being the case there would be no ADR tag on the firewall.
In my opinion the car is L626894 which is a Perth built 4 Door S Model. It was completed on 15 Nov 1969 and sold by WA dealer 838 (unknown) during Dec '69. It left the factory with a 2250 cc (138 ci) 6 cylinder, 3 speed manual transmission, drum brakes all round and a 3.08:1 conventional diff.
It appears on page 802 of the VIN master listing.
Bazza
#73 N/A-PWR
  • 9,632 posts
Posted 02 February 2014 - 03:34 PM
Thank-you very much Bazza,
the top right of the '2' is what I thought was part of an '8', so you are spot-on me thinks. Dave I
#74 N/A-PWR
  • 9,632 posts
Posted 02 February 2014 - 03:37 PM
Does any info say what colour it was, I should look up the '69' colour chart of colours - it looks like Backwash green at present.
Just checked, if the same colour was used, it must be 'Verdoro Green'
Edited by TORYPOWER, 02 February 2014 - 03:49 PM.
#75 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 02 February 2014 - 03:48 PM
Hi
No further info appears on the disc. There were a number of 'green' colours available for the 1969 range.
Bazza
