Brake rotor thickness
LJ LC
19 replies to this topic
#1 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 01 October 2012 - 09:35 PM
Hi Guys,
can anyone tell me the thickness of a new standard rotor off an LJ/LC?
I have looked up my Manual and it says it's 9.525mm exactly the same thickness as the pad, I think this is a mistake.
Also If you know minimum thickness as well.
Attached File  IMG_1415s.jpg   110.89K   10 downloads
Marty
Edited by sibhs, 01 October 2012 - 09:37 PM.
#2 dattoman
  • 16,487 posts
Posted 01 October 2012 - 10:51 PM
12.7mm standard
12mm are throw away thickness
#3 S pack
  • 15,722 posts
Posted 01 October 2012 - 10:53 PM
The GMH LC Torana workshop manual has the disc thickness listed as .375" so it appears the specs in your manual are correct.
The pad thickness specs are also the same.
I don't have any data on the minimum disc thickness spec however it I expect it would be approx 1mm less than the original thickness.
Edit: Thanks Datto, I thought they were thicker than 10mm, so the GMH shop manual also has the wrong spec listed.
Edited by S pack, 01 October 2012 - 11:01 PM.
#4 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 02 October 2012 - 09:08 PM
Thanks guys,
Datto, is 12.7mm the new size? I've just bought a second hand set and they are almost 15mm.
Marty
#5 _Bomber Watson_
Posted 02 October 2012 - 09:15 PM
Mos likely xu-1 rotors.
#6 S pack
  • 15,722 posts
Posted 02 October 2012 - 09:24 PM
Yep, XU1 rotors are approx 3mm thicker than standard ones.
12.7mm will be the thickness of new std 6cyl rotors (discs).
#7 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 02 October 2012 - 09:32 PM
I've just noticed they're one piece, the hub and rotor are one. Is that an XU-1 thing or after market.
#8 dattoman
  • 16,487 posts
Posted 02 October 2012 - 10:13 PM
They aren't LC-J ones then
They are LH-X-UC ones
#9 Ice
  • 15,200 posts
Posted 02 October 2012 - 11:14 PM
Thanks guys,
Marty
You can buy them new to suit lj torana and there not expensive let me know if you need to get some new
cheers gene
#10 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 02 October 2012 - 11:55 PM
Hi Gene,
So can I buy new hubs and rotors?
Makes me wonder if the stub axles which came with them are LH or LJ, any way to tell? I can't quite read the numbers on the outside but has an E on the inside.
Marty
Attached File  IMG_1420s.jpg   90.39K   4 downloads
#11 dattoman
  • 16,487 posts
Posted 03 October 2012 - 12:22 AM
I think we established the stubs interchange
But the brakes don't
So if your using twin piston cast iron calipers you need the hubs and discs to suit
You can't use the 1 piece version as they foul on the caliper
I prefer the 2 pots (LC-J) over the later caliper myself
LH-X-UC look like this
LC-J ones look like this and bolt to hub
#12 S pack
  • 15,722 posts
Posted 03 October 2012 - 09:55 AM
Datto is correct, the LC/LJ stub axles carried over to LH but the discs and calipers are different. You can't use LH discs with LJ calipers.
BTW, you can buy new repro LJ discs but you'll have to find second hand hubs to bolt them to.
#13 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 03 October 2012 - 06:51 PM
Appreciate your input guys.
I'm finding out that just because you got parts off an LJ, doesn't mean they belong there. Welcome to the world of rebuilding a car.....
This is what I've learn't so far.....
My stub axles are good because LC to LH model are the same except LH ones are used on opposite wheels.
I need LC/LJ hubs to go with LC/LJ calipers. One piece hub/rotor is from the LH series and will foul on the LJ caliper. I can buy new rotors but need LC/LJ hubs.
Am I on the right track now?
Are my calipers the 2 pot LJ ones?
Yes, they're filthy but I'm not getting them reconditioned until I know they're right.
Marty
Edited by sibhs, 03 October 2012 - 06:52 PM.
#14 S pack
  • 15,722 posts
Posted 03 October 2012 - 07:07 PM
Marty
Yep you're getting the hang of it.
The LC/LJ calipers have two pistons. One behind each pad.
AFAIK the calipers you have are actually HK,T,G but don't panic cause they are the same as LC/LJ except for the cylindrical protrusion cast onto the back of the inboard half of the caliper, LC/LJ calipers don't have this cylindrical protrusion.
Dave.
#15 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 03 October 2012 - 07:20 PM
Dave.
Thanks Dave
Far - out.. more bitsa other cars in the build. What would happen If I cut that protrusion off?
#16 S pack
  • 15,722 posts
Posted 03 October 2012 - 07:59 PM
Thanks Dave
Nothing, as far as I know it's a solid casting, however I would pull the pistons out first and confirm that there isn't a hole running down into the protrusion.
#17 Ice
  • 15,200 posts
Posted 03 October 2012 - 08:33 PM
Marty give me a call and i can help you out with the reconditoning of the calipers and tell you where you can buy brand new rotors from pretty cheap
#18 dattoman
  • 16,487 posts
Posted 03 October 2012 - 08:46 PM
Or me :)
#19 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
  • Car:LXSS, VUSS, VESSv & the mighty HB
Posted 03 October 2012 - 09:09 PM
They look the same as what is on the HB, with out Stealing the thread, can LC LJ stubs fit the HB to run 5 stud rims, just a question, as I'm curious :D
#20 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 03 October 2012 - 09:24 PM
Or me :)
Thanks, I'll call you both.
I quickly panic'd and looked on ebay at all the calipers for LJ's for sale and they all had the protrusion on them, are these people just trying to get a better price for a HK/T/G part?
Also tagged with one or more of these keywords: LJ, LC
