best manual gearbox for sbc in torana
16 replies to this topic
#1 _jamiller82_
_jamiller82_
Posted 17 October 2012 - 06:11 PM
hi im just after some advice on which manual trans to put in my torana i have a 383 chev stroker small block , i know the ford toploader 4 speed is up there with the best trans to use but they are way to expensive to buy they sell secondhand up to 1000 bucks then you need bell housing clutch and the list goes on any ideas will be great. the car will just be used for the street no racing just cruising and the engine should be producing between 450 to 500HP thanks
#2 TerrA LX
Posted 17 October 2012 - 06:47 PM
Is $1000 expensive for a strong manual box that will handle 400 to 500 horsepower?
#3 _evil UC hatch_
_evil UC hatch_
Posted 17 October 2012 - 06:53 PM
I couldnt imagine you would get anything else suitable for any less than a grand. the only other boxes I'd consider behind an engine like that would be a tremec TKO 5 speed, or a T56 6 speed, and you would be expecting to spend 4-6k to got one in, maybe more.
Even a used T5 can set you back 1k but I wouldnt put that on more than a stock 308/304 without doing any modifications to one to beef it up
#4 Ice
  • 15,204 posts
Posted 17 October 2012 - 06:58 PM
whats wrong with a muncie they handle big block chevs
#5 _evil UC hatch_
_evil UC hatch_
Posted 17 October 2012 - 07:11 PM
I cant imagine one being any cheaper than a toploader still, but yeah another good choice in the 4 speeds
#6 _Quagmire_
_Quagmire_
Posted 17 October 2012 - 07:19 PM
2k brand new from summit...from memory...and a lot better shifting box too boot :)
#7 unclefestal34s
unclefestal34s
  • 1,126 posts
Posted 17 October 2012 - 07:20 PM
perfect gearbox for you would be opel 4 speed as used in the hk's and lc torana's or even a bullet proof aussie 4 speed...nice and cheap good ratios...
mate get real if you can afford to build a 383 chev...perhaps you can dig a little deeper into your pocket and put a real 4 speed transmission where it belongs..
that's infact if you've got the horsepower your quoting...
if your genuinly serious about what your doing the gearboxes you should be considering are muncie finespline and super t10 which both have 26 spline and 32 rear
and of course the toploader gearbox which you say is to expensive..all these gearboxes i have personally used with great success...don't kidd yourself horsepower
and torque costs money..
#8 _Bomber Watson_
Posted 17 October 2012 - 07:23 PM
Agreed, whats the point of spending 15k building hp if you break stuff easing your foot off the clutch at idle??
That said i agree the 1k or so asking price for a toploader pulled offf some lads junk pile is a bit rich, considering you need to add a rebuild to that etc. If you look around you can get brand new super T-10's from the states for around $1500 plus freight and duties, or a TKO 500-600 is about $2200 from the sttes plus freight and duties. The latter is the way im going behind my 202 when i go to a manual. The perk for you is seeing your running a chev EVERYTHING bar the tailshaft and gearbox x member you can get straight from the states cheap cheap. Budget 5k.
If you cant afford that, put a slushbox in it.
Edited by Bomber Watson, 17 October 2012 - 07:25 PM.
#9 _stretchlc_
_stretchlc_
Posted 17 October 2012 - 08:08 PM
I just dont get why people call Manual GEARBOXES.....Transmissions!....................I always thought that a transmission was an automatic transmission and a gearbox was, well....a GEARBOX!!
#10 _Bomber Watson_
Posted 17 October 2012 - 08:09 PM
No, still a transmission.
Gearbox is aussie slang.
#11 76lxhatch
  • 7,208 posts
Posted 17 October 2012 - 08:49 PM
Everyone has basically said it all but just in case it needed reinforcing... re-think your budget to something more realistic like $3K and get a decent Muncie and clutch
#12 yel327
  • 13,658 posts
Posted 18 October 2012 - 07:12 AM
Muncie. You'll smash a standard Toploader with a 377/383, unless it has been built right which costs as much as a new Muncie.
#13 TerrA LX
Posted 18 October 2012 - 09:23 AM
But OP suggests "just cruising"
#14 _chrome yella_
_chrome yella_
Posted 18 October 2012 - 11:11 AM
get a close ratio toploader, they shift like a muncie and are stronger than a standard ratio T/L
#15 yel327
  • 13,658 posts
Posted 18 October 2012 - 11:30 AM
Just cruising...can't beat an auto. Much easier and cheaper in the end.
#16 _Liam_
_Liam_
Posted 18 October 2012 - 07:43 PM
Muncie or TKO. There is no middle ground.
#17 _Quagmire_
_Quagmire_
Posted 19 October 2012 - 07:22 PM
those the gt boxes?
priced one of those lately?
even for a secondy handy i think you'd have change after buying a new muncie or tko
