keeping moisture out of compressor lines
#1 _pocock_
Posted 02 November 2012 - 11:03 PM
of running copper pipe out of the compressor and coiling 3 or 4 metres up in a bucket wiith water in it that cools the air down before hitting the water trap i was thinking of using this method and putting the water trap about 10 metres after the copper pipe so the trap will be about 14 metres away from the compressor then another trap another 10 metres away from the first one was told you can even add ice to the water for better results i was just wondering if you need to put some sort of drain plug in the copper pipe is this a good method
#2 _Bomber Watson_
Posted 02 November 2012 - 11:07 PM
Best working trick i've tried so far. I went away from it to expeirment a bit but nothing has worked as well yet.
Downside is you gotta keep buying ice. Water on its own doestn quiet cut it.
If your going to be doing some spraying have several bags of ice on hand.
For just general air tool use water alone would work i suppose.
#3 _sjp67m_
just wondering the best method of keeping water out of your your air linesi have read about a method
Is this for a budget fix (home use?)
If not a air dryer which I just got fitted to my compressor at my workshop is amazing but costed about 1200 with fitting but that's nothing compared to the cost of air tools
#4 _pocock_
Posted 02 November 2012 - 11:31 PM
#5 _Bomber Watson_
Posted 02 November 2012 - 11:35 PM
Water traps dont collect water when its a vapour, you need to condense it to a liquid first, this is why you need to cool the air, and copper pipe in water + ice is the best method i've found thus far.
Did try running it through the shed beer fridge, had the copper pipe coiled in the bottom, didnt work nearly as well, so tried boxing that area in and filling it with water, worked reasonably well but again not quiet as well.
#6 _pocock_
Posted 02 November 2012 - 11:45 PM
#7 _Bomber Watson_
Posted 03 November 2012 - 10:03 AM
Posted 03 November 2012 - 10:16 AM
Picture this system with the two middle sections removed;
And this set up tacked onto the end,
Also make sure you regularly drain the tank and end cock and don't spray in high humid conditions.
#9 _Bomber Watson_
Posted 03 November 2012 - 10:58 AM
I just draw something on a piece of paper than take a photo of it.
Posted 03 November 2012 - 11:02 AM
Still gonna load them thru photobucket just the same as the ones I posted, maybe you got problems viewing photobucket???
Edited by TerrA LX, 03 November 2012 - 11:03 AM.
#11 _Bomber Watson_
Posted 03 November 2012 - 11:05 AM
Posted 03 November 2012 - 11:29 AM
Posted 03 November 2012 - 11:30 AM
Posted 03 November 2012 - 11:52 AM
#16 _tryhard_
Posted 03 November 2012 - 12:05 PM
Posted 04 November 2012 - 07:55 AM
ok, what about this morning haha.
They're working now, must have been the scotch on my cornflakes frOckin with me
Posted 21 May 2013 - 07:17 PM
Anyone tried this?
The ice idea is good if you paint all in one day, but i'll be priming in bits and pieces so it's not practical.
Thinking this unit looks OK, but expensive for a plastic container with toilet paper inside. I don't mind if it works, should do?
Any thoughts?
$(KGrHqZHJCIFCChF!h87BQj7Rlmo3Q~~60_57.JPG 331.12K 8 downloads
www.ebay.com.au/itm/221147079594?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Posted 22 May 2013 - 08:42 AM
Posted 22 May 2013 - 11:18 AM
Is it an air filter or a moisture trap?
Have you tried local auto paint suppliers for similar items?
#21
Posted 22 May 2013 - 07:26 PM
#22
Posted 22 May 2013 - 07:58 PM
Hmmm, my mind turns to wet toilet paper, not something I would want in my air line.
#23 _pocock_
Posted 24 May 2013 - 11:07 PM
yeah i just have a couple of ice cream containers filled with water and frozen and drop them in
then when finished put them back in the freezer they cool down the copper pipe well ,,they work a treat being a big block of ice they take a fair while to melt and dont cost anything
#24
Posted 27 May 2013 - 09:08 PM
Looks similar to the franz filters I used to use back in the 80's. They are still available.
#25 _Red One_
Posted 27 May 2013 - 09:59 PM
Check out using 'brine water'. By simply adding some salt into your water/ice mix the temperature can be somewhat colder.
I'm too lazy to google it but you should have a read. Might be worth a try and it wont rust the copper.
