Porting 12 port heads
_rb3torana_
Posted 10 November 2012 - 04:22 PM
Posted 10 November 2012 - 07:44 PM
_STRAIGHTLINEMICK_
Posted 10 November 2012 - 09:33 PM
_rb3torana_
Posted 11 November 2012 - 08:16 AM
_stretchlc_
Posted 11 November 2012 - 08:45 AM
_rb3torana_
Posted 11 November 2012 - 09:01 AM
_stretchlc_
Posted 11 November 2012 - 09:06 AM
_rb3torana_
Posted 11 November 2012 - 03:19 PM
G'day mate,I am using an open manifold and a ported 12 port head which is tapered to a point at manifold face where tthe head bolt is.It seems to work well it does a 13.1 @100 N/A.It would be best to start with a black motor head as they have a good short turn as cast.
Are you using a aussiespeed manifold on your car? If so have you noticed that no6 runs richer than the rest? Well on my car it does, no5 is fine just no6 is richer. Still alot better across the cylinders than any other 6 cyl manifold Ive used.
_ljxu1torana_
Posted 11 November 2012 - 04:08 PM
dont put a stall in it.i would put a done up trimatic than a done up glide.Yeah 175 13 inch tyres dont help, nor does the manual and open centre diff lol. But it is surprising how much traction it does actually get lol. On the 13.1 run I half missed 4th gear and it only ran 110mph, going off the half track times it would have ran a 12.93 lol. You have to sort of squeeze it in first gear. It will eventually get a powerglide big stall etc.
Posted 11 November 2012 - 04:10 PM
_rb3torana_
Posted 11 November 2012 - 07:52 PM
_STRAIGHTLINEMICK_
Posted 11 November 2012 - 09:01 PM
I did have an Aussiespeed manifold and 450 holley, some cyls were richer than others but definatley better than other 6cyl 4bbl manifolds.At the moment i'm running 2" su's on an armours manifold.Are you using a aussiespeed manifold on your car? If so have you noticed that no6 runs richer than the rest? Well on my car it does, no5 is fine just no6 is richer. Still alot better across the cylinders than any other 6 cyl manifold Ive used.
_ljxu1torana_
Posted 11 November 2012 - 09:21 PM
i should have said not to use a big stall.that is what i ment to say.personally i would stick to using the manual because turbo holden 6s,use tall diff gears because they work on load.using low diff gears is a no no.it is like taking a knife to a gun fight.thanks jason.No stall? WTF Jason?
Posted 11 November 2012 - 09:42 PM
_rb3torana_
Posted 12 November 2012 - 07:20 AM
_stretchlc_
Posted 12 November 2012 - 01:48 PM
_rb3torana_
Posted 12 November 2012 - 06:46 PM
Posted 12 November 2012 - 07:17 PM
Had a much better cutaway, i gave them to Heath, perhaps PM him for some photo's, forgot to take picks before i gave them to him.
_rb3torana_
Posted 12 November 2012 - 07:19 PM
_oldjohnno_
Posted 12 November 2012 - 07:36 PM
Edited by oldjohnno, 12 November 2012 - 07:37 PM.
#21
_rb3torana_
Posted 12 November 2012 - 08:45 PM
Edited by rb3torana, 12 November 2012 - 08:54 PM.
#22
_rb3torana_
Posted 13 November 2012 - 08:19 PM
#23
Posted 14 November 2012 - 08:06 PM
What chamberr size did you end up with?
Edited by Bomber Watson, 14 November 2012 - 08:07 PM.
#24
Posted 14 November 2012 - 08:34 PM
Edited by Stinga, 14 November 2012 - 08:37 PM.
#25
_rb3torana_
Posted 15 November 2012 - 07:26 AM
