Big block vs small block fuel consumption
Posted 12 November 2012 - 09:03 PM
Everyone, as soon as you mention the word "big block", instantly states the fuel consumption will be absolutely terrible.
But upon pondering this in my mind for quiet some time now, I cant quiet understand why.
im sure in standard guise, straight from the 70's, theres a marked diffference between a big block and a small block, but i cant understand why a big block will, apparently, always chew more fuel.
Lets set up a few nice little scenario's.
I quickly selected two engines, based on basically nothing bar both being Chevrolet one being a 350ci chev and the other being a 427 chev and the fact that they both make near on the same peak HP and torque.
Here are the engines:
350:
http://www.summitrac...45910/overview/
427:
http://www.summitrac.../make/chevrolet
Sadly these engines i picked dont list the rpm at which peak HP and torque are achieved, i was trying to find two which did list these but i couldnt find any in the same kinda hp/torque ballpark.
But basically we can assume roughly that the Big block being 22% larger in capacity will make its peak torque 22% lower than the 350, i say roughly and assume, remember.
Now lets throw a few constants in. Both engines are tuned for good efficiency within reason, exhaust system is designed around promoting the area around max torque etc.
The car will weigh 2000kg with the small block. Obviously the big block car will weigh a little more, About 2050kg. I couldn't find a reliable weight figure for the two engines but it seems a BBC is about 50kg heavier than a SBC... I think the actual type of car is irrelevant for this. Lets assume its teh same car in both situations so same frontal area same drag coefficient etc etc.
Both cars will run the same 5 speed manual. Both cars will have the final drive ratio tailored to suit the particular engines characteristics.
Everything else on the two cars will be identical.
So, explain to me, please, why the big block powered car will have so much worse fuel economy?
I can see a little bit of difference, Mainly extra friction due to the larger bore, more ring contacting = more friction, larger bearings, and the extra weight.
I also think it may have something to do with the size of the inlet ports, BBC's seem to run larger valves and inlet port volumes than SBC's of comparable HP. This would effect efficency by reducing air speed i think.
But why the massive difference? The way people rant on you would assume that the BBC would consume up to 10 litres per 100km more fuel, but i'd be surprised to see, in this instance more than 1lt per 100km difference?
Around town? Bit more, on the highway, negligible?
Now for fun lest stick a 2000kg trailer on the back of our sample car, how would this affect the difference?
I think the BBC would always last longer, being a bit less highly strung, assuming the same consideration was put into the engine building.....
Im just curious about this, please, discuss.
Posted 12 November 2012 - 09:07 PM
Posted 12 November 2012 - 09:10 PM
To expand upon that slightly, i just noticed that the SBC in this case uses 1.94 in. intake, while the big block uses 2.190 in intake. Considering they both make the same HP and torque i think the larger inlet valves, and generally fair bit larger inlet port, and inlet manifold runners, would be a factor, especially around town?
_Quagmire_
Posted 12 November 2012 - 09:11 PM
as you wouldn't be reving the big block as much for the same performance
i know i could get better economy with my 253 powered hj than my 202 powered ones if i tried
towing would be a no brainer....
Posted 12 November 2012 - 09:15 PM
Posted 12 November 2012 - 09:22 PM
But thats just the way I like it
Posted 12 November 2012 - 09:25 PM
_Shaune_
Posted 12 November 2012 - 09:35 PM
- I guess that’s why its called average fuel consumption – over a variety of driving conditions.
When I accelerate in my VZ Monaro, the fuel consumption goes through the roof, although on the highway it’s not too bad. A Barina on the other hand, accelerating doesn’t consume as much a 6L engine constantly accelerating, however on the highway its reving like no tomorrow….
but again we're not talking about similar enagines and talk as Bomber outlined....
torque even..
Posted 12 November 2012 - 09:37 PM
Suppose i should have added driving style as a constant in the above thing to.
_Shaune_
Posted 12 November 2012 - 09:40 PM
_Viper_
Posted 12 November 2012 - 10:59 PM
Theres no way my 500 cube Caddy will use less fuel than a comparable small block
If you had a 350 Chev in your caddy would it not be under a lot of load and need to be pushed a lot harder to pull the weight compared to the big block doing it with relative ease?
_oldjohnno_
Posted 13 November 2012 - 05:03 AM
Posted 14 November 2012 - 08:12 PM
So do you think the comparitively larger inlet port and larger inlet valve, even with the two engines listed making the same HP/torque would be a factor?
After all the smaller SBC valve can obviously move enough air to make the power....But then i suppose its opening and closing more frequently than the BB one....
_oldjohnno_
Posted 14 November 2012 - 08:28 PM
Posted 14 November 2012 - 08:47 PM
And if I swapped out the cast inlet manifold for alloy and put alloy heads on it the SBC is allegedly heavier
500 cubes for max torque
Very few stock engines (comparable petrol) can compare to a Caddy donk
