Hydraulic throw out bearing
15 replies to this topic
#1 _nemo355v8_
_nemo355v8_
Posted 25 November 2012 - 08:50 PM
For those interested in doing away with there with the big dellow or CRS slave cylinder on the side of there bellhousing the Quarter master 721 series hydraulic release is the correct size for the M20/21 gear box tube,
I brought one as Im going to a TKO box and just out of interest I tried it on my old M21 and its a perfect fit.
Im also going to use one of these and do a under dash master cylinder conversion
http://www.ebay.com....#ht_1700wt_1037
Edited by nemo355v8, 25 November 2012 - 08:52 PM.
#2 dattoman
  • 16,487 posts
Posted 25 November 2012 - 10:40 PM
Yup
I'm a fan
#3 _red roar_
_red roar_
Posted 26 November 2012 - 06:04 PM
Nemo, is that the style of under dash unit mal woods and the likes use? i'd love a good look at one in position
#4 _nemo355v8_
_nemo355v8_
Posted 26 November 2012 - 07:55 PM
The malwoods set up is a whole pedal and pedal box and uses a BA Falcon master cylinder, the master cylinder is a lot like the one from wilwood.
I was thinking of using a BA cylinder but at around $250 for just the master cylinder the wilwood set up works out better on the pocket.
I havnt ordered the cylinder yet as I need to work out if I need a 3/4 inch or 13/16 cylinder.
Will post pics of how I go mounting it But dont hold your breath waiting as I really busy and is not high on the to do list, But I will be doing it as part of the TKO conversion.
Will also post a pic of the hydraulic release bearing on a M21 when I get time to get into the shed
Edited by nemo355v8, 26 November 2012 - 07:57 PM.
#5 76lxhatch
  • 7,208 posts
Posted 26 November 2012 - 08:52 PM
Interesting, I used a Tilton Muncie setup on an Aussie 4 speed years ago but had to cut down an old bearing retainer to adapt it as the input shaft is so much longer on the V8 Aussie boxes
#6 _nemo355v8_
_nemo355v8_
Posted 27 November 2012 - 07:03 PM
This is on a M21, would need spacing up towards the pressure plate more but nothing head about setting it up for a aussie box
#7 _nemo355v8_
_nemo355v8_
Posted 27 November 2012 - 07:05 PM
forot to click on attach this file oopps
#8 _nemo355v8_
_nemo355v8_
Posted 21 January 2013 - 05:53 PM
Today I finally got the time to do my under dash master cylinder.
Here are some pics of the TKO and hydrualic throw out bearing bolted up tp the motor and of the under dash master cylinder, pretty easy realy there is plenty of room above the steering colum.
#9 _nemo355v8_
_nemo355v8_
Posted 21 January 2013 - 06:36 PM
A few more pics
#10 76lxhatch
  • 7,208 posts
Posted 22 January 2013 - 06:29 AM
Nice, that master must be quite close to the ignition switch?
Got another one of those Tilton bearings for my Muncie recently:
Price is a bit silly and they no longer have decent length hydraulic lines but its a massive improvement on any fork actuated setup. I'm still using it with the angled HR style 1" master with the stroke drastically shortened via pushrod mounting alterations.
Where are you planning on putting the reservoir?
#11 myss427
myss427
  • 1,636 posts
Posted 22 January 2013 - 11:27 AM
Would you have the part number for the WQillwood Master by chance?
#12 _nemo355v8_
_nemo355v8_
Posted 24 January 2013 - 08:52 PM
close to ignition switch but no where near touching, works out a very good fit.
Reqiures a small trim on the front part of the hand brake mech to clear the front bolt.
Only had a quick look as to where to mount the fluid cylinder, most likely where the old CRS master cylinder mounted to clean up the butcher hole tha is there.
#13 _nemo355v8_
_nemo355v8_
Posted 24 January 2013 - 08:55 PM
Wilwood 260-5920 Master Cylinder Aluminum Natural .813 in. Bore Universal
Thats the part number for a 13/16 cylinder, you can get that style cylinder from 5/8 to over 1 inch
#14 _nemo355v8_
_nemo355v8_
Posted 16 February 2013 - 09:36 PM
Any one doing this use a 3/4 inch cylinder, I went 13/16 and my clutch was over throwing and had to limit pedal travel by bolting a block to my floor under the carpet.
Was advised I need a 3/4 inch master with 1.5 inch stroke, the wilwoods cyinders only have a stroke of 1.1 inch hence going up a size in cylinder.
3/4 1.1 inch would of been plenty
#15 christolx
christolx
  • 184 posts
  • Name:Chris
  • Car:1976 LX SL Coupe
Posted 01 March 2017 - 04:58 PM
Great advice there nemo355V8. I am looking at sorting a hydraulic setup for my M22 at the moment.
#16 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 05 March 2017 - 02:31 PM
Here's how it was done in my Mustang, you have to shim up the bearing to the right distance so it travels where it should when you hit the pedal, my mechanic also welded on an adjustable bolt and striker plate to prevent it travelling further, in case.
http://www.gmh-toran...e-3#entry817244
s
