so it came time to fit the engine in.
Hooked it up on the chain block and went to drop it in. suprise suprise it didnt fit!
You can just see the edge of the sump hitting the crossmember fairly substantially.
A couple more photo's.
I took the engine in and out about 5 times to see if i had done anything wrong in the set up,tried lifting at different angles and all sorts but knew it wasnt going in...
So i marked around the sump with the white paint pen to get an idea of how much i needed for clearance.(can see the marks on the previous pic of the crossmember)
ripped the engine out.Put the engine on the stand,locked the shed and went and cracked a few Jacks cans and got a bit munted.
After a couple of days,a few phone calls,emails of pictures i pulled the front end out again.
I found out you can lift the whole front end,tyres rims and complete suspension by yourself when you are mighty piss&d off!!
Anyway,stripped the crossmember down to a bare assembly again and it went back to CRS. I dropped it off at my sister's workshop where it had previously been picked up from and rang them to let them know it was ready to go back.
Off to work i go and for a week and a half i hear nothing,until my sister messaged me and said it was still at their workshop and hadnt been picked up.
Well it took me half an hour to calm down before i rang them up and got 'we thought you were going to send it back'
For F$%#ks sake!!!! well it got picked up two days later and was back again in a weeks time.
This time i was told it couldnt be modified anymore because it would affect it's strength. So it came back like this.
It did look better,but i was sceptical for some reason.
so back to re-assembling the suspension(getting good at this)and putting it back in.
So the front end is in and i lift the engine in and again,it doesnt fit.
The flat section in the bottom doesnt let the sump go down far enough to get anywhere near the engine mounts
and the humped section is about 8mm too high to clear the sump as well
So after another lot of phone calls and pictures i was told i have to modify my sump. hmmm i dont think so
I rang an engineer friend and had a chat with him and after a plan was established,i decided to make it fit myself.
So out came the white paint pen again,marked some lines and had a clear plan in mind.
So the chopping started.Firstly out with the blue tongued lizard,and then the slitting disc on the grinder.
So the slits in the top section allowed the top to be bent down slightly for clearance of the sump.I V'd out the slot again and welded it all up.The cut out at the back allowed the sump to drop down far enough for the engine mounts to be close to bolting up. Yet again, found another problem. The engine mount brackets are on a stupid angle to where they shoud be.I even got a straight edge and ran across the front of the mounting blocks just to see how far they are out.
So these will have to cut off and re-positioned. I'll make up a jig off of the original k-frame and mounting points to try and get them close. The mounts also dont go down far enough to get a bolt through on both sides which is a pain as well.
so i did have the engine in there and it was sitting very close to where i was happy with it.
So once again, everything out of the car. Engine,front end and all that jazz.
Now to strengthen the crossmember due to having to cut into it for clearance.
I have only just started doing this and then it was time to go away for the long weekend.
Four days of fishing,drinking and eating certainly helped clear the mind!!
So when i get home from work,i will continue strengthening the front of the crossmember by boxing up the whole front section.
There will be another piece of 25x25x5 angle at the top,then a peice of 75mmx5mm flat barwelded across the front with internal gussets as well.
I'll keep taking pics along way so everyone can see whats been happening.
So there is a short story.
So i guess we'll see what happens and how it goes.
I should have gone and seen a local engineering company and had one made there,but you live and learn.
As always, Buyer beware!!!!
