Sill Mufflers
95 replies to this topic
#1 N/A-PWR
  • 9,639 posts
Posted 11 January 2013 - 10:49 PM
Hi All,
Need help to find out the name of the truck like stack muffler that you run along the sills from the front door on the Lc/Lj Torana 2 door, as a mate had them in the 80's.
They looked cool with the chrome heat shield and finished in front of the back wheel. Dave I
#2 _Bomber Watson_
Posted 11 January 2013 - 10:52 PM
Sidepipe.........
Illegal.....
#3 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 11 January 2013 - 10:58 PM
and look silly on torries.
Take yourself out the back and slap yourself
#4 _tryhard_
_tryhard_
lakepipes most corvetes had them
#5 _Bomber Watson_
Posted 11 January 2013 - 10:59 PM
And Vettes are gay, hence we dont fit such parts to Toranas.....
But yes your bang on Marcus Lakepipes is the correct term for the pipes down the sill with the heat shield thing.
Edited by Bomber Watson, 11 January 2013 - 11:00 PM.
#6 N/A-PWR
  • 9,639 posts
Posted 11 January 2013 - 11:04 PM
Great Info Guy's,
So they are Legal in the States, I got to slap myself in the head with a Corvettes set. Dave I
They are everywhere thank's:-
http://www.google.co...iw=1447&bih=653
Edited by TORYPOWER, 11 January 2013 - 11:08 PM.
#7 _ljxu1torana_
_ljxu1torana_
Posted 12 January 2013 - 02:34 AM
Sidepipe.........
Illegal.....
why are they illegal.
#8 _oldjohnno_
_oldjohnno_
Posted 12 January 2013 - 07:26 AM
Criminally poor taste?
#9 warrenm
warrenm
  • 2,118 posts
  • Car:1972 LJ Torana
Posted 13 January 2013 - 06:31 AM
The exhaust needs to exit 400mm(from memory) past the last opening, which on a 2 door is behind the diff.
#10 N/A-PWR
  • 9,639 posts
Posted 13 January 2013 - 08:54 AM
Hi warrenm,
Thank's for that - A friend of mine say's it is 650mm behind the last window, and he also said you can get an open permit for lakepipes.
So if we put the exhaust output facing in, run an extension up over the diff and back down behind the rear wheel, we could be in business. Dave I
Edited by TORYPOWER, 13 January 2013 - 08:54 AM.
#11 racean69
racean69
  • 782 posts
  • Name:Rod
  • Car:LH sedan
Posted 13 January 2013 - 10:04 AM
noooo Dave...
#12 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 13 January 2013 - 10:58 AM
Im pretty sure its to do with them getting red hot and people walking into them as much as the window distance thing.
#13 _niterida_
_niterida_
Posted 13 January 2013 - 11:17 AM
From the NCOP :
The outlet of an exhaust system must be rearwards of any passenger side entry door or opening
window. If any part of the exhaust system, including the outlet pipe, extends beyond the profile of
the body (other than on the underside), it must be shielded. Exhaust outlets must also meet the
requirements of ADR 42/… where applicable. Vehicles manufactured after June 1988 must not
have the exhaust exiting to the left of the vehicle.
So pre-1988 should be able to run sidepipes. But as others have said - why would you ? Because they can look awesome done right and on the right car - Corvettes and Cobras spring to mind.
If its what you want on your car then do it :)
#14 N/A-PWR
  • 9,639 posts
Posted 13 January 2013 - 12:57 PM
Great work niterida,
Now this is why the Lc/Lj Tory had the Lake-pipes on, as they possibly took the ADR book with them.
We are one step closer, now to find a 2.5" set. Dave I
p.s. I heard the Lake-pipes have catalytic converters built in as well, in our case pre 1988
#15 N/A-PWR
  • 9,639 posts
Posted 13 January 2013 - 02:04 PM
Hi All,
This place has some 1 3/4" to 2" inlet in different lengths with the heat shields:-
http://www.jegs.com/i/Patriot+Exhaust/737/H1080/10002/-1
#16 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 13 January 2013 - 02:13 PM
Do you have any pics of an LC/J with them on.
Just want to see what they look like on the car before we have to send someone around to beat some sense into him. :D
#17 N/A-PWR
  • 9,639 posts
Posted 13 January 2013 - 02:19 PM
Hi Mort,
Wish I took pictures of every good thing I seen - I have searched Goggle for an image with no luck ( rare thing )
oh and don't need to send anybody yet. Dave I
#18 _Bomber Watson_
International laws of the internet Prohibit such atrocities, thankfully.
I saw a picture once, burnt my computer to the ground then stared into a HID spot light for a full hour trying to get rid of the image burnt on my retinas.
Think of a UC with flares, and multiply that horridness by 1000, and your 1/4 the way there.
#19 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 13 January 2013 - 02:29 PM
:spit: :spit: :spit:
#20 N/A-PWR
  • 9,639 posts
Posted 20 January 2013 - 10:36 AM
Yes BAD UC Darren,
Our First Picture of Lakepipes on a Tory. Regards Dave I
p.s. I read somewhere that Lakepipes give an extra 6hp at idle.
Edited by TORYPOWER, 20 January 2013 - 10:40 AM.
#21 N/A-PWR
  • 9,639 posts
Posted 20 January 2013 - 01:30 PM
OK,
Here is a Chop Job of how I will do my RAT:-
http://toranaclub.co...kepipes/RAT.bmp
p.s. the sills are removed and replaced with a con-caved piece so the Lakepipe sits snug.
Edited by TORYPOWER, 20 January 2013 - 01:33 PM.
#22 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 20 January 2013 - 03:48 PM
Those arent lakes pipes.
These are lakes pipes.
Edited by wot179, 20 January 2013 - 03:50 PM.
#23 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
  • Car:76 LX Sedan, 4 seater
Posted 20 January 2013 - 04:17 PM
Wot is correct, the other pic isn't Lakes pipes.
They look better if they come outside the body with perforated guards over the top.
Run the outlets like Wot's pic with blanking plates either on the outside or behind a bolt tail-piece(that cannot go outside the line of the guard.
Then have another outlet on the inside of the pipe running under the car and dumping over the diff.
Then you've got all the looks of the Lakes pipes, and you can uncap them and drop the dump pipes at events/shows......
Grant..
#24 N/A-PWR
  • 9,639 posts
Posted 20 January 2013 - 05:15 PM
Hi wot179 and enderwigginau,
Great posts and we can incorporate ideas.
I did ask for the name of the Truck like Mufflers with guards which Corvettes have them on, so what are they called? DJ said side-pipes.
The Picture that BAD UC put up, is more like the type that I am looking at only with perforated guards. Dave I
#25 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 20 January 2013 - 05:36 PM
Ive always known them as sidepipes.
Love them on 80s panelvans,but not on much else.
