* * * * * 1 votes
The Marty Report
LJ GTR Build
1095 replies to this topic
#26 Potta
Posted 23 January 2013 - 12:00 AM
Nice work mate.
Might have to borrow your door removal tool one day :-)
#27 kiwi-lilj
kiwi-lilj
  • 1,426 posts
  • Name:Blair
  • Car:LIL J
Posted 23 January 2013 - 06:27 PM
Two hands on the grinder thanks Marty
#28 _LONA-CK_
_LONA-CK_
Posted 23 January 2013 - 08:20 PM
gee im in trouble then
cheers gong
#29 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 23 January 2013 - 08:28 PM
hahaha
nice one
#30 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 23 January 2013 - 10:04 PM
I quickly found out what can happen.
Attached File  IMG_1998.jpg   64.05K   42 downloads
Started stripping the paint to find the hidden damage. The car has had a second hand purple LH guard and nose cone and lower beaver section fitted. The RH side of the headlight had been dinged, would like to fix this up but not sure how, due to no access behind. May have to cut it out and fix it and weld back in or fit from doner, any one got this part of a guard lying around.
Attached File  IMG_2008.jpg   68.44K   39 downloads
Attached File  IMG_2018.jpg   36.65K   37 downloads
Cut away the lower fender to check the damage, not too scary, hope to fabricate these parts myself.
Attached File  IMG_2015.jpg   57.18K   38 downloads
Attached File  IMG_2016.jpg   50.08K   34 downloads
Potta "Might have to borrow your door removal tool one day :-)" You're welcome to use my super duper door pin remover.
#31 Potta
Posted 24 January 2013 - 01:38 AM
Have you trademarked that name yet?
Nice progress but now is where the real work begins :-)
So far nothing too bad though!
Keep it up mate :-)
#32 _sunburst73-xu1_
_sunburst73-xu1_
Posted 24 January 2013 - 07:24 PM
It's great to see you having a go your self keep at and you'll be driving it before you know it.
#33 Ice
  • 15,202 posts
Posted 24 January 2013 - 08:30 PM
Some nasty cancer there marty go for it mate
#34 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 27 January 2013 - 02:46 PM
"Sunburst73-XU1
It's great to see you having a go your self, keep at and you'll be driving it before you know it."
Cheers Sunburst, I'm still doing the easy stuff as Potta said, sooner or later I've got to do the hard bits. Always willing to have-a-go and learn.
The last week has been about trying different methods of paint stripping. No matter what method I used I couldn't get the original etch to come off and had to resort to the grinder and paint remover pad.
I honestly found no benefit by covering with plastic, this just may be my paint or conditions but the results were the same when it wasn't used. I think scoring the paint first helped but on the panels that were from another car two coats of stripper were required.
Here's a quick video of me doing the roof, this was scored, covered and left for around 20 mins and the result is average but better than sanding off the whole lot. I did get a bit of stripper on the shirt and had to do a quick change as it started to dissolve my flesh. "Todays shirt is tomorrows rag"
The bonnet was also off another car, maybe a Plum dinger, and took two goes of stripper.
Attached File  IMG_2030.jpg   47.24K   35 downloads
Attached File  IMG_2031.jpg   70.41K   31 downloads
Attached File  IMG_2032.jpg   47.83K   33 downloads
Heres the question, What's going on here? It appears on both sides below the rear windows. There is a kink in the body line. No sign of repair or damage and looks like factory made.
Attached File  IMG_1714.jpg   27.15K   34 downloads
Marty
#35 _LONA-CK_
_LONA-CK_
Posted 27 January 2013 - 05:32 PM
that is factory and if you run your hand from there along the rare about 150 there is a indent that is also part of that factory press, even know i have seen lots of these bogged up over the years.
to paint stripping with paint stripper, sit in sun under dark plastic for 35 to 45 mins then it will come of alot easier.
stripper wheels on the buff are the best thing for original red oxide primer.
cheers gong
Edited by LONA-CK, 27 January 2013 - 05:44 PM.
#36 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 27 January 2013 - 05:50 PM
I would steer clear of scoring the paint,you can score the metal as well which can cause sinking problems with the paint later.
#37 Potta
Posted 27 January 2013 - 06:34 PM
I like the bits where you're standing there watching and waiting, That doesn't strike me as something that comes natural to you.
You are really getting into this now, once you start stripping paint there is no turning back mate.
#38 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 03 February 2013 - 10:13 PM
cheers gong
Thanks Gong, might leave them there for that unmolestered look.
. Cheers wot179, by scoring I really just roughed it up with some 36 grit.
Not much progress on the car this week, the weathers been great and have been out on the in-laws boat twice. It's a tough life here in the west. Best of luck to all the flood victims over east.
Attached File  IMG_5297.jpg   67.63K   33 downloads
When I did get in the cocoon it was all about testing things. The sandblaster needs tweaking and I'm going to have to get a bigger compressor, mine will drive me mad at how slow it is.
Have been looking for an anvil for bashing my steel on but these are rarer than a 2 door LJ and costing almost as much. One guy wants $3000 for his. Most are between $300-$500 so I decieded to use an old block and welded an old vice to it. Works really well and has been super handy and free.
Attached File  IMG_2083.jpg   66.25K   35 downloads
Made the front bracket for the rotisserie attachment.
Attached File  IMG_2081.jpg   55.23K   42 downloads
Attached File  IMG_2082.jpg   54.65K   33 downloads
Built a press brake for bending steel.
Attached File  IMG_2087.jpg   58.9K   34 downloads
Sorted out my airline into the cocoon.
Attached File  IMG_2080.jpg   48.72K   34 downloads
Marked out the cut lines for the flutes.
Attached File  IMG_2073.jpg   54.71K   31 downloads
Stripped the steering column down and removed the 3 speed linkages.
Attached File  photo.JPG   111.05K   32 downloads
If anyone notices that I'm doing something the wrong way please let me know. This is all new to me and self taught by you guys and you-tube.
Marty
#39 71xu1
71xu1
    Dave
  • 1,275 posts
  • Car:LC GTR XU1
Posted 03 February 2013 - 10:44 PM
Looking good Marty be ultra careful when welding those flutes in. Really take your time.
Cheers Dave
#40 Ice
  • 15,202 posts
Posted 03 February 2013 - 10:50 PM
And make sure you get the angle right otherwise they will pick the shit out of them on here you know how they are on here
#41 S pack
  • 15,726 posts
Posted 03 February 2013 - 10:56 PM
hehe, if he claims it to be a genuine original unrestored GTR or XU1 then f#%K yeah I'll pick the shit out of it. :)
#42 Ice
  • 15,202 posts
Posted 03 February 2013 - 10:58 PM
See i told ya
#43 Potta
Posted 03 February 2013 - 11:25 PM
Only thing I can see that you're doing wrong is going much too fast!!
Putting the rest of us to shame.
Seriously though, she's looking great mate, as do the boats in the bay :spoton:
And nice work on all the tools you are making, saved yourself quite a few dollars so far.
#44 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 12 February 2013 - 10:14 PM
G'Day all,
A bit more progress,
Started preping and painting a few parts so I can put them away. Applied a rust converter, then etch primer and then a hi fill 2 pack primer. There is a bit of pitting in the booster I want to hide. These parts i'll do in 2 pack black satin.
Attached File  IMG_2151.jpg   61.95K   36 downloads
Attached File  IMG_2152.jpg   56.41K   35 downloads
Attached File  IMG_2158.jpg   53.59K   35 downloads
Had a real tough time on the bolts that connect the K Frame to the chassis under the car, they were rusted solid and had to be cut.
Attached File  IMG_2196_2.jpg   63.84K   40 downloads
Finally the moment I have been waiting for...
Lift-off
Attached File  IMG_2187.jpg   51.29K   37 downloads
Attached File  IMG_2191.jpg   46.55K   42 downloads
First real look at the underneath of the car and no hidden dramas.
Found out the rotisserie was too short so I had to ad a section to the conection system. Unusual cause the Torana's a small car? Must be ment for a mini, still happy for $630.
Marty
#45 _markm_
_markm_
Posted 12 February 2013 - 10:30 PM
Excellent work mate. How did you end up connecting the rear to the rotissiary ?
#46 Potta
Posted 13 February 2013 - 12:35 AM
I can't believe it was too short. What is supposed to fit on it?? :D
You're doing a great job mate, keep it up. :spoton:
#47 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 13 February 2013 - 09:07 AM
Thanks Craig and Mark,
I've used 50mm square tube along the back and packed out the ends with washers, then a piece or 50mm angle bolted to the boot lid retainer.
Next I just joined the two together with bits of scrap.
Cut the rotisserie mounts to size and notched them to fit around square tube.
Attached File  photo.JPG   115.94K   41 downloads
Attached File  photo.JPG   133.72K   38 downloads
Attached File  IMG_2182.jpg   63.05K   37 downloads
Got to see a stripped GTR and now have the measurements and size of the 4 speed hole.Attached File  IMG_2150.jpg   52.95K   49 downloads
#48 Potta
Posted 13 February 2013 - 09:17 AM
That's interesting that there isn't a hole there already.
This was talked about on another thread, and it seems a lot of cars came with the D shaped hole even if they were column shift, eg my LC.
Maybe the LJ's did not?
Anyway, good to see you're still enthusiastic after all that you've done, I was starting to get worried when your post frequency dropped off but I can see now its cause you were busy :spoton:
#49 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 13 February 2013 - 11:49 PM
Today was wire wheel day and how to turn black in 5 mins.
I started to wire everything but soon found the bitumen coat in the wheel arches to be a real prick. Played around a bit and tried an old wood chisel (sharp) to be the best for scraping 90% of it off then hit it with the wire, much easier, quicker and cleaner.
After chisel action
Attached File  IMG_2208.jpg   45.34K   39 downloads
Then wire wheel
Attached File  IMG_2210.jpg   39.53K   40 downloads
Attached File  IMG_2213.jpg   51.97K   37 downloads
Playing with the panorama function on my iphone
Attached File  IMG_2221.jpg   26.52K   43 downloads
Attached File  IMG_2222.jpg   23.79K   40 downloads
Attached File  IMG_2223.jpg   40.16K   38 downloads
#50 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 14 February 2013 - 12:28 AM
I heard they stopped putting the holes in and blanking plates in 72?
