Steel Camshaft Material
35 replies to this topic
#1 N/A-PWR
  • 9,639 posts
Posted 17 January 2013 - 04:50 AM
Hi All,
As I am getting a Comp Cam made as a 41/73, the material is needed.
Steel Billet Camshaft Material is requested by Comp Cams,
'Quote' I will see if there is anything in billet.. What material? 8620? 'end Quote'
Can anyone help with the steel type material number?
Best Regards Dave I
#2 _oldjohnno_
_oldjohnno_
Posted 17 January 2013 - 07:26 AM
8620 is probably the most common material for roller cores - I'm assuming this is for a solid roller. Austempered ductile iron ("cast") is fine for most flat tappet cams (including nearly any remotely sensible Holden six cam) and for hydraulic rollers with moderate spring pressures and rpms. Don't forget to use the appropriate oil pump gear with a steel core and be prepared to change it from time to time.
#3 _Ned Loh_
_Ned Loh_
Posted 17 January 2013 - 07:44 AM
Dave,
what engine is the cam for?
Don't know the full answer to your original question (sorry), but keep in mind that certain camshaft treatments go hand in hand with certain materials. Billet material is the sort of thing you'd expect the cam company to be telling you (based on the application and their experience), not asking you.
#4 _oldjohnno_
_oldjohnno_
Posted 17 January 2013 - 08:57 AM
Exactly.
#5 N/A-PWR
  • 9,639 posts
Posted 17 January 2013 - 12:12 PM
Thank-you oldjohnno and Ned Loh,
HOLDEN SIX and I will check for the Oil treatments recommended Ned.
Well done Fella's - So I looked up Google and seen lots of company's using the '8620' material for the Solid Roller Cam, return eMail sent.
So then I seen that Comp Cams have the Roller lifters too:-
8620 steel alloy body
9310 steel alloy wheels
These are not for a Six:-
http://www.compcams.com/Products/CC-'Elite%20Race'-0.aspx
Thank-you again for pointing me in the right direction. Dave I
#6 _Ned Loh_
_Ned Loh_
Posted 17 January 2013 - 12:38 PM
Have Comp confirmed they will make you a steel billet cam?
Oh, and I didn't mean oil treatments. I meant heat treatment (of the camshaft). Ask your cam company if they recommend any sort of heat treatment for the cam material they end up using.
#7 N/A-PWR
  • 9,639 posts
Posted 17 January 2013 - 01:59 PM
OK Ned Loh,
I will keep you posted here on the outcome and thank's for the advice. Dave I
p.s. 'Comp Cam' Holden Six Cores are from their Supplier/s.
#8 N/A-PWR
  • 9,639 posts
Posted 18 January 2013 - 01:53 AM
Hi Ned Loh,
Just got confirmation from 'Comp Cams' that they use the '8620 Grade Billet' for both their Hydraulic and Solid Cam Grinds.
Also the Cores are already Heat Treated, now that is great News. Dave I
#9 _Ned Loh_
_Ned Loh_
Posted 18 January 2013 - 07:11 AM
Hi Ned Loh,
Seem to have two threads going along similar lines.
Ok, thanks for letting me know.
#10 _WYLDLC6_
_WYLDLC6_
Posted 18 January 2013 - 08:35 AM
Just a question, how is the core only heat treated. It may be stress relieved as 8620 is commonly used for nitriding.
8620 in pure form is reasonaly tough but not a lot of hardness, maybe 20 rc.
Cheers Chris.
Edited by WYLDLC6, 18 January 2013 - 08:41 AM.
#11 _oldjohnno_
_oldjohnno_
Posted 18 January 2013 - 09:51 AM
Cheers Chris.
It's induction hardened. Any other surface treatments like nitriding or parkerising are separate processes.
#12 _WYLDLC6_
_WYLDLC6_
Posted 18 January 2013 - 10:02 AM
Dave,
Ok. That would make sense. Induction and tempered. Interesting. I wonder what kind of depth they get. Anymore than 2-3mm would surely be overkill.
Edited by WYLDLC6, 18 January 2013 - 10:04 AM.
#13 _oldjohnno_
_oldjohnno_
Posted 18 January 2013 - 12:34 PM
It can be quite deep, apparently insufficient depth can lead to surface cracks and flaking in the long term.
Again, the customer shouldn't have to concern himself with these decisions, he should be able to simply follow the cam companies recommendations. And while it may seem some of the Comp guy's answers aren't all that clear you have to remember that (and I don't want to put too fine a point on this) the quality of his advice can only be as good as the quality of the information that he's given to work with... which sometimes isn't all that flash.
#14 _WYLDLC6_
_WYLDLC6_
Posted 18 January 2013 - 12:55 PM
You will generally always get 2-3mm min depth with induction hardening, flaking/cracking will only happen if untempered. There's probably more stresses involved with straightening after hardening. Just find it interesting that they go down the induction path.
Cheers Chris.
#15 N/A-PWR
  • 9,639 posts
Posted 18 January 2013 - 10:16 PM
Hi All,
New Information:-
Comp Cams have two main suppliers of Billet Cores. Dave I
#16 N/A-PWR
  • 9,639 posts
Posted 23 March 2013 - 04:44 PM
Hi All,
With no Luck from Comp Cams, I now have asked Tighe Cams for a price on the:-
900C 79 51 51 79 310 310 274 274 .550" .550" .030" .028" Road race 4500-8000 rpm.
http://www.tighecams.com.au/cars.htm
#17 _JimAndrews_
_JimAndrews_
Posted 29 March 2013 - 08:48 PM
for gas wheels with average springtime demands and rpms. Don't forget to use the appropriate oil push equipment with a metal primary and be prepared to change it every now and then . . . . . . . . .
#18 _oldjohnno_
_oldjohnno_
Posted 31 March 2013 - 08:52 AM
Intriguing post that appears to have been translated from something other than English. I took it to mean "for normal (steel-core) roller cams don't forget to use a bronze oil pump drive gear and be prepared to change it every now and then"
#19 S pack
  • 15,727 posts
Posted 31 March 2013 - 09:53 AM
Must have been translated from Mazda RX7 Japanese into Chevy American English? Pity he wasn't able to translate it into Holden Australian English, LOL.
Ever thought of a job as a translator John? Looks like you'd be good at it. haha.
#20 N/A-PWR
  • 9,639 posts
Posted 31 March 2013 - 10:51 AM
Hi All and thank-you JimAndrews,
Here is the reply from Dean and the website says this,
Notes -
- Bronze Gears must be used on steel camshafts.
- These profiles chosen because of lower lift.
- For more profiles see Chevrolet s/b roller.
Sent: Monday, March 25, 2013 5:28 AM
To: "'Dave I'"
Subject: RE: Website Enquiry
> Good Morning ,
> The Holden 202 roller camshaft with the 900c is $720.00 Inc gst
> We have a large range of profiles not listed on the Web site if you would
> like other options
> But the 900c does work well in the 202 .
> Regards
> Dean Tighe
> Ivan Tighe Engineering Pty Ltd
> ABN 46 009 747 139 t/a TIGHE CAMS
> 47 Westgate Street
> Wacol Qld 4076, Australia
> Tel (07) 3271 6001
> Fax (07) 3271 6005
> Email: [email protected]
p.s. oldjohnno is a very very good translater hey S pack
#21 N/A-PWR
  • 9,639 posts
Posted 26 February 2015 - 10:57 PM
OK, finally got the 900C from Tighe Cams:-
Attached File  900C-2.jpg   80.98K   4 downloads
Attached File  900C.jpg   85.88K   6 downloads
Attached File  RAT CAM 900C 001.jpg   159.7K   8 downloads
#22 N/A-PWR
  • 9,639 posts
Posted 26 February 2015 - 10:59 PM
Steel Camshaft -  5160 material,
and here is the roller lifter and bridge:-
Attached File  Roller lifter.jpg   79.93K   1 downloads
Edited by NA-PWR, 26 February 2015 - 11:12 PM.
#23 Rockoz
Rockoz
  • 4,035 posts
  • Name:Rob
Posted 27 February 2015 - 09:59 AM
Nice looking lobes.
Very different to the regrinds from back in the day.
#24 TerrA LX
Posted 27 February 2015 - 10:11 AM
Hi Dave.
What brand and part number are the lifters your using?
#25 N/A-PWR
  • 9,639 posts
Posted 27 February 2015 - 11:50 AM
Not wrong Rob,
My regrind here, which I bought from Rare Spares, Strathfield,Sydney,1986:-
Attached File  IMG_5691.JPG   42.21K   0 downloads
Nice looking lobes.
Hi there TerrA,
The Roller Lifter didn't come in a bag, but using a Plossi lens,
there is Comp Cams written on the bridge mount ( Comp Cams - 25/13 ),
and the screw at the back ( cheese head ), has 'YES' stamped around the allen headed head.
I looked up the Comp Cams Solid Roller Lifter section, and this one looks a little different.
But the bridging ( link-bar 839-L ) piece did come in a bag, which lines central to the little 6 lifter bores.
Hi Dave.
